Old 09-27-2010, 11:03 AM   #691
Originally Posted by alainchan View Post
change low friction belt
I am still waiting my 5 any suggestions about battery receiver pack and sevros?
tonyhalandri is offline   Reply With Quote
Old 09-27-2010, 12:04 PM   #692
BigC2007's Avatar
Originally Posted by TEAM BROOKLYN View Post
In answer to your question the mrx5 starts at $600 upto 750.00 for a prebuilt one from mike swauger.
Ralphie see you in the morning to test the mrx5 ! hope to take some video and have it posted here tomorrow night .
brooklynhobbies.com
team mugen northeast
nyrclive.com
Where can I find a or order a prebuilt one ?
BigC
1 Corinthians 1:18
For the message of the cross is foolishness to those who are perishing, but to us who are being saved it is the power of God.
BigC2007 is offline   Reply With Quote
Old 09-27-2010, 01:12 PM   #693
MugenDrew's Avatar
Trader Rating: 28 (100%+)
See that part in his signature that says www.brooklynhobbies.com , I'd try there.
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 09-27-2010, 02:03 PM   #694
BigC2007's Avatar
Ohhhhhhh I C the light now.
BigC
1 Corinthians 1:18
Old 09-27-2010, 09:11 PM   #695
Any suggestions about sevros&battery receiver for MRX5?
Old 09-27-2010, 09:14 PM   #696
mugenize1's Avatar
Can someone tell me what are the size of the pulleys are they the same as the 4X
mugenize1 is offline   Reply With Quote
Old 09-27-2010, 10:40 PM   #697
choisan's Avatar
the front way is the only one that can be shared from 4. depsite some have the same part# of pulley, the alu adaptors are different.
choisan is offline   Reply With Quote
Old 09-28-2010, 05:04 AM   #698
FF25510's Avatar
a must have mod / no touch
FF25510 is offline   Reply With Quote
Old 09-28-2010, 05:08 AM   #699
FF25510's Avatar
car before run
MUGEN SEIKI MRX5-img_3166.jpg   MUGEN SEIKI MRX5-img_3167.jpg   MUGEN SEIKI MRX5-img_3168.jpg   MUGEN SEIKI MRX5-img_3169.jpg
Old 09-28-2010, 05:22 AM   #700
FF25510's Avatar
car after 1/2L run
because i'm using an old shell (P909 from Vx) with the standard setup, the car feel easy to change diretions (with 25mm bumper to shell) then change front upper arm post to 5mm at the back, car feel very stable to drive next time will try 18/20mm bumper to shell. another thing was the two screws of the saver are easy to loose, must use t/l or wait for the alu one
Old 09-28-2010, 06:20 AM   #701
FF25510's Avatar
just check from the lap record, the fastest lap that i made compare to the old/new car was improve .3 sec i'm looking forward to the rest
Old 09-28-2010, 08:15 AM   #702
ralphierace13's Avatar
can u explain this must have ? mine dont touch no were near it y should i cut that out?
also some info ran car 2 days pretty hard anyscrew into aluminun use lock tight there coming loose
RALPH FORTUNATO
MUGEN SEIKI MRX6 TEAM DRIVER
Futaba 4PK-S-R, Novarossi Team Driver, CONTACT TIRES
Byron Fuel, Veytrex Desgin Labs
2014 R.O.A.R. REGION 1 CHAMPION!!
ralphierace13 is offline   Reply With Quote
Old 09-28-2010, 08:23 AM   #703
Phil Trotta's Avatar
Is it for the one piece low engine mount?
PHIL TROTTA
Phil Trotta is offline   Reply With Quote
Old 09-28-2010, 09:38 AM   #704
any suggestions for sevros and battery for the MRX5?
Old 09-28-2010, 10:33 AM   #705
Default servo saver
Another helpful hint i hope helps during the build . the servo saver /ackerman piece is adjustable , and if you move all the way up it will rub the one way pulley . If you dremel away the turnbuckle plastic end near where it passes the one way pulley you will be able to use the adjustment to it full potential .
Richard Siriano
Team Mugen Northeast
TEAM BROOKLYN is offline   Reply With Quote
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 07:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 09:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 08:49 AM
