Old 03-21-2011, 12:35 PM   #1816
thanks to our friends at xray whom have supplied a great guide on car setup which is similar with most modern nitro on-roads, I would suggest you download this .pdf file.
http://www.teamxray.com/teamxray/pro...me=XRAY%20NT1R
xray nt1 set-up book
Mugen needs to release a guide like this......
Everything you need to know about chassis settings and what they achieve is listed on here and took me years to learn. Hope this help......[/QUOTE]
+1 I agree, I use this often, I wish Mugen would offer one with their cars.
I have seen Ralph Burch drive an RC car, It was an amazing thing to watch. So I joined his team and got the same car... XRAY and RC AMERICA
CFowler is offline   Reply With Quote
Old 03-21-2011, 06:35 PM   #1817
tdr170's Avatar
Here are a couple more setup books available for free download from Hudy and Serpent.
http://www.hudy.net/xhudy/products/p...0&kategoria=64
http://www.serpent.com/product/903000/downloads/
tdr170 is offline   Reply With Quote
Old 03-21-2011, 08:09 PM   #1818
Arahawak's Avatar
Trader Rating: 32 (100%+)
Originally Posted by X4 View Post
Hey guys, i'm a bit lost with the ackerman settings on the X5.
Does anyone know that if on the MRX4, i was using the C ackerman block, should i be moving the ackerman setting on the X5 forward or backward to get the C block effect?
C block, from memory is with the least aggressive steering.. And also use Kenji's 2 deg toe out.. Not with the Hudy set up tool..
So I think you should pushing it backwards right?
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 03-21-2011, 09:33 PM   #1819
choisan's Avatar
my friend modified his mrx4x by using the floating bracket of the 5, i name it mrx4.8 or vintage 8
choisan is offline   Reply With Quote
Old 03-21-2011, 10:00 PM   #1820
X4
X4's Avatar
Pushing it backwards will make the steering arms more parallel which then both tyres will turn equal amounts, which also makes it more agressive and have more tyre scrub.
Correct???
X4 is offline   Reply With Quote
Old 03-23-2011, 02:06 PM   #1821
ltrdude's Avatar
Trader Rating: 29 (100%+)
Default new upper arm plate
I am deleting the post
ltrdude is offline   Reply With Quote
Old 03-23-2011, 02:08 PM   #1822
ltrdude's Avatar
Default upper plate
I have a new CNC Mill ,Its alot of fun.In case you are wondering that is a 4MM turnbuckle.My assembly as far as arm,ball end and turnbuckle weighs the same as the stock mugen set-up
Old 03-23-2011, 02:24 PM   #1823
Pooh2's Avatar
Send a message via MSN to Pooh2
I don't run Mugen anymore but... you guys are killing a really good car with all these mods. Mugen has always made great cars and I don't think the 5 is any different.
Don't hit, won't break. That goes for any car.
MUGEN MRX5/CONTACT TIRES/DESOTO RACING/TEAM LOGIC
"Since the Bible and the church are obviously mistaken in telling us where we came from, how can we trust them to tell us where we are going"?
Pooh2 is offline   Reply With Quote
Old 03-23-2011, 03:08 PM   #1824
ltrdude's Avatar
Default front end
I am kicking myself right now,I am not going to post pics of parts I make any more .I will just have people test them for me or I will test them myself when My track opens.I am making stuff that is needed to improve the car.And only parts that racers have given feedback on.I put alot of time and effort in things that I make.I am not trying to ruin the car just make it a little better.If I knew how to delete the picture I would.
Old 03-23-2011, 03:50 PM   #1825
Riketsu's Avatar
Send a message via AIM to Riketsu
I guess it was really dumb on Mugen's part to replace a Pivot Ball that has around 5mm (diameter) thread with a 3mm rod and expect it to be just as strong...
Hope Mugen addresses this problem for all of you MRX5 drivers.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 03-23-2011, 05:15 PM   #1826
West03's Avatar
+1. Its a race car not a bumper car. Design to go fast not to withstand smashing into things. 1/8th scale on-road is the premier class in ic racing, what did you want mugen to do, build a tank which is heavy and slow?
EGA . MUGEN SEIKI (MRX5 WC) . MMI . SANWA . MURNAN MODIFIED
MRCCR - MELBOURNE RADIO CONTROL CIRCUIT RACING
www.mrccr.com.au
West03 is offline   Reply With Quote
Old 03-23-2011, 05:39 PM   #1827
CanyonCarverR1's Avatar
Originally Posted by ltrdude View Post
I am working on a new plate that is threaded.This gives more room to play with between the rim.
Please keep your updates comming, some of us like to hear them. I wouldn't mind trying a set when you're ready to sell some. PM me when ready please.
I would like some additional feedback; if the front corners are now holding up to more impacts, what other parts are you seeing breaking during frontal impacts? In other words: what's the next weakest link?
Cheers!
CanyonCarverR1 is offline   Reply With Quote
Old 03-23-2011, 05:54 PM   #1828
West03's Avatar
Cheers!
On impact the arms break to reduce the energy from that impact. If these parts don't flex enough or break then that force travels to the bulkhead and the chassis.
So to answer your questions, bulkheads and chassis, two of the most expensive parts the car.
www.mrccr.com.au
Old 03-23-2011, 06:51 PM   #1829
ralphierace13's Avatar
west y do u have such a problem with trying something that might work alittle better no one said u have to change yours, sorry we dont all drive as good as u, mugen made a great great car but it has a weak spot thats above and beyond the normal limits to some of us, its not high speed crashing were concerned about, and its not the arms, its the ball end that is very fragile even at low speed impacts.. and at low speed impact u not damaging the chasis and bulkhead so have no fear. plus the car is way under weight so dont worry bout a 4mm tie rod weighing the car down or slowing it down. skip over the post about the upgrades and it wont bother u. also y are people that dont even have a mugen and dont know what were talking bout posting on here i dont get it, and i have said this before ill take the cost of changing a bulkhead or chasis that might bend but not cause me not to finish a race as long as i can finish and not cause of a stupid lilttle thing that could of been corrected.... dont let it get to u west some of us want to try it, u be ok....
RALPH FORTUNATO
MUGEN SEIKI MRX6 TEAM DRIVER
Futaba 4PK-S-R, Novarossi Team Driver, CONTACT TIRES
Byron Fuel, Veytrex Desgin Labs
2014 R.O.A.R. REGION 1 CHAMPION!!
ralphierace13 is offline   Reply With Quote
Old 03-23-2011, 07:04 PM   #1830
Actually I asked for ltrdude's experiences with his mods, not your theories.
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 07:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 09:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 08:49 AM
