Old 01-25-2011, 02:44 AM   #1396
occ
Trader Rating: 15 (100%+)
Originally Posted by R&TRacer View Post
Earlier this month did a barrel roll in the second lap of the mains. Broke the rear upright.
At my LHS I noticed that Mugen had already redesigned the rear uprights. They added additional ribs on both sides of the original rib. I'm glad they did this because I've had harder impacts on my MRX4 and never broke a rear upright in this manner.
Look at the attached photos and you can see the part I broke and the replacment part thats available on the shelves here.
Thanks for the feedback. Is this new rear upright a running change or a new Part Number?
occ is offline   Reply With Quote
Old 01-25-2011, 03:06 AM   #1397
ralphierace13's Avatar
Originally Posted by Slo-MTX4 View Post
Have you tried this Ralph? This is what Robert used to TQ wasnt it?
Also has anyone tried the new 909 with the central fin and lower sides?
yes the team tried and liked the r-15 we also tried the new p909 with the center fin, i like the original p909 best then the r-15 the new p909 was ok.
RALPH FORTUNATO
MUGEN SEIKI MRX6 TEAM DRIVER
Futaba 4PK-S-R, Novarossi Team Driver, CONTACT TIRES
Byron Fuel, Veytrex Desgin Labs
2014 R.O.A.R. REGION 1 CHAMPION!!
ralphierace13 is offline   Reply With Quote
Old 01-25-2011, 03:07 AM   #1398
i cant beleave mugen would make a new rear upright when thats not the god damm problem to fix, fix the damm front end allready and shorten the side belt!!!!!!!
RALPH FORTUNATO
Old 01-25-2011, 03:09 AM   #1399
Originally Posted by West03 View Post
I mounted the p909 at 25mm and the car went from stable to almost un-driveable. Rear of the car just kept stepping out throughout the fast corners and pushed in the slower corners.
I originally had the body mounted at 18mm with little room for the finger to get excess to the fuel tank lid. The car at that stage was able to fight for tq and had set one of the fastest times of the day at our recent state titles. Easy to drive on the limit. However my pitman was going to struggle to get his fingers in to pull the lid, so I mounted the new body forwards. Lets say its an annoying lesson and something I won't do again. I believe 20 - 18mm is the best position for the MRX5 with the p909.
i agree with u what i said before i would start with 20mm with pins back.
RALPH FORTUNATO
Old 01-25-2011, 03:36 PM   #1400
walo's Avatar
Send a message via Yahoo to walo
I finished building my new MRX-5 and the car looks great . The drive train feels very free. I can't wait to take it out for a spin.
walo is offline   Reply With Quote
Old 01-25-2011, 07:00 PM   #1401
Slo-MTX4's Avatar
Send a message via ICQ to Slo-MTX4
Thanks Ralph. Will get one to try.
Podified Picco/MRX5/Futaba/Savox
PODIFIED ENGINES/Trackside RC
Slo-MTX4 is offline   Reply With Quote
Old 01-25-2011, 07:26 PM   #1402
good job walo now get out there and smash it into a wall in a half of lap like your good at doing!!!
RALPH FORTUNATO
Old 01-25-2011, 07:29 PM   #1403
CHRISP76's Avatar
Here here!!!
Chris P
MUGEN / NOVAROSSI / MATRIX
CHRISP76 is offline   Reply With Quote
Old 01-25-2011, 10:03 PM   #1404
asw7576's Avatar
Is this correct assumption ?
When I mount the body farther from bumper ( ex. 18mm gap from bumper ) = I get more steering but expect to get less stability at rear end ?
When I mount the body close to bumper ( ex. 6mm gap from bumper ) = I get less possible steering but I have more stability at rear end ?
Increasing the height of rear wing ( ex. additional 15mm height increase ) = more stability at rear end ?
Old 01-25-2011, 10:20 PM   #1405
Slightly changing the subject, where can you purchase this new shell from.
Andy
Shepherd is offline   Reply With Quote
Old 01-26-2011, 04:06 AM   #1406
Andy
brooklyn hobbies can get u any shell..
RALPH FORTUNATO
Old 01-26-2011, 04:08 AM   #1407
yes your theroy is right but i would not go 6mm from bumper!! your car might only go stright lol
RALPH FORTUNATO
Old 01-26-2011, 04:11 AM   #1408
CHRISP76's Avatar
Hey fellow MRX5'ers,
I have a problem with mine which I'm hoping you can help me with.
I use a Hudy set up station. I set the car up, including toe, camber, tweak etc. absoutely perfectly. I true tires exactly the same using a Hudy truer.
As far as I'm concerned the car shoud run dead straight after all this. Trouble is, I put the car on the track and find I have to put steering trim in every time which means I end up with one front toeing out and the other toeing in.
Any thoughts/suggestions??
Any help will be much appreciated...
Chris P
Old 01-26-2011, 05:11 AM   #1409
Flygio's Avatar
When you set front toe out, you must align the quick levers. I like to set them vertically when checking toe, and horizontally when checking camber. If they ain't parallel you may have different angles L&R, even though they seem the same when reading the gauge values
And of course check front one way bearings, sometimes if you put too much oil in them, they could slip, pulling the car away from the straight line.
All of this assuming that your shocks and down-stops are equally setted.
ciao
Flygio is offline   Reply With Quote
Old 01-26-2011, 05:26 AM   #1410
R&TRacer's Avatar
The part number on the bag hasn't changed. It's still H2124. I would say this is a running change.
R&TRacer is offline   Reply With Quote
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 07:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 09:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 08:49 AM
