Old 10-15-2010, 09:56 AM   #811
kitracer's Avatar
Default radio problem
Any one experience Radio interference problem on this car.... Why I said that because I have problem in this car only and not my other 2 cars I run. If I switch the same radio gear back to my other cars, it all works fine. I use the Specktrum 3R
We have at least 3 or 4 other MRX 5 run away on the same track within pass 2 weeks. Some of using 4PK with the larger receiver and found that caused problem (box too small to fit) and once they switch, I believe 2 have fixed the problem.
BTW, I use all brand new gear and battery ( I also tested 2 different battery) not the Transmitter which works fine on my V8, HK-1 on the same day!....
I just bought a 4PKS and the mini receive will try on the weekend. This will be 4th attempt
Nitro-x Tomorrow Fuel today
Blitz body the champion choice
kitracer is offline   Reply With Quote
Old 10-15-2010, 11:08 AM   #812
asw7576's Avatar
BTW, I use all brand new gear and battery ( I also tested 2 different battery) expect the Transmitter which works fine on my V8, HK-1 on the same day!....
This is what I did with my R113iP 1024PCM receiver module.
1. Open Futaba casing, and take out the electronic board.
2. Glue small alumnium foils to cover the inside of radio box, ( to reduce unwanted radio signals or reduce radio interference from outside )
3. Install small foams to cover the inside of radio box, ( to eliminate engine vibrations )
4. Put the electronic board inside radio box, and close it.
Old 10-15-2010, 03:35 PM   #813
ralphierace13's Avatar
only thing i can add might help after i found out the hard way if u use a 6.6 or 6.0 life or lipo even they the volts r in spec when u charge it they go up to 8.4 now i have m11x so i dont know if it happens on other systems but something to watch after a few times u run the car with a fully charged battery its burning something out in the reciver. dont know if that helps..
RALPH FORTUNATO
MUGEN SEIKI MRX6 TEAM DRIVER
Futaba 4PK-S-R, Novarossi Team Driver, CONTACT TIRES
Byron Fuel, Veytrex Desgin Labs
2014 R.O.A.R. REGION 1 CHAMPION!!
ralphierace13 is offline   Reply With Quote
Old 10-15-2010, 09:29 PM   #814
kitracer's Avatar
thanks guy
but
We all using 2.4G and I used new 1600 nimh battery that works fine once I installed to my V8 and I tried a Life packed that I borrow, still no good so is not battery.
The problem seems to be the same for all of us, it get stuck at Full throttle for extra 0.1 to 0.5sec at same time the steering lose response as well. Now I think of it, it only happens to me at full throttle ( I adjusted the carb and links so they r free)
Old 10-16-2010, 07:20 AM   #815
kitracer's Avatar
one more friend MRX5 radio problem today, this time on Sanwa M11X , new receiver new servos on the car, crashed broke front bumper and shock.
Same thing, out of corner, throttle stuck at full speed then no response from steering
His car had no problem last week and he was making fun of me just yesterday. Now he got the problem!!!!!
We all Testing for FEMCA starting from Monday so this is bad news for MRX5 drivers
Old 10-16-2010, 08:39 AM   #816
iwk2much's Avatar
Do you use the rubber grommet for the wires leading into the radio box? Could the wires be pinched?
Mike Strack
iwk2much is offline   Reply With Quote
Old 10-16-2010, 11:01 AM   #817
im using an M11x with brand new receivers, servo(bls351) and batteries life 1600, 6.6 while running in no problem after running in full speed same problem
i was running alone at the track. Have 4 cars with same configuration.
Can anyone share the wiring technique differ from the manual.
Romeo is offline   Reply With Quote
Old 10-16-2010, 11:36 AM   #818
Roelof's Avatar
Send a message via ICQ to Roelof
I do have some doubts with the rear brake, a large metal brakedisc ticking on a thick axle can cause problems with the receiver. I will not say it is the cause but it could be. Maybe an idea to create a epoxy brakedisk?
Sometimes it helps to put the chassis to the ground of the electrical system.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 10-16-2010, 11:37 AM   #819
NikoRacing's Avatar
Hello form Italy!
Are you sure that is a problem of the car? I've heard that the M11X is having some problem..
Infact I have a Futaba 3PK and I would try another radio but many drivers suggest me to wait for the next Sanwa because of this problems. I know that D.Ielasi is trying something new in his radio...
NICOLA PEZZOTTI - italian F1 cat. driver - Serpent 747 - HIPEX exhaust system - HOTRACE tyres - SANWA M11X
NikoRacing is offline   Reply With Quote
Old 10-16-2010, 04:25 PM   #820
Couple of things that I looked over very closely when I was assembling my 5
1. I made sure I was using a brand new battery extension cable and that when plugging in to the battery there was NO tension on either cable.
2. I use a KO radio and Spektrum TX/RX , My RX was a very tight fit into the receiver box, I flipped over the reciever so that the servo cables and the battery cable came straight into the box and plugged straight into the reciever and the antenna goes right up the hole for the tube.
3. I would re-bind your radio, when building a new car we turn them on and off setting everything up and sometimes we forget which we turned on first and turned off last and it can plays hell on Spektrum. I did mine
There is no doubt that the reciever box is very tight but if you cram every thing in there and then screw it shut, your gambling. I shortened my servo cables so that they were about 1-2 inches left sticking out of the reciever box.
I have seen Ralph Burch drive an RC car, It was an amazing thing to watch. So I joined his team and got the same car... XRAY and RC AMERICA
CFowler is offline   Reply With Quote
Old 10-16-2010, 04:45 PM   #821
i am telling u i had the same problem with my m11x u can not use a life or lipo with m11x recivers when u charge them they go up to 8.4 volts its damaging something in the reciver i had the same problem with my mrx4 and i confirmed this with airtronics they agreed and if u go back to nimh after u had the glitch its going to keep happening its too late u damaged the reciver get a new rec and use only the nimh like i did and been running fine ever since.. they and i dont know y this is happening only that the fully charged lipo or life even thou 6.6 or 6.0 volts when peaked is causing damage there only reccomendation is a 6.0 volt regulator.... oh and it wont happen first few times u run it slowly burning something out...also if u are running in hrs mode with out the special reciver made for hrs this will cause a glitch take it out of hrs mode
good luck
RALPH FORTUNATO
Old 10-17-2010, 12:14 AM   #822
I have solve the issue by taking out the rubber groumet, line inside the receiver box using some silver tape dremel a hole on the receiver box outside and move the antenna wire out of original place it suddenly work. Still using Life pack. Run well for almost 3 hours. Not sure what i did was correct by it work.
Old 10-17-2010, 09:02 AM   #823
kitracer's Avatar
Default solve using 4PKs with the new mini receiver
Solved my problem on the 4th attempt. Bought new 4PKS with the new mini receiver, run 60 laps today no problem.
So far at our track this is the only combo works 100%.
All Spektrum, some Sawna M11x have the same problem.
Car run great using standard setup , finally.
Old 10-17-2010, 04:58 PM   #824
GMartinez's Avatar
Trader Rating: 82 (100%+)
Im remember they had the same problem in off-road the receivers were getting hot for not getting any air & that's were the problem started from they just took a reamer & placed some holes & the problem stopped just a thought
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup
2014 Hosted Events Roar Paved Electric Nationals, IFMAR ISTC Worlds
2015 Roar Fuel On Road Nationals,U.S.World Nitro Cup Completed
2016 U.S. World Nitro Cup Dec 7th - Dec 11th
GMartinez is offline   Reply With Quote
Old 10-18-2010, 06:13 AM   #825
Send a message via MSN to PMSorber
Sounds to me that the receiver box is too much RF-closed, had this problem in the past with the ALU receiver box as well...
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 08:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 10:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 09:49 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
SEO by vBSEO 3.5.0
