Old 05-07-2012, 04:16 PM   #2446
Roelof's Avatar
Send a message via ICQ to Roelof
These 19x12 bearings are not made for such forces. With the introduction of the Serpent Excel we have seen many failing bearings and some years ago you could buy sets to change the 21x12 bearing with an 19x12 and a small adapter because they should spin with less resistance. At the end many drivers did switch back.
If the current adapter has a diameter of 21mm you could go with the bigger bearing but you will loose yhe option to change wheelbase and/or ride height.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 05-07-2012, 05:09 PM   #2447
MugenDrew's Avatar
Trader Rating: 30 (100%+)
Huh? The bearing size is a 18mm X 12mm. There are no adaptors in the up rites. This was done to lose a large amount of unsprung weight. Yes some reliability was sacrificed to enhance handling and lower lap times. Are you buying a race car or a parking lot hero?
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 05-07-2012, 05:26 PM   #2448
Super Moderator
Snowy's Avatar
Trader Rating: 14 (100%+)
Originally Posted by minibonna View Post
Hmm. Bearings are Mugen, and track is not that dirty. No trouble with the other bearings on the car.
Like Roelof said above, the bearings on the front and rear hubs don't last that long because of the load and they are smaller in size (12x18x4mm) than they used to be in previous models.
Years ago, the manufactures used bigger bearings (12x21x5mm) on the hubs and they lasted forever but now they use the same size that you find in 1/10th cars to save weight and be able to adjust the axle height on some models of cars.
You need to change the bearings in the hubs every few months on the MRX5 or depending on the amount of racing you do. I just buy the $1 bearings and change when they get notcy.
Racing Lines Magazine
Snowy is offline   Reply With Quote
Old 05-07-2012, 11:56 PM   #2449
Roelof's Avatar
Oeps, my bad, whats the difference 18 or 19mm
And I realy thought the 5 was using inserts like Shepherd and Xray. I do know people are using MRX4 uprights or even Shepherd uprights and I do know one Shepherd driver who has taken out the inserts and placed 21x12 bearings.
Old 05-08-2012, 01:11 AM   #2450
Default Set-up for slow-speed corners
Hi there,
could you please help me with a MRX-5 set-up question?
From time to time I have the situation that the car really slows itself down when attacking tight corners like hairpins. I don't need to brake, but just turn in, the car decelerates a bit and then aggresively enters the turn.
On other occations, it will just push and miss the apex by a mile. Need to adjust my driving, come off the throttle earlier or brake a lot.
I have not found out what to do to achieve this at will. I like this very much because it really saves time and frees up the brain a bit if there is no need for braking...
Any ideas?
fulcrum2 is offline   Reply With Quote
Old 05-08-2012, 03:55 AM   #2451
Super Moderator
Snowy's Avatar
Originally Posted by fulcrum2 View Post
Hi there,
Any ideas?
Sounds strange. Are the front tyres rubbing on the body when you turn? It can happen when they are big then stop when they wear down.
Old 05-08-2012, 04:34 AM   #2452
MugenDrew's Avatar
Hi there,
Any ideas?
How tight do you have the servo saver spring adjusted? If your running the Ackerman adjusted all the way forward did you remove material as per the manual from both of the steering links inner ball links?
Old 05-08-2012, 06:47 AM   #2453
Thanks for the follow-up guys!
Tyres are not rubbing, ball cups dont touch the pulley and servo saver is strong.
To clarify: I want to create the effect that the steering (at full lock) slows the car down and allows to enter hairpins aggressively (instead of just understeering)...
Old 05-08-2012, 09:43 AM   #2454
MugenDrew's Avatar
Drag brake? Lots of drag brake...
Old 05-08-2012, 03:29 PM   #2455
Thanks alot for the answers about the bearings, but i still find it very strange that its only the bearings for the front wheels who wear out that fast. Had the same problem last year.
Anybody who know of hi quality bearings that will last longer than the Mugen bearings?
minibonna is offline   Reply With Quote
Old 05-08-2012, 03:38 PM   #2456
MugenDrew's Avatar
You could switch to a ceramic. Are you taking the Shields out and cleaning and lubing them?
I use steel bearings from avid rc. There a dollar each. I throw allot of bearings away, lol.
Old 05-08-2012, 11:49 PM   #2457
walo's Avatar
Send a message via Yahoo to walo
The Mugen bearings are fine, but they or any other bearing that size will not last long under constant impact. You can try bearings from HPI, Team Associated, or Bocca bearings. Under normal use, they will get smoother over time.
walo is offline   Reply With Quote
Old 05-09-2012, 11:57 AM   #2458
I use the ceramic orange seal bearings from boca and I haven't got any problem
Mtx6,Reds WCS,Protoform,kopropo,contact tires.
tonyhalandri is offline   Reply With Quote
Old 05-11-2012, 04:29 AM   #2459
Default MRX5WC
just wanna ask u guys running the WC kit,do you guys use all of the option parts included in the kit?how is the car with the option parts?
tq23 is offline   Reply With Quote
Old 05-19-2012, 11:04 AM   #2460
GMartinez's Avatar
Trader Rating: 85 (100%+)
Default MUGEN MRX5 WCE
Built this for a friend/customer he has a couple of 1/8th electric cars but was looking for a one of a kind so i took a couple of ideas from other brands & put this together for him all I can tell u this thing is fast and sick will try to get a video of it when we test at the track
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 07:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 09:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 08:49 AM
