Old 08-04-2014, 10:31 PM   #2806
nitrodash's Avatar
Default Easy fix
If anybody has had the rod ends break up front try this it seem to work for me. Bust out a 5x8 bearing and use the outer race as a sleeve to support the rod ends. I also use a longer turnbuckle 3x26 OFN19454. The bearing race fits the rod end snug and does not make anything bind.
Dash Hobbies 1039 E. Hunting Park Ave Phila,PA.19124
215-278-9868
dashhobbies.com
facebook.com/Dashhobbies/shop
nitrodash is offline   Reply With Quote
Old 08-07-2014, 04:27 AM   #2807
Roberto168's Avatar
Originally Posted by choisan View Post
Can someone feel the same to me that the belts and pulleys are the most consumed parts. The belts are torn exceptionally more easier than the 4.
I have replaced many times more than the years with 4.
Hope the future car improves
I ran 1 set of belts for 1 whole year in my MRX5. But I ran Capricorn plastic cream coloured pulleys(just the 4 small ones) and standard Mugen belts.(not rubber). I also applied oil to the belts before each race meeting (300 weight shock oil). The belts and pulleys still look good, but I just replaced them as a precaution. I think the belts also have to be correctly tensioned and not tensioned too tight. I only ran the belts for that long just to see how long they would last. It's always best to change belts before any big race meet.
ARC 8.0, Team C GT8, serpent 747
Mx Sim, VRC Pro, Realflight, www.nswrcrcc.com
Roberto168 is offline   Reply With Quote
Old 08-07-2014, 06:32 AM   #2808
choisan's Avatar
Thanks Robert, will check out the Capricorn's cream pulleys.
The 6 probably will move the brake back to the 2 speed shaft, same as the mtx6
choisan is offline   Reply With Quote
Old 08-07-2014, 07:50 AM   #2809
Roelof's Avatar
Send a message via ICQ to Roelof
With what reason?
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 08-07-2014, 06:07 PM   #2810
choisan's Avatar
Only personal speculation, cross platform standardization, and marketing strategy.
If it hasn't had any to change or modify, how will there a new 6?
General statement
Old 09-02-2014, 07:14 PM   #2811
GMartinez's Avatar
Trader Rating: 82 (100%+)
I hope not there was no problem with the mrx5
I know there were issues with the mtx5 and the move was good for the mtx6
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup
2014 Hosted Events Roar Paved Electric Nationals, IFMAR ISTC Worlds
2015 Roar Fuel On Road Nationals,U.S.World Nitro Cup Completed
2016 U.S. World Nitro Cup Dec 7th - Dec 11th
GMartinez is offline   Reply With Quote
Old 10-02-2014, 01:36 AM   #2812
Smile Bearings
Hello everybody!
I was wondering what bearing are you guys using on your MRX5 or MRX5 WC cars?
I use the Mugen Seiki H0601 12X18X4, but they last no longer than a race or two.I understand that a bearing cannot last forever, but 1 race per a set of bearings of 35 bucks is a little annoying .So I would be very thankful to hear what bearing are you using and how long do they last approximately.
Thanks!
Koceto1999 is offline   Reply With Quote
Old 10-02-2014, 08:15 AM   #2813
Roelof's Avatar
No issues after 1 season of racing. Only after the 1st wet race one of the front oneway shaft did go heavy. After a vibration bath with WD40 no problems!
Old 10-06-2014, 09:52 AM   #2814
NITRO 540's Avatar
Trader Rating: 10 (92%+)
Default Looking to purchase
Does anyone have a good used or new prebuilt MRX 5 forsale?
I am also interested in a RTR. These are hard to find. Pm me
Tekno EB 48.3 NB48.3 NT48.3
Team Driver: ProLine, The Nitro shop, M2C racing
NITRO 540 is offline   Reply With Quote
Old 10-11-2014, 03:57 AM   #2815
Trader Rating: 54 (100%+)
There were a few on ebay. There is a reason these are hard to find
Jamison R is offline   Reply With Quote
Old 10-14-2014, 09:05 AM   #2816
NITRO 540's Avatar
I picked up a car from Ralph in New York.
Looking forward to the Halloween Race at Debbie's Rc.
Old 10-23-2014, 02:32 PM   #2817
SMcpot's Avatar
Trader Rating: 22 (100%+)
Why does it seem like none of the European or Japanese team drivers use the aluminum front upper arm mounts? Also, has anyone tried the MLC (Collari) front body supports and tire additive?
SMcpot is offline   Reply With Quote
Old 10-23-2014, 02:42 PM   #2818
Roelof's Avatar
It is an easy to change break point. Aluminium is to solid and will a crash make more and time consuming damage.
I run the plastic as well and needed to change one after a crash.
Old 10-23-2014, 04:12 PM   #2819
with alu front upper arm i noticed less mid-corner steering, so i prefer plastic one...
I also use MLC front body support and they work great with Protoform r 18 and p909 either... you can cut less the front of the bodies and it doesn't touch the ground either with very small tyres... give it a try i also noticed a litttle bit less "floating" on straights... but maybe it is only my impression... Ciao ciao
Nicoḷ Pasqualini (Italy)
Mugen Mrx5 wc- Os Engine - Matrix Tyres- MLC Fuel- Protoform
pasqua2291 is offline   Reply With Quote
Old 10-24-2014, 12:59 AM   #2820
SMcpot's Avatar
Thanks for the input, Nicolo and Roelof. I guess I'll try the plastic mounts as a tuning aid. And I've placed an order for the body supports and additive.
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 08:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 10:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 09:49 AM
SEO by vBSEO 3.5.0
