Old 01-26-2011, 10:05 PM   #1426
CHRISP76's Avatar
Yeah mate, I've been on and off racing for a long time now, but back for good this time. You're probably right, I just like to try and get everything spot on. Racing on the 13th??
Chris P
MUGEN / NOVAROSSI / MATRIX
CHRISP76 is offline   Reply With Quote
Old 01-26-2011, 11:04 PM   #1427
CHRISP76's Avatar
Guys I apoligise if this has already been covered but I have one more question. Are you guys running the carbon discs on the uprights? If so, do you find any benefit? I know the theory behind them but I'm actually going to try my car with them off again....
Chris P
Old 01-27-2011, 04:03 AM   #1428
asw7576's Avatar
Originally Posted by CHRISP76 View Post
Thanks for all the advice guys. I'm using very good quality JR servos and I also use aluminium servo horns so I'm fairly confident this is not the issue but will investigate this theory further.
Some allumunium servo horn ( ofna style ) use plastic adaptor. Plastic adaptor for futaba, jr, ko propo, etc. The problem is the plastic adaptor. Overtime it will get some play. I settled it with epoxy glue in my case.
Old 01-27-2011, 04:32 AM   #1429
ltrdude's Avatar
Trader Rating: 29 (100%+)
Default servo horn
Racers edge makes a real nice aluminum servo horn that clamps onto the servo with two bolts.They make them for all different servos.They also come in all different colors if your into that
ltrdude is offline   Reply With Quote
Old 01-27-2011, 05:40 AM   #1430
ralphierace13's Avatar
yes montonica there are alot of theroys i guess cause i have ocd i didnt stop till i got the car stright mine was the servo didnt stop adjusting i tried new horn everything only fix is to counter act it with the toe trim dont matter bout the track, if it was bad like mine then just leaving pit lane the car wants to go into the wall, so either change servos or do like i did...
RALPH FORTUNATO
MUGEN SEIKI MRX6 TEAM DRIVER
Futaba 4PK-S-R, Novarossi Team Driver, CONTACT TIRES
Byron Fuel, Veytrex Desgin Labs
2014 R.O.A.R. REGION 1 CHAMPION!!
ralphierace13 is offline   Reply With Quote
Old 01-27-2011, 05:45 AM   #1431
CHRISP76's Avatar
Haha, I too have OCD. Thanks for all your help.
Chris P
Old 01-27-2011, 11:36 AM   #1432
Hey guy i used this tension on my mrx5 and it took care of my side belt issues
ososofast is offline   Reply With Quote
Old 01-27-2011, 03:07 PM   #1433
ltrdude's Avatar
Default MRX-5 Parts
J&S Racing has a side belt tensioner.the first batch will be avaliable next week from Brooklyn hobbies.Also with the low CG of the MRX-5 gas tank we came up with a slick little handle that mounts on the tank handle.Next all you I-Phone users,this is a devise that screws right on to the MRX spindle and with your I-Phone you can check camber and caster at the same time.On the bottom of the devise is a half moon piece that simulates a 67 MM tire.When you compress the suspension you can watch your camber and caster gain.Dan Louis came up with this Idea and I am working on these tools for other 1/8th scale cars.Attachment 699972
Attachment 699973
Attachment 699975
Attachment 699976
Old 01-27-2011, 03:20 PM   #1434
walo's Avatar
Send a message via Yahoo to walo
Nice , this side belt tensioner is adjustable from both ends.
walo is offline   Reply With Quote
Old 01-27-2011, 03:38 PM   #1435
YLLIB's Avatar
Nice work, thatís pretty interesting tool and parts. I like that you can see caster gain and the device can be used on either side for setting perfect camber. I want one and I would even like it for kicks and giggles...even if some racer thinks itís an over kill device. It looks like it would work more acurate than any tool out there right now...Nice work John. ÖÖ
YLLIB is offline   Reply With Quote
Old 01-27-2011, 05:33 PM   #1436
BIREL8's Avatar
Very nice. I want two on each.
Steven Jackson
KILLA BEEZ
SHEPHERD USA
DESOTO RACING
KOPROPO
BIREL8 is offline   Reply With Quote
Old 01-27-2011, 05:37 PM   #1437
tdr170's Avatar
Default Side Belt
Here is another option for the side belt and available from the link below.
http://www.teammarketingamerica.com/..._Products.html
MUGEN SEIKI MRX5-dnm-20tension-20guide-20on-20car-201.jpg   MUGEN SEIKI MRX5-dnm-20tension-20guides.jpg
tdr170 is offline   Reply With Quote
Old 01-27-2011, 08:13 PM   #1438
I don't get it. The MRX-5 middle belt is way too long. Why not think about to get the right length of belt instead of getting a double belt tensioner. RC-Mushroom has already selling the right belt for MRX-5 at http://www.rc-mushroom.com/product_i...ducts_id=15962 I installed it and the tensioner set to the most top level. The original belt is useless now.
ioxqq is offline   Reply With Quote
Old 01-27-2011, 09:09 PM   #1439
Seisick's Avatar
Has anyone tried flipping the tensioner and cutting just a bit the radio tray and also flipping the tensioner screw stopper i bet it will help some mm to the tension we did similar on the mtx4
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 01-27-2011, 10:12 PM   #1440
ltrdude's Avatar
Default side belt
one less part I need to make.I had alot of people looking for a fix for this long belt issue.I kinda figured Mugen or an aftermarket company would come through.Now I can work on other stuff.
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 08:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 10:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 09:49 AM
SEO by vBSEO 3.5.0
