Old 11-03-2010, 07:20 PM   #961
GMartinez's Avatar
Trader Rating: 85 (100%+)
Originally Posted by ralphierace13 View Post
sorry big g i didnt mean it debating either i was laughing thinking of the car melting down on us at 70mph lol.. but i do think its something stupid causing it like a screw touching someone will find it out im sure soon...
no doubt it's all good
just think of it in this manner the car is going 70mph but the rx is enclosed & not getting any kind of circulation of cooling that is why certain drivers had that issue in off road of overheating the rx
another example drive 100mph in your car with no ac for 15 minutes an the temps outside are 90deg you would overheat as well
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 11-03-2010, 07:38 PM   #962
ralphierace13's Avatar
see now we got a problem what richie tell u my car has no air condition cause i had to sell my good car to buy a 5 so now i got one thats busted!!! and u got to make fun of me lol
RALPH FORTUNATO
MUGEN SEIKI MRX6 TEAM DRIVER
Futaba 4PK-S-R, Novarossi Team Driver, CONTACT TIRES
Byron Fuel, Veytrex Desgin Labs
2014 R.O.A.R. REGION 1 CHAMPION!!
ralphierace13 is offline   Reply With Quote
Old 11-03-2010, 07:40 PM   #963
GMartinez's Avatar
I got 1 on richie but u will get your chance in december
Old 11-03-2010, 07:56 PM   #964
well the heat issue is easy to find out im sure someone has one of those venom heat probes u stick on your engine and gives u a constant heat reading just stick it in the rec box and run the car see how hot it gets..
but i still have to say the guys who have the problem got to recheck the cars something is touching might have to rebuild the whole car but guess it would b worth it
RALPH FORTUNATO
Old 11-04-2010, 02:23 AM   #965
Phil Trotta's Avatar
We were on the phone with mugen USA. The radio tray where the servos mount back to back you may want to use smaller screws. Like 3by10 mm. The longer 3 by12 mm may touch. This could cause some problems. I'm using 3 by 10 in this spot with the countersunk washers over the servo. Have no problems. Hope this helps.
PHIL TROTTA
Phil Trotta is offline   Reply With Quote
Old 11-04-2010, 06:50 AM   #966
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
thanks for the info good luck to all the MRX5 is outstanding
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 11-05-2010, 10:54 AM   #967
Hi running the car on stock setup for asia, and the track in singapore is high flowing but very little traction. Car tend to oversteer out of high speed sweeper and rear traction break away on tight corners say abt 180 deg corners. Running 35 shore tyres rear 76mm front 71mm downstop rear 8 front 2, rear.Ride hight is 6 front 7 rear The rest is standdard setup found in Mugen site for asia track and Need help. Newbie to 1/8 and my 1st mugen.
Romeo 7 (Chief Entertainment Officer)
Romeo is offline   Reply With Quote
Old 11-05-2010, 11:08 AM   #968
wingracer's Avatar
Trader Rating: 23 (100%+)
Try a bit more rear toe-in. Also, move up the gurney strip on the body and/or move the body back.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 11-05-2010, 11:12 AM   #969
Thank you sir,
Shell used is P909 20mm from front bumper, Gurney is at max i try the toe in later today.
Old 11-06-2010, 04:36 AM   #970
u can try a quick simple fix also turn the dual rate down till it feels good..
RALPH FORTUNATO
Old 11-06-2010, 06:58 AM   #971
Thank you Ralf sir, cant do anything very wet weather in Singapore. Can you also help explain the H221 part b and c what it does and how we apply it.
Old 11-06-2010, 10:24 AM   #972
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
about year when i was racing offroad...i have a M11 w/spektrum and had 2 run aways, i thought it was the battery & they were fine ..called horizon shipped the radio and reciever to them they fix it no problems with binding or runaway....they issue a recall on their website on the model & serial numbers ...so you guys might wanna check that out and contact them
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Old 11-06-2010, 10:26 AM   #973
try running 7 mm split...76 rear 69 front
PHIL TROTTA
Old 11-06-2010, 02:46 PM   #974
Roger that jack hammer. Thanking you in advance still waiting for the rain to go away.
Old 11-10-2010, 05:36 AM   #975
MugenDrew's Avatar
Trader Rating: 30 (100%+)
I have run the car once so far on a hot day 95F. The rear end was unstable and unpredictable to say the least. I was running 35 all the way around and did not have time to do any testing.
I lowered the rear lower arms hinge pin to the bottom hole reset rear drop to 8mm, Changed the shim under the rear upper arm to 1mm, set front drop to 1mm and set the acerman adjustment to the middle mark. Car was good.
We have a race at the same track and I believe there are better answers for this track....
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 07:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 09:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 08:49 AM
