Old 06-13-2011, 03:59 PM   #2146
bsmooth's Avatar
Trader Rating: 17 (100%+)
Originally Posted by ralphierace13 View Post
lol u kidding, thats the worst advice, everyone has a different driving style!! i did use robert pietch setup and car was terrible then i took that x-ray book went to track, felt what the car was doing and looked throu the book and tryed different things till i got it perfect, there are 5 or more top drives for mugen i seen them in the pre worlds all had basic setups but other things were different, plus they came from different countrys which has much differnt track layouts and differnt pavments r used, download the book and take to the track with u, and understand the book by trying the differnt things...
That's kinda where im at. I can copy every setup know to man, but it doesnt teach me what to expect the car to do with those settings. Basically something like: If the car pushes coming off the corner, what adjustment do I look at, and what does that adjustment do to the car. Does it lift the inside rear tire up? Does it make the top of the car lean over.
I guess really what I want to understand is the different hinge pin mounting points, and when, why, and how do I adjust them.
bsmooth is offline   Reply With Quote
Old 06-13-2011, 06:25 PM   #2147
CanyonCarverR1's Avatar
+1 You can't run someone elses setup, it's taylored to their driving style/skills, you have to learn how to setup the car and develop your own setup. Only then will you be able to adapt to different tracks and conditions. The Hudy book and others like it are a great way to learn what each adjustment does in theory, but track time and making the adjustments one at a time to see the change in handling is the way to develop chassis setup skills.
CanyonCarverR1 is offline   Reply With Quote
Old 06-13-2011, 11:04 PM   #2148
Roelof's Avatar
Send a message via ICQ to Roelof
That is the problem with certain brand(s), if the desiner is also testing the car he will create it to himself. OK Pietch did design and test his own creation but or his setup is close to an avarage or he did create enough play into the car to satisfy everyone.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 06-14-2011, 10:29 AM   #2149
Could someone help me out with mugen shock oils. I'm not sure the difference compared to AE and losi? Thanks
chet is offline   Reply With Quote
Old 06-14-2011, 11:16 AM   #2150
Roelof's Avatar
http://www.twf8.ws/php/tip/shock.html
Old 06-14-2011, 04:35 PM   #2151
bsmooth's Avatar
That Hudy book is MONEY!
I just got through briefly checking it out, and that is exactly what i'm looking for!
I might have to make a Kinko's run, and print a nice copy for the track binder.
Thanks guys for suggesting that.
-Steve
Old 06-14-2011, 07:26 PM   #2152
gotmotor's Avatar
Screw the book, just drive it like you Stole it
RcTarget~KO~VP Fuel~OS~Matrix
gotmotor is offline   Reply With Quote
Old 06-14-2011, 08:54 PM   #2153
bsmooth's Avatar
I knowwwwwww!
I did that this weekend. I took out a few peeps, and practically broke the car in half.
Good times!
(my apologies to my Speedworld bro's)
Old 06-20-2011, 08:40 AM   #2154
A little Toledo action.
Me black car MRX-5 Picco Murnan, round 2, 1/8th open
http://youtu.be/3VH1LAVrWNE
Desoto Racing, Serpent America, Novarossi, KoPropo, Xceed.
2011, 2013, 2 Time Midwest Series 1/8th Open, Champion
2011 Byrons onroad 1/8th Open 3rd
2011 Roar Nats 1/8th Open, 5th
2012 GLC 1/8th Open Q7 Finish 5th, 2013 GLC 1/8th Open Q4 Finish 7th
Vector03cobra is offline   Reply With Quote
Old 06-20-2011, 08:55 AM   #2155
wingracer's Avatar
Trader Rating: 23 (100%+)
You're entering into a whole different world of black magics and ancient chinese speed secrets
To really describe it properly, I would have to write a pretty long essay and I'm sorry but I just don't feel like taking the time to do that right now. Especially since once I do, half the people on here will argue with me about it. So my advice is to make a big change and go drive it. First hand experience will teach you far quicker.
Probably the biggest and most noticeable change is the rear lower arm position. With that one change you can completely alter the car's basic characteristics. Give it a try.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 06-20-2011, 09:43 AM   #2156
Roelof's Avatar
There is a neat little piece of software called SUSPROG. It is not free but looking arround on the net you can find working versions. With that you can draw out the suspension and see what it does.
Old 06-20-2011, 11:00 AM   #2157
wingracer's Avatar
I've done that by hand before. Lots of fun taking accurate measurements of everything. I still have the detailed diagrams I did of the MRX-3 around here somewhere.
Team Shepherd USA
Old 06-20-2011, 11:07 AM   #2158
asw7576's Avatar
I think MRX5 is already agressive and responsive car at middle of slow cornering turns. I think the lowest and middle position are already enough for MRX5. The highest position probably will make it harder to drive.
Compare to older car like my MRX4-R, this is what i notice when i changed the lower hinge pin position from lowest to highest position. Again, this is what I notice with my MRX4-R car.
Lowest position = 4.5 rear block = low roll center = more body roll, car is less responsive, understeering at mid cornering off throthle, understeering at mid cornering half throttle too.
Highest position = 6.5 rear block = high roll center = less body roll, car is more responsive, the car's rear end rotate much quicker in mid cornering off throthle.
Finally I end up with 6.5 rear block, and I'm satisfied with it because I have higher cornering speed now. In the begining, I sense a kind of nervous car feeling because the car suddenly can rotate very quick in middle of cornering while off throthling. The car is also very responsive to steering inputs. My solution, I reduce the dual rate to 80 ( from 100 ). My car is responsive but not nervous to drive now.
Old 06-23-2011, 08:41 AM   #2159
RC MARKET's Avatar
ARROWMAX Released Option Parts for MRX5
RC MARKET is offline   Reply With Quote
Old 06-26-2011, 02:19 PM   #2160
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Anyone have any feedback on the Tough Racing Belts for the MRX5? I used them in 1/10th and loved them. Just wanted to know if they held up well in 8th scale also?
I read that the original mugen side belt was too long, is it the same case with the tough racing side belt?
Thanks,
Shepherd RC | Brilliant RC | Arrowmax | Xtreme Aerodynamics | Matrix | Tectrade TTB
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 07:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 09:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 08:49 AM
