Old 04-14-2004, 02:52 AM   #1
doublest's Avatar
Send a message via MSN to doublest
Exclamation Running Problems
After a few mins running and also frok start the car does idle smooth.
It will go up and down etc. And was thinkin that this proberbly an air leak. Im thinking this is the primer on the tank as i know many people that have had problems with the primer.
Im running an HPI RS4 3.
Shall i go ahead and remove primer and block hoel and if its ok, get a new primerless tank.
doublest is offline   Reply With Quote
Old 04-14-2004, 06:21 AM   #2
nitro rookie's Avatar
I pulled my primer out of mine and put a screw in it with some shoe goo. Then I replaced the tank later. I also seal the engine to make sure I wasn't getting any air in around the back plate and carb. Might also want to check to see if you head is on tight along with your glow plug.
nitro rookie is offline   Reply With Quote
Old 05-13-2004, 10:41 AM   #3
mop_iko's Avatar
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
Default AIR LEAK oh... AIR LEAK
go here:
click me! click me! click me! aaaaaaaahhhhhhhhh
u will be amazed what this artcile tells you... all about air leaks... especially from engine and tanks.
they even say... NEW ENGINE also sometimes have air leaks... so right after you buy the new engine... please make sure to do what the article suggest....
thanks to IntialID who gave this link to me.
mop_iko is offline   Reply With Quote
X12 running problems MRX4-R03 Onroad Nitro Engine Zone 1 08-24-2006 08:02 PM
running too rich or running to lean bumm_off_street Nitro On-Road 7 03-29-2006 07:28 PM
TRX 2.5 running problems Xero Rookie Zone 3 01-29-2005 07:29 AM
Running in teething problems!! J3st3r Rookie Zone 5 04-18-2004 10:22 AM
HPI RS4 Nitro 3 running problems racerhpi Rookie Zone 5 03-15-2003 10:07 PM
SEO by vBSEO 3.5.0
