Old 02-20-2011, 02:58 PM   #1636
walo's Avatar
Send a message via Yahoo to walo
Originally Posted by MRX4XXXX View Post
Anybody has an opinion?
I think that in my car the rear belt and the pulley almost touch the engine/engine mount. Just assembled it with the kit gears/pinions and 35PLUS21 engine.
I think the distance is about 0.5mm or something???
-X-
You will be fine . That area of the car will not move under norman circumstances. Take a deep breath, you are now the proud owner of a MRX5 . Take it out for a spin and let me know how it feels.
walo is offline   Reply With Quote
Old 02-20-2011, 03:11 PM   #1637
walo's Avatar
The dogbones I do not greese, to much pressure on the pin seems to me it will pressure out all the greese, for sure if the pin is moving up and down in the shaft. I know some people are using a graphite grease spray, it stays dry and so it will not take dirt.
The CVD gets some teflon spray.
If you're interested, O'donnell Racing has a wax lube called O' Lube.
Old 02-20-2011, 05:46 PM   #1638
CHRISP76's Avatar
Thanks for your help guys...
Chris P
MUGEN / NOVAROSSI / MATRIX
CHRISP76 is offline   Reply With Quote
Old 02-21-2011, 06:47 PM   #1639
Default MRX5
Snow cleared off our track friday and got a chance to take out my 5 again . Feels real good to get back on the track . Not 1 glitch and the car ran great . Cant wait to get the new sway bar on it !
Richard Siriano
Brooklyn Hobbies
Team Mugen Northeast
RICHARD SIRIANO
BROOKLYNHOBBIES.COM
MUGEN USA
2011 /2012 REGIONAL 1 1/8TH SCALE ONROAD CHAMPION
TEAM BROOKLYN is offline   Reply With Quote
Old 02-21-2011, 07:49 PM   #1640
sm1nts2escape's Avatar
Trader Rating: 16 (100%+)
You guys are overthinking too much. The car isnt glitching cause of a tight radio box unless you are using a old am radio. They are having problems with the clutch heating up. .5mm? cmon guys. Anyways how does the car handle compared to the x4? I want one. Thinking about getting one and making a trip to blue diamond twice a month for fun.
sm1nts2escape is offline   Reply With Quote
Old 02-21-2011, 08:12 PM   #1641
CanyonCarverR1's Avatar
Richard Siriano
Brooklyn Hobbies
Do you have the part number for the new sway bar?
CanyonCarverR1 is offline   Reply With Quote
Old 02-21-2011, 08:41 PM   #1642
occ
Trader Rating: 15 (100%+)
I assume he is talking about the three new rear sway bars.
These are the part numbers:
H2134 Rear Sway Bar 2.7mm
H2135 Rear Sway Bar 2.8mm
H2136 Rear Sway Bar 2.9mm
occ is offline   Reply With Quote
Old 02-21-2011, 08:46 PM   #1643
Slo-MTX4's Avatar
Send a message via ICQ to Slo-MTX4
Ummmm so let me get this right you dont even run the car but you know what everyones problem is?
Podified Picco/MRX5/Futaba/Savox
PODIFIED ENGINES/Trackside RC
Slo-MTX4 is offline   Reply With Quote
Old 02-21-2011, 09:05 PM   #1644
Just making a guess. Never had a reciever box cause glitching before. I zip tie all my wires tightly together sometimes taping them together with electrical tape. Never had any glitches before. It may be but I highly doubt it. Just seen you run savox. You know alot of people are having brown outs running those servos? Might try adding a glitch buster or check your battery under load.
Old 02-22-2011, 12:39 AM   #1645
any setups from team drivers avaidable?
thilo-alexander is offline   Reply With Quote
Old 02-22-2011, 05:04 AM   #1646
ralphierace13's Avatar
there are some setups on mugens web site..
RALPH FORTUNATO
MUGEN SEIKI MRX6 TEAM DRIVER
Futaba 4PK-S-R, Novarossi Team Driver, CONTACT TIRES
Byron Fuel, Veytrex Desgin Labs
2014 R.O.A.R. REGION 1 CHAMPION!!
ralphierace13 is offline   Reply With Quote
Old 02-22-2011, 05:53 AM   #1647
MugenDrew's Avatar
Trader Rating: 28 (100%+)
If your driving a four you'll sh-t when ya get a 5 on the track. I did, pulled in the pit lane so I could hoot and holla bout it. The car is badazz. Ran the car at three different tracks with two different radio systems installed not one glitch. I really wish I could get my hands on a car that REALLY has a radio issue. At this point is has been a bad servo, transponder, receiver, battery, wiring ( found chew marks on the equipment, stuff had been installed with a hammer and a vice). Dont over tighten the piviot ball that screws on to the screw for the brake rods slider. Mount the receiver to the cover with one 5-8mm wide strip of "both side tape" rite down the middle (so the receiver is not trying to brace the cover), make sure the plugs are in the well of the box. Neatly wind the wiring up in there and let it rip.
Disregard the .6mm gap in the book, unless you like frying clutch discs ( makin lots O heat). Try this .3-.4 gap, .1 end play, MSR spring 1mm to start, drill the fly weight at the dot furthest from the hole for the pin to 3.5mm. Not enuff or ya put the spring into coil bind to get what your after: drill the hole to 4mm and start over at 1mm on the spring.
THE CAR IS A ROCKET
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 02-22-2011, 06:04 AM   #1648
THE CAR IS A ROCKET
Thatīs good info, thanks. I own a 4x and am looking to get a 5 but Iīm forcing myself not to due to the amount of spare parts and 4x stuff I already have. Can you do a rough estimate on how faster the 5 is compared to the 4x in terms of lap times? i.e. on a 20 sec mid speed track.
nosepick is offline   Reply With Quote
Old 02-22-2011, 06:12 AM   #1649
MugenDrew's Avatar
OOPS forgot. Get your self a H0855(ten in the bag) two H0867 and which ever H0181-a,b,c,d you need to make a spacer 1.5mm thick. 1.5mm puts the ball where it is with the kit stock stuff. Replace the the ball ends on the front upper arms with this stuff. It won't hurt you feelings or your wallet as bad when you wack something.
Old 02-22-2011, 06:31 AM   #1650
RC MARKET's Avatar
KM Released 2 new option parts for MRX-5
RC MARKET is offline   Reply With Quote
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 07:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 09:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 08:49 AM
