RS4 Problem
RS4 Problem
Hi all, I just finished putting a graphite upper deck on my RS4 and everything looks good, I turn on the power and all the servos work good, then when I start the motor and run the car the throttle servo goes to full speed and my steering turns all the way to the left and the car just GO's? What could be the problem??? Thanks
Re: RS4 Problem
I checked the reciever and everything looks okay. No wire exposed?? Any other ideas?
Make sure that your receiver is not touching the graphite directly. Also make sure the none of the servo wires or antena wires are touching the graphite.
The other thing to look at is your throttle linkage. If its touching the upper deck, the rubbing when your motor is running can couse interference. Actually, make sure that nothing metal to metal or metal to graphite is vibrating and rubbing together.
The last thing, actually should be the first thing you check is that you have a fresh set of batteries or a fresh charge on your receiver pack
