Old 07-16-2012, 05:00 PM   #2476
walo's Avatar
Send a message via Yahoo to walo
Originally Posted by Mr-s413bt View Post
Hey guys,
anyone got any suggestions for how far forward to mount the new PF R18? same as the P909 26mm?
Yes, 26mm is a good spot .
walo is offline   Reply With Quote
Old 07-16-2012, 05:20 PM   #2477
Mr-s413bt's Avatar
Thanks Walo... been a few months since i have driven 1/8th!
Mr-s413bt is offline   Reply With Quote
Old 07-19-2012, 08:31 PM   #2478
rip67vdub's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to rip67vdub
Questions?? Pls look. Need help from you Mugen heads
I couldn't find the proper forum to post this, but here it goes. A buddy of mine blew his 1/8 onroad MR21 motor a few days ago, and in the process, damaged his piston head. I've tried to help him look everywhere online to purchase this part, but I've had no luck whatsoever. Rather than perhaps going to the manufacturer directly, does anyone know he can purchase this part from a 3rd party seller? Your help is greatly appreciated. Thanks for looking.
rip67vdub is offline   Reply With Quote
Old 07-19-2012, 09:14 PM   #2479
SuperEk4's Avatar
Trader Rating: 32 (100%+)
I am not sure is this the right place to post.but it seems there little information about mrx2. I have a old mrx2 converted to Ep.I need a belt n parts.may I know is some mrx5 parts comparatible with mrx2. belts n pulley n etc? pls advise thx!
Hobbywing-Acorn Racing-ManiaRC-UpgradeRC-Hong nor-Rc monster-Blackbeard-Rc-MoosDesign-SweepRacing-Boca bearings-Tresrey USA-Velociti raceware-Tekno Rc-Team J-JPL Models-SNR Graphite (RETIRED)
SuperEk4 is offline   Reply With Quote
Old 07-19-2012, 11:16 PM   #2480
gotmotor's Avatar
Try rcmodelstore.com
RcTarget~Airtronics~VP Fuel~Maxpower~SRC
gotmotor is offline   Reply With Quote
Old 07-22-2012, 02:39 AM   #2481
Hi guys,
Does anyone know if the mrx5 shocks fit an Xray Rx8?
Capricorn LAB C02
Protoform
Futaba
Sirio
xray man is offline   Reply With Quote
Old 07-22-2012, 03:56 AM   #2482
MRX4XXXX's Avatar
Originally Posted by xray man View Post
Hi guys,
Measurements from end to end:
Front:
All the way in ==> 59.50mm
All the way out ==> 69.00mm
Rear:
All the way in ==> 61.50mm
All the way out ==> 70.00mm
I would say that they fit OK, since the first version of RX8 was a direct copy of MRX4X and MRX4 and 5 have the same dampers.
Share the results for us also if you try it??
-X-
MRX4XXXX is offline   Reply With Quote
Old 07-22-2012, 07:42 AM   #2483
Stuff Of Legend's Avatar
Questions??
Front:
Rear:
-X-
Rear:
Using short links in rear?
RC STABLE....
CRC GEN X 10se
YOKOMO BD72016 - SERPENT VIPER 977e
HOBBYWING motor's/esc's - PROTOFORM bodies
SAVOX servo's - SPEKTRUM tx/rx - XCEED tire's
Stuff Of Legend is offline   Reply With Quote
Old 07-22-2012, 12:40 PM   #2484
What belt is he after because they didnt change the belts until the MRX5. Now the only belt that is the same is the rear belt the rest are new to the MRX5 so if it is the side or front belt then you can use an MRX4 one and I think all the pullys are the same from the MRX2 to the MRX4 except the big rear one. Hope that all makes sense.
Mugen MRX-5, Nitro-X fuel, OS Motors, Sanwa, Blits, Team Titan, ARC R10, www.crccc.co.nz
Mugen NZ is offline   Reply With Quote
Old 07-23-2012, 07:10 AM   #2485
Hi there,
did someone play around with shock piston holes and could share the findings?
For example front 1.3mm holes and very thick oil to compensate?
In theory large holes paired with thick oil should give the same low speed dampening effect but smoother high speed (over bumps the car should be more forgiving).
Thanks a lot and best regards!
fulcrum2 is offline   Reply With Quote
Old 07-23-2012, 09:33 AM   #2486
asw7576's Avatar
Originally Posted by fulcrum2 View Post
Hi there,
With 1.3mm holes, I use mugen 450. My home track is high speed, flowing, have few bumps and dont have smooth surface.
I think you should try mugen 600 as your starting point.
Old 07-23-2012, 11:00 AM   #2487
OK, thanks a lot for sharing this information.
Are you pairing this with stock pistons in the rear and 600 oil? Ever tried to drill bigger holes in the rear?
Old 07-23-2012, 11:42 AM   #2488
new3's Avatar
try 33 it is good too
www.new3racing.com, OFNA, Mugan MRX5wc, www.speedshophobbies.com, western engineering, redline racing fuels,
new3 is offline   Reply With Quote
Old 07-23-2012, 01:00 PM   #2489
asw7576's Avatar
I use 1.3mm piston hole front and rear.
450 front and rear too.
I cant comment the road feel with drilling bigger piston hole questions yet because i havent try it yet. I have spares oil damper drilled to 1.5mm inside my tool box. However i havent try it yet.... I think you should try 1.3 first (try stock as is).
Old 07-30-2012, 06:39 AM   #2490
I am getting ready to run my MRX-5 WC for the first time, but before I do, I was curious if there was ever a resolution to the side belt problem. I tried a search but found more people talking about it, but not much in the way of fixes. I have the front belt around the right tension and as a result, with the side tensioner down all the way, the belt is still very loose. Just curious if there was a quick resolution to this issue so I don't end my day prematurely. Thanks.
AMorgan is offline   Reply With Quote
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 07:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 09:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 08:49 AM
