Old 08-16-2010, 01:23 PM   #496
85000 yen ..!! Thats $ 996.00 89500 yen is $1048.90
I dont think that is going to be quite right, but it might be that expensive in Japan ??!!
I have seen Ralph Burch drive an RC car, It was an amazing thing to watch. So I joined his team and got the same car... XRAY and RC AMERICA
CFowler is offline   Reply With Quote
Old 08-16-2010, 04:05 PM   #497
Team Kamikaze's Avatar
Wow, wish we can sell it that high in the US but knowing you Chris, you'll buy 2 at that price
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 08-16-2010, 05:09 PM   #498
occ
Trader Rating: 15 (100%+)
I wouldn't read too much into that info. That is just the suggested retail price.
The price will be much lower then that.
occ is offline   Reply With Quote
Old 08-16-2010, 06:06 PM   #499
At that price I would have to take a half a kit .... Would ya sell me a half ??
Old 08-16-2010, 06:08 PM   #500
Seisick's Avatar
Price has been set for dealers, parts list
All set, have your LHS order as kits will begin shiiping one mont
From now! If anyone wants the parts list on pdf file
Pm me!
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 08-16-2010, 06:13 PM   #501
A half? anything for you Chris
Old 08-16-2010, 07:01 PM   #502
http://www.mugenseiki.com/images/mrx...artslist_e.pdf
Check it out .... it's getting closer
Old 08-17-2010, 12:25 AM   #503
kmichael's Avatar
kmichael is offline   Reply With Quote
Old 08-17-2010, 05:59 AM   #504
choisan's Avatar
thanks so much for the partlist. can someone kind enough tell me which pulleys can be used from the 4?
choisan is offline   Reply With Quote
Old 08-17-2010, 07:51 AM   #505
Seisick's Avatar
Option Parts P/N Description MRX5 Only
H2001 MRX5 Kit X
H2002 MRX5 Instruction Manual X
H2003 MRX5 Decal Sheet X
X H2004 MRX5 Metallic Decal Sheet X
H2101L Front Upper Bulkhead Left: MRX5 X
H2101R Front Upper Bulkhead Right: MRX5 X
H2102 Front Lower Bulkhead: MRX5 X
H2103 Rear Lower Bulkhead: MRX5 X
H2104L Rear Upper Bulkhead Left: MRX5 X
H2104R Rear Upper Bulkhead Right: MRX5 X
H2105 Front Lower Arm Hinge Pin (2pcs): MRX5 X
H2106 Front Upper Arm Hinge Pin (2pcs): MRX5 X
H2107 Middle Shaft Bracket: MRX5 X
H2108 Rear Lower Arm Mount "A": MRX5 X
H2109 Rear Lower Arm Mount "B": MRX5 X
H2110 2-Speed Shaft Bracket: MRX5 X
H2111 Front Graphite Upright Upper Plate "A" (2pcs): MRX5 X
H2112 Front Graphite Upright Arm: MRX5 X
H2113 Rear Graphite Upper Arm Holder "A" (2pcs): MRX5 X
H2114 Rear Graphite Upper Arm Holder "B": MRX5 X
H2115 Rear Graphite Lower Damper Stay (1pc): MRX5 X
H2116 Anti-Roll Bar Stopper (2pcs): MRX5 X
H2117 Rear Anti-Roll Bar 3mm: MRX5 X
H2118 Front Lower/Upper Sus. Arm Set (1ea): MRX5 X
H2121 Front Upright Right or Left (1pc): MRX5 X
H2122 Rear Lower/Upper Sus. Arm Set (1ea): MRX5 X
H2124 Rear Upright Right or Left (1pc): MRX5 X
H2125 Eccentric Hub: MRX5 X
H2127 Servo Saver Arm Set: MRX5 X
X H2128 Front Graphite Upright Set (2pcs): MRX5 X
X H2129 Rear Graphite Upright Set (2pcs): MRX5 X
X H2130 Front Graphite Upright Upper Plate "B" (2pcs): MRX5 X
X H2131 Front Graphite Upright Upper Plate "C" (2pcs): MRX5 X
H2133 Front Lower Damper Mount (2pcs): MRX5 X
H2201 Pulley Set: MRX5 X
H2203 Middle Pulley Shaft: MRX5 X
H2204 Pulley Spacer: MRX5 X
H2206 Pulley Adapter for Rear: MRX5 X
H2207 Pulley Adapter for Side: MRX5 X
H2208 2-Speed Adapter: MRX5 X
H2209 Rear Solid Axle: MRX5 X
MRX5 Retail Parts List
Last updated 8/4/2010
Mugen Seiki Racing ~ 949-707-5607, Fax 949-707-5614
H2210 2-Speed Shaft: MRX5 X
H2211 Front Belt: MRX5 X
H2212 Pulley Holder: MRX5 X
H2213 Inner Drive Joint (2pcs): MRX5 X
H2214 Side Belt: MRX5 X
H2301 Graphite Radio Tray: MRX5 X
H2302 Graphite Brake Bracket: MRX5 X
H2303 Brake Cam: MRX5 X
H2304 Brake Return Spring Set: MRX5 X
H2305 Brake Pad (2pcs): MRX5 X
H2308 Brake Disc: MRX5 X
H2310 Radio Plate Flex Mount: MRX5 X
H2311 Radio Box: MRX5 X
H2313 Battery Plate: MRX5 X
H2314 Servo Saver Pipe: MRX5 X
X H2315 Battery Plate Graphite: MRX5 X
H2401 Chassis: MRX5 X
H2402 Front Bumper: MRX5 X
X H2404 Weight "A" (20g): MRX5 X
X H2405 Weight "B" (20g): MRX5 X
H2406 Alum. Front Body Mount (2pcs): MRX5 X
X H2407 Weight "C" (20g): MRX5 X
H2408 Rear Graphite Body Mount Centering Plate: MRX5 X
X H2409 Weight "D" (10g): MRX5 X
H2501 Front Graphite Damper Stay: MRX5 X
H2502 Rear Graphite Damper Stay: MRX5 X
H2602 Bearing 8x14x4 (2pcs): MRX5 X
H2603 Bearing 3x6 Flange (2pcs): MRX5 X
H2801 Fuel Tank: MRX5 X
H2802 Fuel Tank Mount: MRX5 X
H2804 Linkage Parts: MRX5 X
H2806 Turnbuckle Rod 18mm (2pcs): MRX5 X
D0104R Rear Lower Sus. Shaft (2pcs)
J0105U Rear Upper Sus. Shaft (2pcs)
D0105R King Pin (2pcs)
H0107/1 Front Stabilizer Bar (2pcs)
H0142B Radio Tray Mount: MRX5 X
H0144 King Pin Ball Cup
H0145 Adjusting Nut for Front Upright (2pcs)
H0164 Roll Bar
H0180 Rear Upright Ball (2pcs)
X H0181A 3mm Roll Center Spacer .5mm (20pcs)
H0181B 3mm Roll Center Spacer 1mm (20pcs)
X H0181C 3mm Roll Center Spacer 2mm (20pcs)
H0181D 3mm Roll Center Spacer 3mm (20pcs)
X H0187 Titanuim King Pin Ball (2pcs)
X H0187/1 Titanuim King Pin Ball (8pcs)
H0222 Rear Axle Shaft
H0240 Rear Belt
H0252 Front One Way Drive Shaft
H0268 Axle Washer (4pcs)
H0270 Front Universal Joint Set
H0271 Front Axle Shaft (2pcs)
H0272 Front Drive Shaft (2pcs)
H0273 Joint Shaft (2pcs)
H0274 Roller Pin 2.5x11.8 (10pcs)
H0275 Front Wheel Changing Lever
X H0277 Rear Axle Shaft (2pcs)
H0279 Rear Whell Changing Lever
X H0281 1st Gear 48T
H0282 1st Gear 49T
H0283 1st Gear 50T
X H0284 2nd Gear 45T
H0285 2nd Gear 46T
X H0286 2nd Gear 47T
H0287 Shoe for 2 Speed Gear Box
H0288 1st Gear Housing
H0289 2nd Gear Housing
H0291 Rear Drive Shaft (2pcs)
H0292 Graphite Belt Tensioner Plate
H0293 Belt Tensioner Shaft
H0295 Spring Set for 2 Speed Gear Box
X H0296 Rear Universal Joint Set
X H0297 Rear Drive Shaft for Universal (2pcs)
T0305 Servo Saver Shaft
T0307 Servo Saver Spring Adjuster
T0308 Servo Saver Spring
H0466C Rear Body Mount:MRX5 X
H0468 Rear Body Mount Centering Shaft
H0469 Rear Body Mount Arm Shaft (2pcs)
H0470 Rear Body Mount Arm Stopper
H0471 Rear Body Mount Arm Pin (4pcs)
D0506 Damper Shaft (2pcs)
E0322 Radio Box Grommet
D0508 Diaphragm (8pcs)
D0509 Damper O-Ring Set
H0510 Damper Piston (4pcs)
X H0511 Front Spring 1.9 Black (2pcs)
H0513 Spring Adjuster (2pcs)
X H0515 Front Spring Yellow (2pcs)
X H0516 Front Spring 2.0 Blue (2pcs)
X H0525 Front Spring 1.8 Gray (2pcs)
H0526 Front Spring 1.9 White (2pcs)
X H0529 Rear Spring 1.8 Gray (2pcs)
H0530 Rear Spring 1.9 White (2pcs)
X H0531 Rear Spring 2.0 Pink (2pcs)
X H0532 Rear Spring 2.0 Red (2pcs)
H0554 Damper Cap (2pcs)
X H0558 1.2mm Damper Pistons (2pcs)
X H0559 1.3mm Damper Pistons (2pcs)
H0562 Damper Case (2pcs)
H0563 Oil Seal Cap (2pcs)
H0570 Damper Set F/R (1pr)
H0571 Damper Parts
H0601 Bearing 12x18x4 (2pcs)
H0601/1 Bearing 12x18x4 (10pcs) X
C0602/1 Bearing 5x8 (2pcs)
C0603 Bearing 5x10 (2pcs)
D0603 Thrust Bearing
H0603 Bearing 5x10 Flanged (2pcs)
K0603 Bearing 10x15x4 (2pcs)
K0603/1 Bearing 10x15x4 (10pcs)
H0608 Bearing 15x10 (2pcs)
C0702B Flywheel Taper Cone
H0704 Engine Nut
C0723 Engine Mount Screws w/Cone Washer
H0753 Spring Cup
H0755 Spring Adjusting Nut
H0756 Stopper for Bearing
H0757 1st Gear 16T
X H0758 1st Gear 17T
X H0759 1st Gear 18T
X H0760 2nd Gear 19T
H0761 2nd Gear 20T
X H0762 2nd Gear 21T
H0767 Clutch Spring Super Hard
X MSR1001 Clutch Spring Hard
H0770 Engine Mount
H0772 Alum One Piece Engine Mount
H0775 Centrifical Shoe
H0776 Alum Pressure Plate
H0777 Clutch Bell
H0778 Flywheel
H0779 Clutch Shoe Yellow
H0780 Clutch Set
H0801A Steering Tie Rod (2pcs)
D0806 Antenna Tube (2pcs)
D0807 Body Pins 1/8 (8pcs)
E0829 Anti-Roll Bar Link (4pcs)
H0854 Roller Pin Set
H0855 Ball Link 6mm (10pcs)
H0857 Turnbuckle Tie Rod 22mm (2pcs)
H0858 Ball Link 6mm S (10pcs)
X H0862 Titanium Steering Tie Rod (2pcs)
X H0862 Titanium Turnbuckle Tie Rod (2pcs)
H0864 Fuel Tank Cap
H0867 Pivot Ball (4pcs)
C0901 Muffler Stay
X H0901 Manifold Spring (2pcs)
H0952 Wire For Muffler
X H1006 Rear Spoiler Adjusting Screw w/Nuts (2ea)
X H1009 1/8 Body Stiffener Set
X H1010 Rear Spoiler Set 1/8
X H1011 Rear Spoiler 1/8
X P0218 Sticker Flag & Flame
X P0401 Mugen Logo Sheet
X B0010 "Airbooster" Air Filter Set
X B0011 "Airbooster" Air Filter Foam
X B0113 Air Filter .21 On Road (Foam)
X B0115 Mugen Fuel Bottle
X B0116 Pressure Chamber Set
X B0117 Pressure Chamber Mount
X B0220 Pro Starter Box RII
X B0242 Power Pack 1500 Flat w/Futuba
X B0243 Power Pack 1500 Flat w/Airtronics
X B0241/1 Glow Plus Starter (w/Battery)
X B0301 Liquid Locktite
X B0303 Engine Maintenance Oil
X B0316 Super Silicone #400
X B0329 New Air Filter Oil
X B0330 Super Joint Grease
X B0407 Flat Washer 3mm (15pcs)
X B0408 Flat Washer 4mm (15pcs)
X B0413 Color Silicone Pipe (Gray)
X B0422 Body Pin S (8pcs)
X B0424 Carb Cap (4pcs)
X B0429 Alum. Servo Horn Set
X B0506 Snap Ring Pliers
X B0509 Setting Driver for Engine
X B0510 Camber Gauge
X B0514 Clutch Spring Adjusting Tool
X B0519 Prospec Phillips #2 Screw Driver
X B0519/1 Spare Tip for (+) #2 Screw Driver
X B0520 Prospec Phillips #1 Screw Driver
X B0520/1 Spare Tip for (+) #1 Screw Driver
X B0521 Prospec Straight 1.0 Screw Driver
X B0521/1 Spare Tip for (-) 1.0 Screw Driver
X B0522 Prospec Straight .5 Screw Driver
X B0522/1 Spare Tip for (-) .5 Screw Driver
X B0523 Prospec 1.5mm Hex Wrench
X B0523/1 Spare Tip for 1.5mm Hex Wrench
X B0524 Prospec 2.0mm Hex Wrench
X B0524/1 Spare Tip for 2.0mm Hex Wrench
X B0525 Prospec 2.5mm Hex Wrench
X B0525/1 Spare Tip for 2.5mm Hex Wrench
X B0526 Prospec 3.0mm Hex Wrench
X B0526/1 Spare Tip for 3.0mm Hex Wrench
X B0527 Prospec 2.0mm Ball Hex Wrench
X B0527/1 Spare Tip for 2.0mm Ball Hex Wrench
X B0528 Prospec 2.5mm Ball Hex Wrench
X B0528/1 Spare Tip for 2.5mm Hex Wrench
X B0529 Prospec Tool Set (10pcs)
X B0530 2.0mm Hex Wrench Tip
X B0531 2.5mm Hex Wrench Tip
X B0532 Pinion Gear Tool (1/10 & 1/8 Gears)
X B0533 Curved Scissors
X B0534 Height Guage R
X B0535 MSR Nut Driver 5.5mm
X B0536 MSR Nut Driver 7.0mm
X B0537 MSR Nut Driver 5.0mm
HobbymaniA
GoT MuGeN?
Old 08-17-2010, 08:29 AM   #506
choisan's Avatar
wonder if you can post the instruction manual. thanks!
Old 08-17-2010, 08:43 AM   #507
Roelof's Avatar
Send a message via ICQ to Roelof
If there was a known real price I think all shops would have started pre-orders. Beside that, do not forget that Japan and China have the best economics which is a factor in determing the price.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 08-17-2010, 10:59 AM   #508
Seisick's Avatar
IM SORRY NO MANUAL YET TO DOWNLOAD, MUGENSEKI.COM WILL HAVE IT SHORTLY,
FIRST PRODUCTION KITS WILL COME WITH OPTIONAL METALLIC DECALS, A $12.99 RETAIL VALUE FOR FREE
HobbymaniA
GoT MuGeN?
Old 08-17-2010, 01:12 PM   #509
I have no idea about China ... But japan is like New York city ... it is very expensive to live there
Old 08-17-2010, 04:52 PM   #510
It is Coming Very Soon!
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 07:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 09:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 08:49 AM
