Old 04-04-2011, 08:11 PM   #1906
Originally Posted by ltrdude View Post
I like that side belt pulley on your car!!
Thanks, I got it from ralphierace13, and I found it someplace in this thread.
It was one way of fixing the stock belt being so long it works great. There are other ways currently to do the same thing.
Seems to work good so I will keep it until it no longer works or the side belt gets shorter.
Desoto Racing, Serpent America, Novarossi, KoPropo, Xceed.
2011, 2013, 2 Time Midwest Series 1/8th Open, Champion
2011 Byrons onroad 1/8th Open 3rd
2011 Roar Nats 1/8th Open, 5th
2012 GLC 1/8th Open Q7 Finish 5th, 2013 GLC 1/8th Open Q4 Finish 7th
Vector03cobra is offline   Reply With Quote
Old 04-04-2011, 10:36 PM   #1907
Dasmopar's Avatar
Send a message via AIM to Dasmopar
Originally Posted by Vector03cobra View Post
Your last line is brilliant...."find the fastest guy at the track and ask him."
Things i have learned so far on here.
1. there are different cones that can work better or fit better.
2. some think all the mugen parts and any cone just work.
3. post a picture of anything but stock parts and that must be the problem.
5. explain something technically and lose people even more.
and the last one...."find the fastest guy at the track and ask him."
Its really not a big deal, I have learned what I needed and thats great because thats what this forum is for.
And with Brian Berry not racing this year that only leaves me as the fastest mugen guy currently. errr I mean guy with a mugen car.
I will show Brian it, along with Paul C. and Josh C. I am sure they will point me to a Cone first also.
You forgot Lon Burling II ! I recall putting 140 some laps on you at the fort. lol
I also run the NR flash motor with the mugen clutch and had to sand the cone down to make the clutch work. My guess is the newest Flash motors come with a different cone than the old ones and thats our issue. The first post after your first post on here jeff had a part number listed for a cone. Which cone was that? After reading all this I think the gap between the flywheel and bearing is the main issue.
Lon Burling II
Capicorn, Serpent America, Novarossi, Enetti tires
Chicky fan club member #11
Dasmopar is offline   Reply With Quote
Old 04-05-2011, 06:31 AM   #1908
YBSLOW's Avatar
On a different note.
My Tugnsten Battery tray/weight will be done tomorrow night.
I will take a picture of it to show you all.
The normal brass weight is around 40. In FT Myers my car was 150g light
My car is now 170g light most of it is drive line. and whats not is just good planing. I will be replaceing the 170g mostly with a Tugensten battery plate.
Should be pretty neat, the lightness of my car is not from a lipo battery it would be even lighter 220g or more with a lipo.
Anyways I thought I would share some of you might think its pretty trick.
Where did you find the tungsten material?
Thanks,
Brad
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source
POWER MASTER Fuel,
Protoform Bodies, Avid Bearings
YBSLOW is offline   Reply With Quote
Old 04-05-2011, 08:19 AM   #1909
MugenDrew's Avatar
Trader Rating: 28 (100%+)
www.eaglealloys.com They KICK@ZZ!
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 04-05-2011, 08:54 AM   #1910
DS Motorsport's Avatar
Thanks!!
Are they also able to machine it, a lot of companies don't know how to do it?.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 04-05-2011, 09:26 AM   #1911
YBSLOW's Avatar
I'll check it out............
Thanks!!
YBSLOW Racing
POWER MASTER Fuel,
Old 04-05-2011, 09:36 AM   #1912
MugenDrew's Avatar
Originally Posted by DS Motorsport View Post
Thanks!!
They will make you any size stock that you want. I can not answer reguarding machine work.
Just a note. We stopped using tungsten for crank slugs awhile ago, stuff can be pain in the arse to weld. We are using a material that is called "heavy metal". Machines and welds much better.
Old 04-05-2011, 12:50 PM   #1913
I think I contacted them.
Way to much money or I had to buy X amount.
I bought a 4x4x .200 sheet.
it was 185 enough to make 2 chassis weights
I will post where i got it when I get home.
Old 04-05-2011, 01:07 PM   #1914
YBSLOW's Avatar
post some pics of what you made as well.............how much did it weigh when it was done and how thick did it end up being?
Thanks!
YBSLOW Racing
POWER MASTER Fuel,
Old 04-05-2011, 01:26 PM   #1915
Thanks!
Sure thing.
Pretty excited just to show it off.
I also made mine a tiny bit thicker then the brass one I had, there was a little room to do this, and i wanted all the weight i could put in that location.
Old 04-05-2011, 02:14 PM   #1916
chicky03's Avatar
Send a message via AIM to chicky03
I suppose I can look at it even though you run a mugen
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 04-05-2011, 02:55 PM   #1917
How did you make it in here, I thought you would burst into flames in non serpent threads.
I start Name draopping and all kinds of people show up
Old 04-05-2011, 07:58 PM   #1918
Thanks!
Ok This started as 4 x 4 x .250
Here are my 2 weights I had made out of tungsten and my brass weight.
The brass weight is 40g
The 2 Tungsten weights are 148 each.
The thickness of the brass weight is 2.0mm
The thickness of my tungsten weights are 3.25
Here are the pictures.
Old 04-05-2011, 10:23 PM   #1919
Dasmopar's Avatar
Baller!!!
Lon Burling II
Old 04-05-2011, 10:25 PM   #1920
Dasmopar's Avatar
By the way I called dibs on the back up battery tray.
Lon Burling II
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 07:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 09:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 08:49 AM
