Old 07-10-2013, 05:25 AM   #2656
Arahawak's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Snowy View Post
One heat per Clutch Bell and Shoe???
Lucky you Singapore guys can afford to replace them every heat.
Not me manz... well maybe 1 per heat is too much but 1 per 2 - 3 rounds more likely.
I see the ones that Yurugi san was using in Jakarta.. he changed them every round.
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 07-10-2013, 11:16 PM   #2657
Originally Posted by mrlahey View Post
Is the new H2410 High Traction Chassis, made for high traction tracks or to give the car more traction on low grip tracks?
Anyone?
mrlahey is offline   Reply With Quote
Old 07-11-2013, 07:06 AM   #2658
Anyone?
It is for high traction track...
Mtx6,Reds WCS,Protoform,kopropo,contact tires.
tonyhalandri is offline   Reply With Quote
Old 07-12-2013, 07:01 PM   #2659
ltrdude's Avatar
Trader Rating: 29 (100%+)
Default clutch shoe
can someone post the part# for the black clutch shoe for the worlds clutch
ltrdude is offline   Reply With Quote
Old 07-12-2013, 07:03 PM   #2660
rcmike's Avatar
Trader Rating: 40 (100%+)
H2708.
See avatar, You have never Experienced FUN till you ride Motocross. Sponsors include Dunlop tires, FX graphics, Rad mfg and TH-R...
rcmike is offline   Reply With Quote
Old 07-14-2013, 11:30 AM   #2661
Anyone?
Are you sure? So this chassis wont work as good as the standard chassis under most conditions?!
Best wishes
Olli
OliverT is offline   Reply With Quote
Old 07-14-2013, 02:00 PM   #2662
The new chassis is 1mm thicker, making it less flexable then the other one. The car is more stable, but has a bit less steering.
T.O.P. REBEL 12 - Mugen MRX 5 - sponsered by www.bdr-shop.com
lenaers is offline   Reply With Quote
Old 07-14-2013, 11:33 PM   #2663
sm4100's Avatar
Send a message via Skype™ to sm4100
I doubt any locking brake system can be more efficient than ABS. if some people don't know how to adjust or setup then it is different story. (little or nothing is found on how to properly setup ABS on RC cars)
If you don't set an ABS properly it will for sure behave worse than a locking brake.
When you say: 'other looses the feeling in the brake as he has no control over it' .
It obviosuly sounds like he doesn't know how to adjust the brakes. I find it impossible not to feel or loose control over it. ABS will not provent you from skidding, crashing or flying off the corner but will just give you a much more consistent and balanced braking power in shorter distances.
If you talk about driving style I understand, some people like a more agressive feeling of the locking brake but not true saying a better braking power.
sm4100 is offline   Reply With Quote
Old 07-15-2013, 09:51 PM   #2664
sm4100's Avatar
Originally Posted by Lil Paul View Post
ABS can be a useful tool, but like previously mentioned be very mindful that it does put an extra strain on your servos. Not going to steer you away from using it, because we all are willing to do anything to shave even .000001 off our lap times...
That's what Im talking about,
Where I live it is always raining so the track is always humid or wet in some parts, there is no way to go without ABS and as you said it will definitely shave some time off your lap and that's all we want.
Although I have burnt few servos using ABS the fastest Sanwas and Ko Propos will survive very long time, specially with Ko Propos for an extra long life just change the A gear (fuse gear) from original plastic to metal and forget it.
Old 07-15-2013, 09:54 PM   #2665
sm4100's Avatar
Originally Posted by mhavlena View Post
How does one activate ABS during braking? with a separate pushbutton? or can this be tacked on the the brake lever?
Usually the function can be activated with any programmable button on your Tx, I use Airtronics M11 and M12 and both are fully adjustable in the way they are applied and can be switched on and off anytime during racing. I am sure Futabas are the same way.
Most Tx's don't have ABS though
Old 07-15-2013, 09:58 PM   #2666
sm4100's Avatar
Originally Posted by walo View Post
A.B.S is a pre-set feature in most radios, just apply the brakes and it will activate.
Not true... most radios dont have ABS at least the budget ones dont
I ve never seen a TX with pre-set ABS, you always have to switch on and off.
For off road for instance you dont wanna have ABS so the Tx could not come with pre-set ABS, even the cheapest Tx with ABS I know of from Hobby King you can switch on and off any time
Old 07-16-2013, 02:15 AM   #2667
Can you share how to setup the ABS settings in M11x??? i.e. what is your setting???
Thanks.
hobbs is offline   Reply With Quote
Old 07-16-2013, 07:27 AM   #2668
sm4100's Avatar
Everything starts with the mechanical adjust of your brake, so make sure the car is breaking strong and even locking when you apply full brake at high speed, with this done go to the transmitter and adjust:
1. Point 90%
2. Stroke 80%
3. Lag 0.0 sec
4. Speed -3
If your track is cold or wet try Speed -4 or -5
If the car is still locking the wheels decrease the 1. Point
If the car is braking in long distance increase 2. Stroke and a little bit 1. Point
Keep trying something around the 1 and 2 but don't go too far from -3 to -5 in the point 4. Speed
Old 07-17-2013, 08:52 AM   #2669
cho~ke's Avatar
Default Nationals
R&D = rebuild & destroy
Jimmy Cho
cho~ke is offline   Reply With Quote
Old 07-22-2013, 01:44 PM   #2670
Is there a 15 tooth pinion gear that fits the Marx clutch bell? Say a serpent gear maybe. Thanks
Brett Adams
Mugen MGT7
o.s. savox futaba
66 Box Nova all motor LSX
1966ss is offline   Reply With Quote
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 07:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 09:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 08:49 AM
