Does a Heat Sink engine mount work?
Hi guys,
I wonder if someone ever saw a temperature difference with an Heat Sink Engine Mount?
Any link to good one for the R40 or the MTX3?
Re: Does a Heat Sink engine mount work?
Originally posted by Frag
Hi guys,
Hi guys,
I would say it won't help in lowering your engine temp.
Hi guys,
Hi guys,
In actual life, naw
Re: Re: Does a Heat Sink engine mount work?
Originally posted by B
Yes it make a difference. That is in theory.
In actual life, naw
In actual life, naw
Naaa, no one actually measured a temperature difference.
They're .1% cooling and 99.9% bench racing.
transfer heat
If you want to increase the efectiveness of heat transfer from the engine to the chassie, apply some electronics heat transfer paste between the mounts and the chassie. This does work well, if you try it you can feel the temp. increase on the chassie with your hand after you run the car.
thanks
You can buy it at radio shack. Its also used for mounting heatsinks on computer CPU's
