Old 01-12-2011, 06:55 AM   #1306
RC MARKET's Avatar
CSO New product for MRX-5 again !
MUGEN SEIKI MRX5-cso-mrx-5036.jpg   MUGEN SEIKI MRX5-cso-mrx-5037.jpg   MUGEN SEIKI MRX5-cso-mrx-5038.jpg   MUGEN SEIKI MRX5-cso-mrx-5039.jpg
RC MARKET is offline   Reply With Quote
Old 01-12-2011, 06:57 AM   #1307
RC MARKET's Avatar
Part II
Old 01-12-2011, 12:30 PM   #1308
Originally Posted by MugenDrew View Post
29 tooth side pulley 66mm front, 73mm rear still seems to be the sweet spot, if your willing to run fresh cut tires every round. The main is gonna be up to the tire wear and layout. Everytime you run the car write down your starting and finishing diameters so you can monitor your tire wear. Other questions for the main, are you going to change tires(1/2 hr in a parking lot can be tough on tires), are you going to mix up the shores to compensate for wear, are you going to cut all four tires to different diameters to compensate for wear? Half hour at the Fort I would probabley start out with the left front .5mm larger than the right and the rear left say 1-1.5mm larger same shore. There is "no tire wear at the FORT" so to say, there maybe to much traction though...NOT! there is no such thing as to much grip only to low of a roll center
Thanks Drew.
Are you going to be at the Winter Nats?
Desoto Racing, Serpent America, Novarossi, KoPropo, Xceed.
2011, 2013, 2 Time Midwest Series 1/8th Open, Champion
2011 Byrons onroad 1/8th Open 3rd
2011 Roar Nats 1/8th Open, 5th
2012 GLC 1/8th Open Q7 Finish 5th, 2013 GLC 1/8th Open Q4 Finish 7th
Vector03cobra is offline   Reply With Quote
Old 01-12-2011, 01:03 PM   #1309
Stuff Of Legend's Avatar
Exclamation LONG BELT FIX MAYBE?
MRX5 Long Belt Fix.... MAYBE!!
In my MRX5 manual PAGE -11- Figure 27 Kit Bag - G1, G2
Manual photo suggest you install part #H0294 belt tensioner guide with bump stop(thats the name i give it) at the bottom.
My suggestion is to install it with the bump stop to the top and i find that the belt teeth at its closest is 3mm to 4mm.
I cant tell you that the teeth will not stripe seeing as i have not driven car yet.
My camera battery door is broken so i cant take photo!
Good luck let me know if its works
RC STABLE....
CRC GEN X 10se
YOKOMO BD72016 - SERPENT VIPER 977e
HOBBYWING motor's/esc's - PROTOFORM bodies
SAVOX servo's - SPEKTRUM tx/rx - XCEED tire's
Stuff Of Legend is offline   Reply With Quote
Old 01-12-2011, 03:26 PM   #1310
West03's Avatar
Yes, thats what I have been doing. Make sure you file the corner of this part which faces the engine mounts so they don't touch.
EGA . MUGEN SEIKI (MRX5 WC) . MMI . SANWA . MURNAN MODIFIED
MRCCR - MELBOURNE RADIO CONTROL CIRCUIT RACING
www.mrccr.com.au
West03 is offline   Reply With Quote
Old 01-13-2011, 06:24 AM   #1311
MugenDrew's Avatar
Trader Rating: 24 (100%+)
Originally Posted by Vector03cobra View Post
Thanks Drew.
No. Family will be in town and I get to let mickey rodent drain my wallet. I will be at the state race...
MUGEN SEIKI NOVA ROSSI ENETTI TYRES HUDY PROFESSIONAL TOOLS
BYRONS FUEL AIRTRONICS RADIO EQUIPMENT PROTOFORM RACE BODIES
MUGEN RACING RC AMERICA AKA RACING NUGGETS RACING DESOTO RACING
MugenDrew is offline   Reply With Quote
Old 01-15-2011, 10:00 AM   #1312
bsmooth's Avatar
Trader Rating: 17 (100%+)
Default one-piece engine mount
Guys,
Is this a necessary add-on?
If so, does Mugen/MSR make one, or should I go with the Arrowmax brand?
Thanks,
Steve
bsmooth is offline   Reply With Quote
Old 01-15-2011, 10:23 AM   #1313
YLLIB's Avatar
I crash more than most and have raced the car on a smooth and ruff track and mine has never came off. But if you feel more secure putting one on then I would, personal preference, it's not going to hurt as long as you do not have it too tight. When mine comes off I will, lol.
YLLIB is offline   Reply With Quote
Old 01-15-2011, 05:47 PM   #1314
walo's Avatar
Send a message via Yahoo to walo
Originally Posted by bsmooth View Post
Guys,
Thanks,
Steve
You really don't need the uni-block(one-piece engine mount). It's an option to help prevent chassis flex in that area of the car. If you decide to purchase one, you should get the MUGEN brand .
walo is offline   Reply With Quote
Old 01-15-2011, 11:46 PM   #1315
YLLIB's Avatar
DITTO good call. There is not to many after parts you need for the car. It's good like it is..IMO, put who ask, right....
Old 01-16-2011, 10:24 AM   #1316
I am new to MRX5, What to know are spare should keep in pit box? Also are those steel outdrive easy worm out?
ioxqq is offline   Reply With Quote
Old 01-16-2011, 10:43 AM   #1317
YLLIB's Avatar
IMO, rear arms, frt upper eyelet, frt lower arms, plastic steering knuckle, gears, bumper and clutch parts, not that the clutch is bad, it's just nice to have clutch parts and clutch bearing incase. These are safe parts to have. The out drives are good. The tighter and more turns at a track then they will get sloppy but not quickly. Just because on and off the gas slaps them around pretty hard.
I am sure other racers will some other parts to mention.
Old 01-16-2011, 10:46 AM   #1318
wingracer's Avatar
Trader Rating: 22 (100%+)
Front shock shafts, bodies and plastic shock parts. Not because they are bad or easy to break but because they can break in a hard front wreck and no one seems to have them when you need them. Also a front shock tower.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 01-16-2011, 11:04 AM   #1319
Steve Rossi's Avatar
BELTS AND A PULLEY SET
We will give away a $10 off coupon on purchases over $50 once we reach 800 likes.
https://www.facebook.com/srossimotorsports
SROSSIMOTORSPORTS.COM - OS SPEED - PROTO-FORM - PROLINE - MURNAN MODIFIED -KO PROPO- JUN RC JAPAN - RC AMERICA - SPEEDMERCHANT - EAM MOTORSPORTS
Steve Rossi is offline   Reply With Quote
Old 01-16-2011, 12:39 PM   #1320
bsmooth's Avatar
Thanks.
My motor mounts got stolen!
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 08:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 10:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 09:49 AM
SEO by vBSEO 3.5.0
