Old 04-05-2013, 06:13 AM   #2566
choisan's Avatar
Please kindly help to correct if there is any wrong interpretation from original text.
The changed parts are as below! !
☆ wire type front anti-roll bar. As a result of this change, I change specification Front lower arm, front bulkhead, as well as front upper bulkhead L / R. Φ2.3 mm comes in a kit standard front anti-roll bar.
☆ by changing the shape of the plate, side belt tensioner to adjust the tension of the belt in two places tensioner bearing.
☆ clutch system changes to type H2707, acceleration from low speed range will be smooth. (1st. gear: 16T/2nd:. Gear 20T)
☆ main chassis is high traction chassis with excellent traction and steering and (Mugenlogo sculpture).
☆ by changing the shape of the front body mount plate, mounting holes in the body post has been added.
☆ Rear lower arm mount A & B has been enhanced.
◆ bulkhead of the rear and front becomes out machined aluminum, maintenance work can be easily done, such as a belt replacement.
◆ By replace upright upper plate of three (optional), front upright, you can change the kingpin angle.
◆ is attached to the RC module, servo throttle and steering fits the case of the RC receiver modules.
◆ brake disc, so that is attached to the rear axle solid, braking is applied to the rear drive shaft directly.
◆ 2 inserts at the top and bottom, mounting location of the front upper arm suspension shaft can be changed geometry of changing the end of Bush that there are two types of rear suspension shaft.
◆ By changing the mounting position of the steering servo saver arm, the hole location of the front upright arm, you can change the Ackerman.
◆ mounted directly next to the pulley and machined aluminum, lightweight middle shaft.
◆ 2 speed shaft, two speed unit is mounted in the hollow shaft of φ8mm. (1st. gear: 49T/2nd gear:. 46T)
◆ The rear body mount, hard type to improve the rear grip is attached.
◆ There are four options in the configuration, weights, you can adjust weight, and balance.
It is under construction like the target in late April release now, but we will continue to made from time to time as soon as the sales price and image to be worried about is found
choisan is offline   Reply With Quote
Old 04-05-2013, 12:11 PM   #2567
MiamizFinest's Avatar
Trader Rating: 37 (100%+)
Can someone point me in the right direction to find a front belt for the mugen MRX4??? Its outta stock everywhere. Does anyone here have one to spare?? Im Paypal ready!
-= Made In Dade =-
MiamizFinest is offline   Reply With Quote
Old 04-05-2013, 01:00 PM   #2568
pinoy69racer's Avatar
Trader Rating: 179 (99%+)
Just check right now nitrohouse.com they have on stock
HENRY C
DESOTO RACING/SERPENT/VEYTREX DESIGN LAB/RC TARGET
pinoy69racer is offline   Reply With Quote
Old 04-05-2013, 01:22 PM   #2569
It's on back order, look again I checked it first thing this morning and just now Again
-= Made In Dade =-
Old 04-05-2013, 01:44 PM   #2570
*1speedy's Avatar
Miami, Website Says IN STOCK, even when I put in cart.
Here is the link, hope this helps
http://www.nitrohouse.com/Belt-Front-Mrx24_p_10466.html
🏁🏁🏁 🏆🏆🏆🏆 2013 XRAY XB9 GT8 🏆🏆🏆🏆 🏁🏁🏁
2013 & 2014 R.O.A.R. REGION 1 & NY State GT8 CHAMPION!!
....................... 🏆 SPONSORS 🏆 .....................
ABSOLUTE HOBBYZ / Engines Modded by The Nitro Shop
*1speedy is offline   Reply With Quote
Old 04-05-2013, 03:00 PM   #2571
Roelof's Avatar
Send a message via ICQ to Roelof
Make one by yourself?
http://www.euronet.nl/users/tooms/spanner/spanner.htm
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 04-05-2013, 03:37 PM   #2572
dougday's Avatar
Desoto racing has in stock. Part number is BLI51201
dougday is offline   Reply With Quote
Old 04-05-2013, 05:48 PM   #2573
choisan's Avatar
shop@pro-s-futaba.co.jp
Pro futaba japan must have it
Old 04-06-2013, 07:08 AM   #2574
gotmotor's Avatar
Originally Posted by toto View Post
tuttomugen.jimdo.com/tutto-mrx5/
That piece is a joke I hope thats not the new design and trying to order from them is a joke
RcTarget~Airtronics~VP Fuel~Maxpower~SRC
gotmotor is offline   Reply With Quote
Old 04-06-2013, 12:18 PM   #2575
Flygio's Avatar
The guy who made that custom mod is from over here. He made that some time ago.
Serpent 977 - Fidelio Telemetry Software
Flygio is offline   Reply With Quote
Old 04-06-2013, 04:48 PM   #2576
gotmotor's Avatar
Oh my bad
Old 04-08-2013, 09:33 AM   #2577
MugenDrew's Avatar
Trader Rating: 28 (100%+)
Pics of the new 5 are up. Www.mugenseiki.com
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 04-08-2013, 11:18 AM   #2578
Trader Rating: 14 (100%+)
<World Champion-Spec Parts>
+ Rear Body Mount Hard (H0466-H)
+ Rear Lower Arm Mount A (H2108-B)
+ Rear Lower Arm Mount B (H2109-B)
+ Front Suspension Arm (H2119-C)
+ Front Upper Bulkhead L (H2142L)
+ Front Upper Bulkhead R (H2142R)
+ Front Lower Bulkhead (H2143)
+ Belt Tensioner Plate (H2220)
+ Front Bumper (H2402-B)
+ Front Body Mount Plate (H2403-B)
+ High Traction Chassis (H2401)
+ Clutch Set (H2707)
Speedpassion : Speedpower : East Coast Bodies
thunderbt3 is offline   Reply With Quote
Old 04-08-2013, 03:54 PM   #2579
occ
Trader Rating: 15 (100%+)
The original and still the best! Looks like I'm buying a new kit...
occ is offline   Reply With Quote
Old 04-08-2013, 11:07 PM   #2580
What has changed on the rear lower arm mount? Just new insert for alternative roll centers?
fulcrum2 is offline   Reply With Quote
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 07:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 09:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 08:49 AM
