Old 12-02-2013, 12:15 PM   #2731
Send a message via MSN to Gianni Giorgio Send a message via Skype™ to Gianni Giorgio
Break in done !!! Feels goods the new engine Picco !!! Ready for star the race at kissimme orlando
Nitro world cup 2013 !!!!
Mugen Racing/Matrix tires /Mikedesigns/VP fuel
Gianni Giorgio is offline   Reply With Quote
Old 12-09-2013, 08:02 PM   #2732
Hello, im looking for mrx5 wc. Please pm if anyone is selling. Thanks
RGKL is offline   Reply With Quote
Old 01-06-2014, 09:49 PM   #2733
Ready for next weekend !! Florida state race At homestead track !!!
See there guys
Ciao
Old 01-07-2014, 10:48 AM   #2734
Hi Gianni,
It seem that you are not using the original front upper link. Cloud you please explain, what part you are using or post a picture?
Thanks.
kapa is offline   Reply With Quote
Old 01-07-2014, 11:27 AM   #2735
Ciao
I put back the mrx4 arms !!! I need testing at fort myers for the winternats 2014 !!! Maybe its more strong for this track
Bye
Old 01-07-2014, 12:42 PM   #2736
Hi Gianni,
Thanks for the quick reply. I actually did the same during last summer. I use the MRX 4 link and the H0139-B Front Upright. For me as a “just for fun” driver, I could not feel any difference when driving the car. Since then I did not break anything, even in the German Winter on an indoor track, which is not really forgiving …
I also like that I now can use bigger bearings in the front upright, because they seem to last much longer.
Karsten
Old 01-07-2014, 01:26 PM   #2737
Ahh perfect !!! Are you coming to winternats at fort myer in february?
Old 01-07-2014, 06:29 PM   #2738
As I live in Germany ... I will not attend.
Old 01-07-2014, 06:34 PM   #2739
Ok !!!
Old 01-24-2014, 05:07 AM   #2740
ruicortez's Avatar
Default Rear tires don't fit
I am having a problem with rear tires.
I have Enneti tires and cannot fit them to my MRX5. When inserting the rear tire it doesn't reach the tip and the lever (H0279) doesn't close.
Am I the only one having this problem? Can anyone help?
Regards
ruicortez is offline   Reply With Quote
Old 01-24-2014, 09:04 AM   #2741
walo's Avatar
Send a message via Yahoo to walo
Regards
Often the small things are overlooked. Check the pin in the center of the axle. Make sure it's centered and tightened with the set screw. Make sure the rim slides all the way on the axle, the tip of the axle should show. If the quick release lever does not slide up to lock the wheel in place, you may have to add some pressure. This isn't a problem with the car, but some tire manufactures rims don't always fit perfectly. As a quick fix, simply remove a little material from the center of the rim where the quick release lever rest. This should solve the problem with any tire(rim) you use. .
walo is offline   Reply With Quote
Old 01-24-2014, 09:31 AM   #2742
ruicortez's Avatar
Thank you. I have already checked everything. Then, I guess I'll have to trim near 100 enneti rims...
Old 01-24-2014, 11:45 AM   #2743
Roelof's Avatar
Send a message via ICQ to Roelof
Sometimes you just have to give a smack on the wheel to give that extra push.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 01-24-2014, 03:04 PM   #2744
ruicortez's Avatar
Roelof, it would have to be a "hammer push"
The lever is like 2mm away from closing.
Old 01-24-2014, 07:16 PM   #2745
choisan's Avatar
Did you realm the wheel a little bit, just a little bit, to make it easier to go in
choisan is offline   Reply With Quote
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 08:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 10:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 09:49 AM
SEO by vBSEO 3.5.0
