Old 05-20-2013, 06:59 AM   #2611
choisan's Avatar
but can't confirm if hara is racing this year, as his name is not with the approved representative list from japan, he or masami needs to win from the pre-world to get the seat for japan
choisan is offline   Reply With Quote
Old 05-24-2013, 02:28 AM   #2612
Default conversion kit?
Hey guys,are Mugen going to come out with a conversion kit for the WC spec? Or its just gonna be the kit alone?
tq23 is offline   Reply With Quote
Old 05-24-2013, 02:45 AM   #2613
Super Moderator
Snowy's Avatar
Trader Rating: 14 (100%+)
Probably no upgrade kit, just the kit alone. Download the "New Parts for MRX5 WC-SPEC" PDF file from the Mugen website for the part numbers.
Racing Lines Magazine
Snowy is offline   Reply With Quote
Old 05-24-2013, 03:51 AM   #2614
Masami is in track, but is only an helper of the organizations....
Results later 2 heat
w.facebook.com/anto.canta?ref=tn_tnmn#!/photo.php?fbid=424444250996836&set=a.1401985227547 45.30909.100002937950450&type=1&theater[/url]
toto is offline   Reply With Quote
Old 05-24-2013, 06:53 AM   #2615
choisan's Avatar
disappointed that masami is not racing, neither hara
Old 05-24-2013, 09:56 AM   #2616
Thks snowy!
Old 05-27-2013, 08:52 AM   #2617
SRAD's Avatar
Are any of the parts of the old car usable?
SRAD is offline   Reply With Quote
Old 05-27-2013, 05:00 PM   #2618
Pooh2's Avatar
Send a message via MSN to Pooh2
Everything other than the front lower arms.
MUGEN MRX5/CONTACT TIRES/DESOTO RACING/TEAM LOGIC
"Since the Bible and the church are obviously mistaken in telling us where we came from, how can we trust them to tell us where we are going"?
Pooh2 is offline   Reply With Quote
Old 05-30-2013, 02:29 AM   #2619
What is the difference between old and new rear arm mounts?
Patrick_Head is offline   Reply With Quote
Old 05-30-2013, 04:14 AM   #2620
Arahawak's Avatar
Trader Rating: 32 (100%+)
Yeah, i suppose you could order the parts separately.
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 05-30-2013, 05:30 AM   #2621
walo's Avatar
Send a message via Yahoo to walo
If you are referring to the rear lower roll center mount, it's just stronger (thicker).
walo is offline   Reply With Quote
Old 05-30-2013, 01:18 PM   #2622
brothainchrist0's Avatar
Trader Rating: 145 (100%+)
Hey guys, i'm having some issues with my mrx5. I need more braking before the turns and at the end of the straight. In my 10th scale I put a front diff in the car and it added so much braking but I was told there is no front diff for the mrx5? I have my brakes set as harsh as I can get them without it spinning out and its definitely not enough. It spins out real easy if I jam on the brakes any more than I have it set right now. What do u guys suggest?
Thanks!
Kyle
Mugen MRX5 - Ielasi Modified Engines/Matrix Tires/Savox Servos/Airtronics Radio
IGT Hobbies - The one stop shop for anything on-road and incredible customer service.
brothainchrist0 is offline   Reply With Quote
Old 05-30-2013, 03:37 PM   #2623
wingracer's Avatar
Trader Rating: 23 (100%+)
Thanks!
Kyle
Learn to drive it, that's all you're going to get. Front brakes are actually illegal in this class.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is online now   Reply With Quote
Old 05-30-2013, 03:51 PM   #2624
ok ok good point. i do need more practice with it. i guess i just thought everybody else was able to hit their brakes and I wasnt so i'll just keep driving i guess. thanks!
Kyle
Old 05-30-2013, 04:07 PM   #2625
wingracer's Avatar
Kyle
I did just think of a couple pointers that might help though.
1. You can use more brake at high speed than at low speed so you can try setting it as high as it can go for the end of the straight and then using either no brakes or just a very quick stab of brake for the rest of the track. I do this at some tracks.
2. High bite you can use more brake, but of course you don't need as much then.
3. More rear downforce can allow more brake to be used but will make the car push in fast sweepers. Works well on tracks that don't have sweepers.
4. I often start a long main with a touch too much brakes and use it very carefully since they usually fade a bit over the run. I also keep my radio on the brake endpoint menu so during pit stops I can add a click or two as needed.
Team Shepherd USA
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 07:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 09:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 08:49 AM
