Old 05-18-2010, 10:16 PM   #181
occ
Trader Rating: 15 (100%+)
Originally Posted by gotmotor View Post
I got mine
Please don't tease us like that. We want to see more.
Or did you just make some MRX5 stickers?
occ is offline   Reply With Quote
Old 05-18-2010, 10:57 PM   #182
aturbotony's Avatar
I got mine
You Got your stickers made!
Tony Thompson / Mugen Seiki USA / RC America / Airtronics / Flashpoint Fuel / Novarossi USA /Jgo paints / DeSoto Racing/ Murnan Modified Motors / Zac Project Tires / My Wife and Kids /
aturbotony is offline   Reply With Quote
Old 05-19-2010, 06:40 AM   #183
gotmotor's Avatar
Oh you'll see this Saturday all I can say is what Mike Tyson said
in the Hangover............NICE!!!
RcTarget~KO~VP Fuel~OS~Matrix
gotmotor is offline   Reply With Quote
Old 05-22-2010, 04:57 PM   #184
gotmotor's Avatar
Nice
Old 05-22-2010, 06:00 PM   #185
Nice
You were blazin' today Matt.
Now I see why!!!!
Rich Browne is offline   Reply With Quote
Old 05-22-2010, 06:20 PM   #186
occ
Nice
Is that a Shepherd??? Just joking.
It looks a bit different to the CAD images. In particular the bar type swaybar that we saw mounted low around and the rear of the bulkheads. The shocktower looks different too.
Still, can't wait to see it in real life!
Old 05-22-2010, 10:08 PM   #187
Roger's Avatar
Nice
Nice Matt !!
Roger is offline   Reply With Quote
Old 05-23-2010, 08:19 AM   #188
Pooh2's Avatar
Send a message via MSN to Pooh2
Nice
That is a shepherd! lol Trust me, I know!
MUGEN MRX5/CONTACT TIRES/DESOTO RACING/TEAM LOGIC
"Since the Bible and the church are obviously mistaken in telling us where we came from, how can we trust them to tell us where we are going"?
Pooh2 is offline   Reply With Quote
Old 05-23-2010, 08:36 AM   #189
Trader Rating: 18 (100%+)
Default MRX5
I have a question abput the new car.
I have a couple of the MRX4X cars and think they are great. My understanding is on the new MRX5 it is using a turnbuckle to adjust front camber.
If that is true, how can you make quick pit stop camber adjustments without removing the body to access the turnbuckles on the new car.
[COLOR="Red"][FONT="Comic Sans MS"][/FONT][/COLOR]BRC358http://www.kamikazercracing.com
nearest barstool
brc358 is offline   Reply With Quote
Old 05-23-2010, 10:05 AM   #190
wingracer's Avatar
Trader Rating: 23 (100%+)
You probably wouldn't want to but if you just had to, you could just adjust the lower pivot ball. Off course, that is going to affect toe and track width too.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 05-23-2010, 10:15 AM   #191
Roelof's Avatar
Send a message via ICQ to Roelof
I think before a final you have to deal with the setup and not while warming up....
Indeed the lower pivot is still available. The upper can be changed in position with different inserts for the front upright making different camber changes while turning.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 05-23-2010, 10:36 AM   #192
Default MXR5
I aggree that you "should" have your set up dialed in before final, but many times as you know there are last minute adjustments that are made sometimes during warm up. If you do need to adjust camber during warm up and adjust it from the lower pillow balls, run your final, and then turn your car if for tech inspection, you could be screwing yourself if your pitman adjusts the lower pillow balls out and then the track width is off to where it may not pass tech inspection.
Granted, the pillow balls would have to be adjusted out quite a lot, but the possibility of not passing tech is there.
Club racing is not an issue of course, but I have seen some tech inspections that are extremley tough, and then some inspections that are a joke.
nearest barstool
Old 05-23-2010, 10:56 AM   #193
Richard E's Avatar
Ö you could be screwing yourself if your pitman adjusts the lower pillow balls out and then the track width is off to where it may not pass tech inspection. Granted, the pillow balls would have to be adjusted out quite a lot, but the possibility of not passing tech is there. Club racing is not an issue of course, but I have seen some tech inspections that are extremley tough, and then some inspections that are a joke.
Eeeeeuh Ö I havenít seen anyone setting front width wider than 265mm. Whatís your point?
Richard E is offline   Reply With Quote
Old 05-23-2010, 11:30 AM   #194
Default MRX5
My point is, how do you adjust front camber without removing the body due to the use of turnbuckles for the front camber of the MRX5
If you come into the pits and need a quick adjustment, the body still has to come off unless you adjust from the pillow balls, which will change the track width
nearest barstool
Old 05-23-2010, 01:40 PM   #195
wingracer's Avatar
If you screw the ball out enough to fail width, you're going to have 30 degrees of front camber. With a normal amount of front track width, I doubt you even could back it out that far.
To me, it's a non-issue. I have NEVER had adjust camber during warm-up. Sway-bars, rake, spoilers, rear toe yes but never camber.
Team Shepherd USA
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 07:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 09:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 08:49 AM
