Old 05-04-2011, 07:18 PM   #2086
Tony Rice's Avatar
Originally Posted by CanyonCarverR1 View Post
Any idea what the black plastic part mounted in front of the battery opening is? A splash guard?
Looks like 130 grams of weight is added... maybe that piece is not plastic and is needed for weight. ?
______________________________
DeSoto Racing ••• Picco ••• RED CUP RACING™ ••• Serpent ••• Byron Fuels ••• winternats.com
Tony Rice is offline   Reply With Quote
Old 05-04-2011, 07:19 PM   #2087
Steve Rossi's Avatar
Originally Posted by Mugen NZ View Post
So is that heavy duty wire from the battery to the plug and then from the plug to the receiver or just from the plug to the receiver. Because I dont know if I can replace the lead from the LiFe battery to the plug. And if I do it from the plug to the receiver only will that still have an effect. I wouldnt have thought so. Thanks
just from the pack to the receiver
We will give away a $10 off coupon on purchases over $50 once we reach 800 likes.
https://www.facebook.com/srossimotorsports
SROSSIMOTORSPORTS.COM - OS SPEED - PROTO-FORM - PROLINE - MURNAN MODIFIED -KO PROPO- JUN RC JAPAN - RC AMERICA - SPEEDMERCHANT - EAM MOTORSPORTS
Steve Rossi is offline   Reply With Quote
Old 05-04-2011, 10:55 PM   #2088
I think the black part in the car of Robert Pietsch is a cable guide. He mounted the receiver on the exhaust side, so he needs to route all the cables across the car (between battery pack and middle shaft).
fulcrum2 is offline   Reply With Quote
Old 05-05-2011, 04:56 AM   #2089
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
Originally Posted by tonyhalandri View Post
I am thinking of purchasing rsx sevros to use them with my 4PKS.Are you suggesting the hard case ones or not?
the hard case is not needed, extra weight, same torque/speed, and white???? yea ytry keepin those clean..lol.. i would become crazed trying to keep my 400 dollar servos loking good, i bought 4 of the standard "blacks: 2 high speed and 2 high torque
Thinking on maybe a Tekno 1/8 Nitro Buggy?
TommyBlazin is offline   Reply With Quote
Old 05-05-2011, 06:37 AM   #2090
MugenDrew's Avatar
Trader Rating: 28 (100%+)
Originally Posted by Woodlands Racer View Post
Mugen Drew,
You posted earlier in an answer to someone else that you too had experienced advanced wear on the inner bearings on all four corners. I have been running my MRX5 since they were first released last fall and have had the same experience. I also use the Avid bearings and pitch and replace them at $1 each. However my question is, do you have any idea or willing to venture a guess as to the cause?
Thanks,
Roger
These bodies are vaccum cleaners. There is a very large low pressure under the front of the car. If its on top of the track and loose your going to suck it up in there when ya run over it, dust, sand, rubber etc. If you look at the right side up-rite from the front of the car when the wheels are turned right you will see that the bearing is expossed to the rush of air. It packs it in there.
I made a couple little deflectors out of scrap lexan. I drilled the forward screw hole on the front up-rites that is intended as the mounting hole for the wheel disc all the way thru and I am using a 4mm screw to mount the "deflector". If it works I'll make them out of carbon.
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 05-05-2011, 08:51 AM   #2091
Thanks....
Mtx6,Reds WCS,Protoform,kopropo,contact tires.
tonyhalandri is offline   Reply With Quote
Old 05-07-2011, 03:16 PM   #2092
Anybody know when the new front upper arms might be out?
Peppinerus is offline   Reply With Quote
Old 05-07-2011, 08:27 PM   #2093
Bill Wyatt's Avatar
So where are people putting all their weights?
And just fyi I haven't had any glitching problems with my radio gear in the stock position.
MUGEN USA / NOVAROSSI / AIRTRONICS / KONA KUSTOM DECALS
DARKSOUL RACING / ONEILL BROTHERS RACING / KILLER RC
Bill Wyatt is offline   Reply With Quote
Old 05-07-2011, 11:01 PM   #2094
gotmotor's Avatar
I put mine on my light weight rims it seems to balance the car
RcTarget~Airtronics~VP Fuel~Maxpower~SRC
gotmotor is offline   Reply With Quote
Old 05-08-2011, 06:34 AM   #2095
That was classic!!
Rich Browne is offline   Reply With Quote
Old 05-08-2011, 11:08 AM   #2096
Originally Posted by Rich Browne View Post
That was classic!!
so thats how its done, I needs me some balance, lol
SERPENT AMERICA / Desoto Racing / kosmic fuel
michael 1 is offline   Reply With Quote
Old 05-08-2011, 07:28 PM   #2097
Bill Wyatt's Avatar
thanks for the help...let me know if you guys ever need anything...
Old 05-15-2011, 01:25 AM   #2098
FRP
let's show your mrx5 and not have this thread sink!
FRP is offline   Reply With Quote
Old 05-15-2011, 08:11 AM   #2099
bsmooth's Avatar
Trader Rating: 17 (100%+)
Looks good!
Is the purple your own anodizing, or are those aftermarket parts?
Also, where can I get those plastic body mounts (the parts that mount directly under the body)?
-Steve
bsmooth is offline   Reply With Quote
Old 05-15-2011, 09:34 AM   #2100
gotmotor's Avatar
Originally Posted by bsmooth View Post
Looks good!
-Steve
Nitrohouse sells them.
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 07:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 09:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 08:49 AM
