Old 08-12-2012, 08:13 AM   #2506
Originally Posted by MugenDrew View Post
I have ran the CSO and am currently using the Arrow max. Quality is identical, weight is the same (same weight as the original pulley set) pricing is similar (i think?).
I have only used the optional Mugen rubber belts. Keep in mind these are qualifying belts and not intended for hours of use. They do free the car up.
I am wondering with what tire diameter are you setting up your mrx5??
Mtx6,Reds WCS,Protoform,kopropo,contact tires.
tonyhalandri is offline   Reply With Quote
Old 08-12-2012, 07:36 PM   #2507
MugenDrew's Avatar
Trader Rating: 29 (100%+)
The 5 as well as the 4 and the 3 have always produced the quickest lap times when the rears are around 73mm. FORGASS runs 7 minute qualifiers plus a three minute warm up. So from the first lap on the track till the end of the main I record my tyre wear and cut accordingly so that half way thru my tyres should be close to 73. Split stays at 7.5mm so I'm just under a 1to1 drive ratio. The 5 has really surprised me at maintaining a split.
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 08-13-2012, 05:03 AM   #2508
Flygio's Avatar
Hi guys I'm looking for a 198mm RPP3 belt for my pan car. Can anyone tell me if the mugen mrx5 belt is 198? Accordingly to the 3mm pitch, the belt should be 66 teeth; is this the case?
Thank you very much.
Flygio is offline   Reply With Quote
Old 08-13-2012, 02:30 PM   #2509
so is it better to use a 66/73 tire diameter to set up the car??
Old 08-13-2012, 06:26 PM   #2510
MugenDrew's Avatar
Set up what?
Old 08-13-2012, 08:28 PM   #2511
GMartinez's Avatar
Trader Rating: 85 (100%+)
Set up what?
I think he is looking at starting point
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 08-13-2012, 11:13 PM   #2512
Set up what?
ride height...
Old 08-13-2012, 11:14 PM   #2513
that's it
Old 08-14-2012, 10:18 AM   #2514
MugenDrew's Avatar
AHHH HAAA!
Brand new track that I have never ran I'll set the car up on 76/68.5, rear ride hieght at 7mm front ride hieght at 6mm. Run the car 5 minutes at a time then rotate tires. When the chassis starts to drag stop running and measure the tyres diameter. Use this and the above info to figure ride hieght for the qualies and the main based off of tyre wear. I like to leave an extra millimeter of ride hieght in the car for the main if I can. Its really nice to be the guy with rubber to spare at the end of a race. Remember two milimeters of tyre diameter is only one milimeter of ride hieght.
Old 08-15-2012, 09:15 AM   #2515
AHHH HAAA!
Thanks guys for the info ..unfortunately in Greece this category is due to eliminate so I do not have records from real race only practice... most of the times in dirt enviroment without timer..
Old 08-15-2012, 07:21 PM   #2516
Trader Rating: 1 (75%+)
what are the factory side pulley numbers
bigironbullies is offline   Reply With Quote
Old 08-15-2012, 07:48 PM   #2517
Rob B99's Avatar
Trader Rating: 15 (100%+)
28 or 29 .. and 18
Sweep Racing Tires~TQ wire~ Brooklyn Hobbies ~ Phat Skeemz Paint ~
360v2 New Rochelle
Rob B99 is offline   Reply With Quote
Old 08-24-2012, 07:02 AM   #2518
Trader Rating: 14 (100%+)
Below is JJ Wang's China National Champion setup:
Speedpassion : Speedpower : East Coast Bodies
thunderbt3 is offline   Reply With Quote
Old 08-24-2012, 05:17 PM   #2519
GMartinez's Avatar
Rick what are the track dimensions
Old 08-24-2012, 08:09 PM   #2520
I'm not Rick. He's rwang, try PM'ing him for the track dimensions.
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 07:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 09:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 08:49 AM
