Old 06-08-2013, 08:03 AM   #2641
Lil Paul's Avatar
Exclamation Procees with Caution
ABS can be a useful tool, but like previously mentioned be very mindful that it does put an extra strain on your servos. Not going to steer you away from using it, because we all are willing to do anything to shave even .000001 off our lap times...
Lil Paul is offline   Reply With Quote
Old 06-08-2013, 09:41 PM   #2642
Originally Posted by sm4100 View Post
A well adjusted A.B.S is all you need, it can brake any 1/8 with easy you just need:
1. A strong and faaaaast servo, slow servo does not get the job done and will overheat
2. If you can adjust the ABS point on your transmitter try these:
a. Adjust your mechanical brake until it starts to lock the wheels at the end of a straight full speed than jam break
b. Switch on the ABS or ALB depending on your transmitter
c. Adjust the stroke to 70%
d. Brake point to 85%
e. Release 0.04 s
f.Hold 0.04 s
g. Lag 0.00 s
The whole brake system is std on my MRX5 but the break power with ABS is amazing
All starts on your servo speed and the best and strongest I have tried so far for ABS purposes is KO Propo, many others will burn soon with above setup.
How does one activate ABS during braking? with a separate pushbutton? or can this be tacked on the the brake lever?
mhavlena is offline   Reply With Quote
Old 06-08-2013, 09:46 PM   #2643
walo's Avatar
Send a message via Yahoo to walo
A.B.S is a pre-set feature in most radios, just apply the brakes and it will activate.
walo is offline   Reply With Quote
Old 06-20-2013, 06:07 AM   #2644
hyder's Avatar
Does anyone have problem putting in the clutch spring and tighten it up? I find it very hard to push down the clutch spring and tighten up with the clutch spring nut..
How did you guys manage to do it?
hyder is offline   Reply With Quote
Old 06-20-2013, 06:55 AM   #2645
Check your flyweights.maybe its the opposite.
Btw hyder,its me taufiqh frm SP.
tq23 is offline   Reply With Quote
Old 06-20-2013, 07:42 AM   #2646
walo's Avatar
If you're using the w.c clutch, the spring is a harder spring. Make sure everything sit level and apply a little pressure to catch the threads.
Old 06-20-2013, 08:11 AM   #2647
hyder's Avatar
Yes, I'm using the wc clutch. The hard thing is getting that pressure just enough for the nut to thread. . I think I need to get the clutch spring tool to get this done...
Old 06-20-2013, 09:07 AM   #2648
The WC spring is little bit lean on one side, if insert the spring is not smooth with the nut, try the other direction and make sure the spring is smooth to release.
GP: Capricorn C03 1/10 touring, Capricorn C803 1/8 onroad
Engine: Tesla .12 WC, Tesla .21 7 port on-road, Rody VS02, OS 2101
beebone is offline   Reply With Quote
Old 06-29-2013, 04:52 AM   #2649
JJ's latest MRX5 setup sheet from the 2013 Byron Nitro Challenge
http://www.jjwangracing.com/setup-sheets-nitro/
rwang is offline   Reply With Quote
Old 06-29-2013, 06:45 AM   #2650
Anyone is running the alum clutch bell and black shoe care to comment?
I see all the team drivers are using them..
Patrick_Head is offline   Reply With Quote
Old 07-02-2013, 09:31 AM   #2651
Arahawak's Avatar
Trader Rating: 32 (100%+)
Super but its a heat per bell and shoe.
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 07-02-2013, 09:34 PM   #2652
Super Moderator
Snowy's Avatar
Trader Rating: 14 (100%+)
One heat per Clutch Bell and Shoe???
Lucky you Singapore guys can afford to replace them every heat.
Racing Lines Magazine
Snowy is offline   Reply With Quote
Old 07-06-2013, 10:32 AM   #2653
I am building an MRX5 WC and I noticed that there is no spot to mount a receiver switch. Does that sound right? If so, how are you turning your electronics on and off?
rossb is offline   Reply With Quote
Old 07-06-2013, 11:34 AM   #2654
nitrodash's Avatar
[QUOTE=rossb;12322489]I am building an MRX5 WC and I noticed that there is no spot to mount a receiver switch. Does that sound right? If so, how are you turning your electronics on and off?[/QUOTE
I mounted a switch in the small opening on the transponder mount using Futaba mini switch SWH15 it fits there perfect you will also need Ofna servo mounting hardware 34026 to extend the transponder mount out slightly so the switch does not hit the steering servo and two 3mm button head screws. I opened up one of the slots on the radio tray slighty with a dremel tool to have the wire routed neatly. Its very easy to do and works great never had any issue after many races.
Dash Hobbies 1039 E. Hunting Park Ave Phila,PA.19124
215-278-9868
dashhobbies.com
facebook.com/Dashhobbies/shop
nitrodash is offline   Reply With Quote
Old 07-10-2013, 04:23 AM   #2655
Is the new H2410 High Traction Chassis, made for high traction tracks or to give the car more traction on low grip tracks?
mrlahey is offline   Reply With Quote
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 07:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 09:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 08:49 AM
