Old 07-26-2010, 06:11 PM   #76
NITTO550's Avatar
Originally Posted by NikoRacing View Post
Yes...I've just cut out, coloured and test this body. I used the original cut line for the wing but it was very very under the roof-height.
I think you could try to cut it 3/4mm higher than the line.
Normally I use the second hole on the body post (using the NT1) but shifted to the third because the grip was simply not enaugh with the wing cutted on the line.
Ps: for quietstorm..raise the hole post is better than putting shims under the wing because it also incline it and make it more efficient (more surface is touched by the air)
I raised the body one hole on the rear on my nt1, and I had to add 1 degree of camber cause the car was rolling even more than before.
There are only two ways to do things. The wrong way or my way!
Rich D..
~Mugen Seiki Racing MTX-6 ~,
Novarossi racing Engines ~Ko Propo, ~Avid Bearings..
VBC Racing Wildfire D07 ~LRP Electronics ~ Fantom Racing
NITTO550 is offline   Reply With Quote
Old 07-30-2010, 12:55 PM   #77
Does know where I can get this body? Everywhere I check is out of stock.
bdortch is offline   Reply With Quote
Old 07-30-2010, 01:32 PM   #78
RC MARKET's Avatar
last 1pc instock,
next shipment at 9 AUG !
RC MARKET is offline   Reply With Quote
Old 08-13-2010, 12:51 PM   #79
Default sticky windows maskin. solution.
Originally Posted by Speedypeterb View Post
+2 they need new window mask thats ridiculous to have to spend more time cleaning the windows then actually putting the paint on I also used alcohol
Painted the chevy tonigt and took of the windows maskin. Yes. it did not remove easy, but then i tryed with a heatgun and warmed up the windows from the outside. You can see when the maskin starts to bubble. And the maskin whent off easy and total free off glue.
speikey is offline   Reply With Quote
SEO by vBSEO 3.5.0
