Old 05-03-2011, 03:30 AM   #2071
CHRISP76's Avatar
Originally Posted by CanyonCarverR1 View Post
Here's a pic from REDRC
Cheers, must have missed that page on Red.
Chris P
MUGEN / NOVAROSSI / MATRIX
CHRISP76 is offline   Reply With Quote
Old 05-03-2011, 05:59 AM   #2072
Hi all, have a look to the mugen team driver setup sheet at world everyone is using the optional front upright upper plate C (PN# H2131) and positioned the hole at front. Anyone could explain how it works and what good it brings?
Navi is offline   Reply With Quote
Old 05-03-2011, 06:16 AM   #2073
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
Originally Posted by jdesoto View Post
You guys should try KO Propo. The latest version, Eurus, is bullet proof.
not true at all, i had several run aways with it.....but with top of the line hitec, i am buying 2 rsx servos today, as the connector ends are gold plated, and maybe have something to do with ti, also taking the reciever out of the case<plastic> and wrapping it in foam in the radio box to ensure as much vibration free operation as possible...
Thinking on maybe a Tekno 1/8 Nitro Buggy?
TommyBlazin is offline   Reply With Quote
Old 05-03-2011, 06:21 AM   #2074
Roelof's Avatar
Send a message via ICQ to Roelof
Well..... it seems there is more than only blaming the electronics. Mugen did already change the receiver position so that must have a good reason.
But did all of you guys with glitches try to connect the chassis to the ground and with that I mean a wire from the negative pole of the battery to the chassis?
It can take away a lot of interferences made by the chassis, motor and clutch.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 05-03-2011, 06:33 AM   #2075
Only Robert runs the receiver on the other side. The other Mugen drivers had the standard layout and did just fine. I think Robert is doing it to have the possibility to put weight on the right side of the car, close to the center. At the worlds he ran at least 60 gram in the original place of the receiver. The world circuit was ran clockwise with two long right hand sweepers, so having weight on the right side of the car should help...
We have so many Mugen drivers now at our national events with the receivers mounted in the original position without issues, so it must be something different. As I said, I got rid of glitching by changing to PPM transmission mode (disables the failsafe with low voltage protection as well).
What Steve Rossi posted earlier makes a lot of sense to me: The power leads are quite thin if you use a Futabe servo extension for example. With two strong digital servos there is certainly a high current load on them. I charged my Life pack with 3amps at one time and the connector got extremely hot. I was really shocked when I touched it...
What other otions for the power leads do we have? I can not just make my own leads (have tried already) because the socket pins and Futaba connectors do not accept fat wires...
fulcrum2 is offline   Reply With Quote
Old 05-03-2011, 06:44 AM   #2076
ralphierace13's Avatar
Originally Posted by CHRISP76 View Post
What is the difference with the new clutch? Have I missed something?
the new pressure plate will ensure the flyweights dont shoot out past the pressure plate, some guys running a big clutch gap with a loose spring are finding the flyweights shoot out past the pressure plate and cause slipping.
RALPH FORTUNATO
MUGEN SEIKI MRX6 TEAM DRIVER
Futaba 4PK-S-R, Novarossi Team Driver, CONTACT TIRES
Byron Fuel, Veytrex Desgin Labs
2014 R.O.A.R. REGION 1 CHAMPION!!
ralphierace13 is offline   Reply With Quote
Old 05-03-2011, 07:40 AM   #2077
max_chen's Avatar
Send a message via MSN to max_chen Send a message via Skype™ to max_chen
i already seen in Taiwan.It looks very well.
High Performance Exhaust System by SSTECH.
www.sstech-racing.com
My facebook http://www.facebook.com/#!/profile.php?id=100000783788369
APlus adjustable clutch system(ACS Clutch)
max_chen is offline   Reply With Quote
Old 05-03-2011, 08:33 AM   #2078
Roelof's Avatar
That is not the advantage of the new clutch. Normally the flyweights have to move forward over the pin on the flywheel. Because the flyweight is twisting a tiny bit it goes a bit stiff over the pin slowing down the clutch movement, with the new clutch the flyweight stays on position and rotates freely. That will give a faster response on the clutch.
Old 05-03-2011, 09:17 AM   #2079
I am thinking of purchasing rsx sevros to use them with my 4PKS.Are you suggesting the hard case ones or not?
Mtx6,Reds WCS,Protoform,kopropo,contact tires.
tonyhalandri is offline   Reply With Quote
Old 05-03-2011, 11:01 PM   #2080
Originally Posted by Steve Rossi View Post
hey fellas something i learned at the worlds from Sawamotto of Sanwa ....i'm not sure but havn't had issues since .....worth a try...I did see most of the Pro drivers using a heavy duty or home made power lead or the factory ones that KO and Sanwa give you with the radios in the kit....i heard the power loss of a lesser quality lead was causing the problems...
So is that heavy duty wire from the battery to the plug and then from the plug to the receiver or just from the plug to the receiver. Because I dont know if I can replace the lead from the LiFe battery to the plug. And if I do it from the plug to the receiver only will that still have an effect. I wouldnt have thought so. Thanks
Mugen MRX-5, Nitro-X fuel, OS Motors, Sanwa, Blits, Team Titan, ARC R10, www.crccc.co.nz
Mugen NZ is offline   Reply With Quote
Old 05-04-2011, 01:56 AM   #2081
CanyonCarverR1's Avatar
Anybody know when the new front upper arms might be out?
CanyonCarverR1 is offline   Reply With Quote
Old 05-04-2011, 05:32 AM   #2082
MugenDrew's Avatar
Trader Rating: 30 (100%+)
ALL-RITE! Think your on to something here! I have only used JR PROPO heavy duty extensions and either the Intellect from teamepiconline or the Reedy receiver pack. Both of which use excellent construction and come with very high quality silicone jacketed wire.
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 05-04-2011, 06:46 PM   #2083
Woodlands Racer's Avatar
Mugen Drew,
You posted earlier in an answer to someone else that you too had experienced advanced wear on the inner bearings on all four corners. I have been running my MRX5 since they were first released last fall and have had the same experience. I also use the Avid bearings and pitch and replace them at $1 each. However my question is, do you have any idea or willing to venture a guess as to the cause?
Thanks,
Roger
Roger Bourland
The Woodlands, TX
THIRD COAST RACING
Max Power/RC America - Mike's Hobby Shop - SRC Tires/RC America
Getting Faster With Age, Hope to see many more birthdays!
Woodlands Racer is offline   Reply With Quote
Old 05-04-2011, 06:59 PM   #2084
Any idea what the black plastic part mounted in front of the battery opening is? A splash guard?
Old 05-04-2011, 07:18 PM   #2085
Steve Rossi's Avatar
this is so the battery doesn't come in contact with the belt pully under crash .
We will give away a $10 off coupon on purchases over $50 once we reach 800 likes.
https://www.facebook.com/srossimotorsports
SROSSIMOTORSPORTS.COM - OS SPEED - PROTO-FORM - PROLINE - MURNAN MODIFIED -KO PROPO- JUN RC JAPAN - RC AMERICA - SPEEDMERCHANT - EAM MOTORSPORTS
Steve Rossi is offline   Reply With Quote
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 07:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 09:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 08:49 AM
