Old 07-21-2011, 03:59 PM   #2206
SMcpot's Avatar
Trader Rating: 22 (100%+)
Questions??
Can any of you team guys that have presumably used the new-configuration clutch clue us in to its advantage over the traditional centax-style clutch?
SMcpot is offline   Reply With Quote
Old 07-22-2011, 01:43 AM   #2207
Roelof's Avatar
Send a message via ICQ to Roelof
There are some advantages I did not see at the 1st time
- the flyweights do not have to move over the pins of the flywheel, they only have to rotate which makes the movement faster due less friction.
- the movement is in a straight line of the force and not in an 45 degree angle wicht does give 1.4x more force in the clucth system.
- there is less weight on the outside of the flywheel.
All advantages is giving a faster responding clutch with which you should be able to set an higher engaging point.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is online now   Reply With Quote
Old 07-22-2011, 03:19 AM   #2208
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
MRX5 World Champ edition....
http://www.redrc.net/2011/07/mugen-m...on/#more-45300
Shepherd RC | Brilliant RC | Arrowmax | Xtreme Aerodynamics | Matrix | Tectrade TTB
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 07-22-2011, 09:16 AM   #2209
SMcpot's Avatar
Thumbs up
I also didn't take into account the weights only moving on one plane.
Old 07-22-2011, 09:23 AM   #2210
SMcpot's Avatar
Old 07-25-2011, 05:35 AM   #2211
MugenDrew's Avatar
Trader Rating: 30 (100%+)
www.mugenseiki.com, click on whats new.
New parts for MRX5
H2118-B Front Sus. Arm MRX5
Coming soon!
New parts for MRX5
H2119B Front Upper Arm Link MRX5
Coming soon!
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 07-25-2011, 07:11 AM   #2212
Trader Rating: 14 (100%+)
Are these just the stiffer parts that were talked about during the worlds?
thunderbt3 is offline   Reply With Quote
Old 07-25-2011, 07:36 AM   #2213
The eyelet at the end of the camber rod is thicker and the upper arm is a little thinner to fit the thicker eyelet in .
RICHARD SIRIANO
BROOKLYNHOBBIES.COM
MUGEN USA
2011 /2012 REGIONAL 1 1/8TH SCALE ONROAD CHAMPION
TEAM BROOKLYN is offline   Reply With Quote
Old 07-25-2011, 07:39 AM   #2214
I have used the new clutch and the new design is better . I think the other companys will come out with the same design .
RICHARD SIRIANO
BROOKLYNHOBBIES.COM
MUGEN USA
Old 07-25-2011, 09:09 AM   #2215
MugenDrew's Avatar
NO, those parts were molded from a much more ridged plastic from the existing molds. They had every plastic part on the car in the stiffer formula.
There seems to be some uncertainty if we will ever see them again...
Old 07-25-2011, 09:13 AM   #2216
MugenDrew's Avatar
For what it's worth,they did add little humps on the top and bottom side of the arm where the eyelet goes. When the turn buckle is screwed into the eyelet there is a greater amount of expansion which produces more of a force fit into the arm.
Old 07-25-2011, 12:31 PM   #2217
Jay7's Avatar
Send a message via AIM to Jay7
Looks like the WC MRX5 is out in limited quantities. http://www.redrc.net/2011/07/mugen-m...on/#more-45300
Jay7 is offline   Reply With Quote
Old 07-25-2011, 01:09 PM   #2218
Michael_T's Avatar
From what I have been told, the WC version will only be available in EU
Old 07-25-2011, 03:37 PM   #2219
Mr-s413bt's Avatar
Correct... its a MSE release only although Mugen dist. in other regions can purchase them but i don't believe it is cost effective.
Mr-s413bt is offline   Reply With Quote
Old 07-28-2011, 08:20 AM   #2220
rave1010hk's Avatar
Default My Diy Brass Engine Mounts
My Diy Brass Engine Mounts 86g
MUGEN MTX5、MTX4-R、NR FLASH 12.PTS/MRX5、NR FLASH 21.PTS/MBX6、NR BONITO 21-7XLBS/SPP 966、733、811、411、120、120L、240、100/TAMIYA 417、F104X1、M05/XRAY RX8、T3/FUTABA 4PKS
rave1010hk is offline   Reply With Quote
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 07:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 09:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 08:49 AM
