Xceed 1/10 200mm Chevy
#64
Later Peter,
See you in a couple of weeks,
DJ Apolaro
#67
Nice, Tino needs to make sure next time to specify he wants the lap time also.
DJ Apolaro
DJ Apolaro
#68
Congrats to Brian Thomas for the TQ at the Kamikaze Invitational. This shows the the body is not only good for small tracks and that it works in every chassis
#69
The body post markings are for which chassis ?
#71
I heard somewhere that the cut lines on the wing was 5mm too low. Any truth to this?
#73
I wish I had that info 4 bodies ago. Any suggestions on how to fix this since they are already trimmed
#75
I think you could try to cut it 3/4mm higher than the line.
Normally I use the second hole on the body post (using the NT1) but shifted to the third because the grip was simply not enaugh with the wing cutted on the line.
Ps: for quietstorm..raise the hole post is better than putting shims under the wing because it also incline it and make it more efficient (more surface is touched by the air)
