Old 02-21-2012, 10:18 AM   #2371
Roelof's Avatar
Send a message via ICQ to Roelof
Make it a PDF or JPG and attach it with a reply.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 02-23-2012, 09:45 AM   #2372
Pooh2's Avatar
Send a message via MSN to Pooh2
Default Setup
I don't know how to post the setup sheet so I just did it this way.
FRONT
Width 253
Toe 1 each side
Camber 2
Droop 1+
Swaybar 45
Caster 5mm
Springs Yellow
Ackerman forward
Shocks middle hole
Oil 500
H2131 Forward
Steering rod- Forward
Upper arm position- front and rear UP
Ride height- depends on tire size
20 gr weight in the middle
Offset- Stock
Rear
Width- 263
Droop- 9
Camber-3
Toe-2
3mm- swaybar
Shims- 2 mm
Roll center - bottom
Weights in the rear 20X2
Weights on the drivers side 39 grams
Shock oil -500
Shock position- 2nd hole
Rear springs - Grey
Camber link- long
The body was 26.5 mm forward
The wing was 12.85 mm high
Body- P909 light weight
I used all for wheel disk
32/35
NO SAUCE!
If I missed anything just let me know.
MUGEN MRX5/CONTACT TIRES/DESOTO RACING/TEAM LOGIC
"Since the Bible and the church are obviously mistaken in telling us where we came from, how can we trust them to tell us where we are going"?
Pooh2 is offline   Reply With Quote
Old 02-23-2012, 07:31 PM   #2373
gotmotor's Avatar
FRONT
Width 253
Toe 1 each side
Camber 2
Droop 1+
Swaybar 45
Caster 5mm
Springs Yellow
Ackerman forward
Shocks middle hole
Oil 500
H2131 Forward
Offset- Stock
Rear
Width- 263
Droop- 9
Camber-3
Toe-2
3mm- swaybar
Shims- 2 mm
Shock oil -500
Camber link- long
32/35
NO SAUCE!
Rear Springs...lol
RcTarget~Airtronics~VP Fuel~Maxpower~SRC
gotmotor is offline   Reply With Quote
Old 02-26-2012, 12:00 PM   #2374
Pooh2's Avatar
Originally Posted by gotmotor View Post
Rear Springs...lol
What's good dawg? You coming to the Nats? Track is really nice!!!
Old 02-26-2012, 01:12 PM   #2375
CanyonCarverR1's Avatar
Rear Springs...lol
Does it matter?
CanyonCarverR1 is offline   Reply With Quote
Old 02-26-2012, 07:35 PM   #2376
gotmotor's Avatar
Talking about it
Originally Posted by CanyonCarverR1 View Post
Does it matter?
Didn't you sell all yo Sh!t
Old 02-26-2012, 07:42 PM   #2377
Pooh2's Avatar
Talking about it
You should try and make it dawg. I really like that track and I'm sure most will. Any big races for you this year?
Old 02-26-2012, 08:22 PM   #2378
Anyone played with the flyweights of the new clutch?
I did cut my shoes to leading (I always do) but the new clutch comes with a tailing setting and so far I see there are no leading flyweights optional with original or optional parts. RickV told me that a leading setting does not work well and that is why only tailing is used but so far I have tested I haven't seen any problem.
Any benefit to run the weight leading? Is it engage earlier then tailing?
GP: Mugen MRX-6, Serpent Cobra GT 3.0
Engine: Tesla 7 port on-road, Tesla 5 port GT, Rody VS02, OS 2101
beebone is offline   Reply With Quote
Old 02-26-2012, 08:45 PM   #2379
Pooh2's Avatar
From what I've noticed with the NEW CLUTCH it hit's really hard but feels VERY smooth. It seems to allow you to get on the power sooner and harder without disrupting the car.
Old 02-26-2012, 08:59 PM   #2380
From what I've noticed with the NEW CLUTCH it hit's really hard but feels VERY smooth. It seems to allow you to get on the power sooner and harder with disrupting the car.
BTW, I saw ur setup data. I think the front is very sensitive because of 500 shock oil, highest roll center position, those keep the weight transfer heavy on the front, only the yellow spring and 45 roll bar help to compensate abit weight. Did you try heavier shcok oil and softer spring?
what the ride height u normally set? I think -2 camber fits for low ride height setup.
Old 02-26-2012, 09:28 PM   #2381
gotmotor's Avatar
Looking at the Nats, RCpro and KOpropo raceD
Old 02-27-2012, 12:40 AM   #2382
Roelof's Avatar
The answer was already given on this page:
MUGEN SEIKI MRX5
There seems to be no defference than only the needed spring tension.
Old 02-27-2012, 11:33 AM   #2383
gregsbox's Avatar
READ HERE
[YOKOMO] [XRAY] [SANWA] [TEKIN] [ALIGN] [JR]
www.thisisrc.com
www.thisisbluerain.com
gregsbox is offline   Reply With Quote
Old 02-27-2012, 02:45 PM   #2384
Questions?? Gearing ratio and shift point
Hi,
can somebody give advise how to find the correct gearing ratio for different tracks. What is important, what should be considered to be fast and to have a stable car. Is there a way to pre-calculate the best ratio on a theoretical basis, e.g. based on the lenght of the track, the amount of curves etc.? Where should be the shift point on the track? Is there a general rule like shift in the curve, short after the curve etc.? How should be the step between the first and the second gear.
thx.
mugentom702 is offline   Reply With Quote
Old 02-27-2012, 02:56 PM   #2385
Questions?? Receiver Battery
Who is using a LiPo battery for the receiver and made good experience? What is the recommendation, better a LiFe or NiMH? I do see a huge benefit wrt weight, size and capacity.
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 08:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 10:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 09:49 AM
SEO by vBSEO 3.5.0
