Old 11-12-2010, 05:38 AM   #991
How much distance from the bumper do you guys mount your body ?
[Mugen Seiki MRX-5]
Backspace. is offline   Reply With Quote
Old 11-12-2010, 05:50 AM   #992
Phil Trotta's Avatar
I'm running p909 16 to 20 mm foward
PHIL TROTTA
Phil Trotta is offline   Reply With Quote
Old 11-12-2010, 10:57 AM   #993
Originally Posted by asw7576 View Post
In my hometrack, top 10 drivers are mostly using mrx5 now.
Few drivers still use mrx4x and kyosho m3.
The usual finish number 1 driver is still using mrx4x.
Here a little story about mrx5 vs mrx4x :
Last weekend, the usual finish number 1 driver (mrx4x) is finished 2nd position, and the usual finish number 3 or 4 driver ( brand new mrx5 ) got lucky and finished 1st position.
The usual finish number 1 driver said to me after the race, "mrx5 is definetely better car than mrx4x, especially in high speed sweeper. I'm slower at that sweeper. He (mrx5 driver) closes the gap from that sweeper and finally pass me at lap 150".
According to him , All mrx4(x,r) cars have understeering tendencies when push to the max ( eventhough he already done 3mm wheelbase mod ).
Ok the truth is this is my first mugen after the evo m3 and graduated to 1/8 last 3 months after staying in 1/10 ep and boy it is an amazing world i come to.You guys really making life alot easier. Big thank you for all advice
Romeo 7 (Chief Entertainment Officer)
Romeo is offline   Reply With Quote
Old 11-12-2010, 07:41 PM   #994
Can someone tell me the exact dimensions of the bearings nearest to the tires ?
[Mugen Seiki MRX-5]
Old 11-13-2010, 04:00 PM   #995
ralphierace13's Avatar
to all the guys with glitching problems discovered something today might be an answer, most of he time i tune my motor with the cover off but today was tuning on the track and couldnt get to the low speed screw so i turned the carb out so the screwdriver can get to it ok went on the track car was glitching all over the place went back and what i found was when turning the carb out like that i found the throttle body binding was like chattering when opening all the way also getting stuck open.. so i turned the carb back and wala glitching went away so guys go check the strain on the throttle servo is causing the glitch.. cause we all have this problem its hard to get to the low speed screw cause of the tank and this could b y all diff radio systems r having this problem please let me know if this helps
RALPH FORTUNATO
MUGEN SEIKI MRX6 TEAM DRIVER
Futaba 4PK-S-R, Novarossi Team Driver, CONTACT TIRES
Byron Fuel, Veytrex Desgin Labs
2014 R.O.A.R. REGION 1 CHAMPION!!
ralphierace13 is online now   Reply With Quote
Old 11-14-2010, 08:31 PM   #996
GMartinez's Avatar
Trader Rating: 85 (100%+)
Ralph was it a glitch or just that it was binding up & getting stuck
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 11-14-2010, 09:24 PM   #997
asw7576's Avatar
deleted
Old 11-15-2010, 02:23 AM   #998
big g i would say it was glitching more then getting stuck richie says the binding is causing a strain on the servo causing it to glitch as soon as i returned the throttle to the normal position it went away for the rest of the day, it was going into fail safe when i would go full throttle
RALPH FORTUNATO
Old 11-15-2010, 05:25 AM   #999
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
our new & improved region 12 race saw the X5s do really well with swauger winning
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 11-15-2010, 02:43 PM   #1000
GMartinez's Avatar
10-4 ralph can u kill the big g I know I gained some pounds since I left N.Y. but know you got my thinking
Old 11-15-2010, 02:44 PM   #1001
GMartinez's Avatar
Congrats Mike
Solo any links to check results or video
thanks in advance
Old 11-15-2010, 03:46 PM   #1002
What about glitching in the steering servo?
miker2209 is offline   Reply With Quote
Old 11-15-2010, 06:36 PM   #1003
Congrats Mike
thanks in advance
i don't have any but they post something soon cars are dialed
WILLIAM PENDERGRASS
Old 11-15-2010, 07:33 PM   #1004
Carl Giordano's Avatar
Trader Rating: 20 (100%+)
Hello Ralph
If using digital servos be sure to set the EPA so not to overload the servo. Digital servos operate much differently than analog. Digital servos will always try and center themselves and max out to the end points. If the servo is straining, it will cause the servo to stutter and appear as if it was glitching. This is why I still use analog servos on the throttle. Hope this helps.
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 11-15-2010, 07:50 PM   #1005
Originally Posted by Carl Giordano View Post
Hello Ralph
thanks i hear what u saying but this was deff caused by the angle of the carb cause it was pointed out ward and the linkage to the servo is like bending the throttle body inward as its trying to pull it out so its overloading it. causing the glitch and to the other ? from the other post yes if the throttle glitches it will cause the steering to glitch as well.. alot of guys with the glitching problem kept looking into things like the rec over heating and i posted a few times that its most likly something small like 2 screws touching and so on so i showing an example of how somthing so stupid can cause it and with the throttle alot of guys might have turned it out cause u cant get to the low end needle cause of the tank...
RALPH FORTUNATO
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 07:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 09:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 08:49 AM
