Old 02-04-2013, 06:44 PM   #2551
SMcpot's Avatar
Trader Rating: 22 (100%+)
Questions??
How easy is it to drill a hole through the Mugen titanium turnbuckles and does doing so significantly compromise their strength? Want to use these in the upper arms, but it looks like the plastic has to be cut away in order to get a turnbuckle wrench in there for adjustment, which I'd like to avoid.
Also, does anyone here have any experience with the Mugen titanium pivot balls? I run on a track with wooden boards and don't make a habit of bouncing my car off those boards, but am wondering how these hold up.
SMcpot is offline   Reply With Quote
Old 02-26-2013, 11:35 PM   #2552
Questions?? Where to measure the 6 and 7 millimeters below the machine
Where to measure the 6 and 7 millimeters below the machine?
I abitually put my 6 and 7 mm. near the front axle precisely under the screw of the save servo, and in rear under the axis of the exchange, is right?
toto is offline   Reply With Quote
Old 03-01-2013, 07:05 AM   #2553
MugenDrew's Avatar
Trader Rating: 30 (100%+)
With a good sharp bit it drills very easy. Hold them in a vise and if you have a drill press it's even easier. I drill a 1.2mm hole and use a 90 deg. miniature pick tool to adjust. The turnbuckle will bend before it breaks where the hole is drilled.
The ti balls hold up very well. I've bent one since 1998...
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 03-01-2013, 07:07 AM   #2554
MugenDrew's Avatar
The front rite where the front bulkhead ends and the chassis steps out.
Old 03-01-2013, 08:59 AM   #2555
Drew where have you been ???
Miss you at the track.
Hope to see ya soon
Jim
DESOTO RACING--SERPENT-977 EVO- 2010/2017 FORGASS -PRES.
RED CUP RACING - -BYRONS FUEL -NUGGETS RACING- RC AMERICA
PICCO RACING ENGINES - SANWA RADIOS - - -http://winternats.blogspot.com
FORT MYERS R/C CAR CLUB MEMBER 1983-2017--FLORIDA WINTERNATS 1988-2017
jrice is offline   Reply With Quote
Old 03-01-2013, 01:41 PM   #2556
SMcpot's Avatar
Thanks Drew. Got the balls last week and will be ordering the turnbuckles.
Old 03-02-2013, 10:19 AM   #2557
MugenDrew's Avatar
Lunsford. 3x1inch and 3x 28mm. Get two of each. There ti is soft compared to Mugens but the extra length really helps.
Glad ya got your balls....she must be a mean one
Old 03-02-2013, 10:28 AM   #2558
MugenDrew's Avatar
Hope to see ya soon
Jim
Hey! Jimmy! New boat business, very bizy! Congrats on having the old metal monster stuck like fly paper!
Old 03-02-2013, 12:41 PM   #2559
SMcpot's Avatar
LOL.....you have no idea
Old 03-19-2013, 03:11 AM   #2560
Smile New MRX5?
News around the new MRX5, or new parts?
Old 03-19-2013, 10:25 AM   #2561
There are no news for updated kit ..maybe cause our baby is by far the best in 1/8!!!
Mtx6,Reds WCS,Protoform,kopropo,contact tires.
tonyhalandri is offline   Reply With Quote
Old 03-19-2013, 07:13 PM   #2562
MugenDrew's Avatar
+2
Worlds is this year,so keep your eyes peeled....
or maybe not???
Old 03-25-2013, 03:55 AM   #2563
Talking New Mrx5 ?
tuttomugen.jimdo.com/tutto-mrx5/
Old 04-05-2013, 05:17 AM   #2564
choisan's Avatar
mugen will launch a new upgrade version of mrx5 with the front end using wire anti-roll bar by end of apr, detail is to be confirmed.
choisan is offline   Reply With Quote
Old 04-05-2013, 06:01 AM   #2565
choisan's Avatar
Below is what i found from japanese website, i will try to do the google translation, but the correct meaning will be a little weird.
昨年末からずっと品切れ中だったMRX5ですが仕様変更を終え遂に発売決定となりました☆
気になる仕様変更した部分は☆のとおりです!!
☆ フロントアンチロールバーをワイヤータイプに仕様変更しました。この変更により、フロントロワーアーム、フ ロントバルクヘッド、フロントアッパーバルクヘッドL/R なども仕様変更しました。フロントアンチロールバーはφ2.3 mmがキット標準で付属します。
☆ サイドベルトテンショナーはプレートの形状変更により、テンショナーベアリング2ヶ所でベルトのテンション を調整します。
☆ クラッチシステムは H2707タイプに変わり、低速域からの加速がスムーズになります。(1st.ギヤ:16T/2nd.:ギヤ20T)
☆ メインシャーシはステアリングとトラクションに優れたハイトラクションシャーシ(ムゲンロゴ彫刻)となりま す。
☆ フロントボディマウントプレートの形状変更により、ボディポストの取り付け穴が追加されました 。
☆ リヤロワーアームマウントA&Bは強化されました。
◆ フロントとリヤのバルクヘッドはアルミ削り出しとなり、ベルト交換などのメンテ作業が容易に行 えます。
◆ フロントアップライトは、3種類のアップライトアッパープレート(オプション)を付け替えることにより、キ ングピンアングルの変更ができます。
◆ ステアリングとスロットルのサーボは、RCモジュールに取り付けられ、レシーバーもRCモジュールのケース に収まります。
◆ ブレーキディスクは、リヤソリッドアクスルに取り付けられていているので、制動は直接リヤドライブシャフト に掛かります。
◆ フロントアッパーアームサスシャフトの取り付け位置は上下2ヶ所、リヤサスシャフトは2種類あるブッシュの 付け替えでジオメトリーの変更ができます。
◆ ステアリングサーボセイバーアームの取り付け位置と、フロントアップライトアームの穴位置を変更することで 、アッカーマンの変更ができます。
◆ ミドルシャフトは、アルミ削り出しとなりプーリーを直接取り付けられて、軽量となりました。
◆ 2スピードシャフトは、φ8mm の中空シャフトで 2スピードユニットが装着されます。(1st.ギヤ:49T/2nd.ギヤ:46T)
◆ リヤボディマウントは、リヤグリップを向上させるハードタイプが付属します。
◆ ウエイトは、オプション設定で4種類あり、重量、バランスなどを調整することができます。
只今4月下旬発売を目標に製作中みたいですが、気になる画像や販売価格がわかり次第随時発表し ていきます
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 07:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 09:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 08:49 AM
