MUGEN SEIKI MRX5
#1606
Just got an email back from Koji Sanada (Mugen Seike Japan). From what I can gather, moving the receiver to the other end of the radio tray has nothing to do with cooling the clutch. I won't go through his entire email, however it appears they are trying to solve the radio interference problems with the receiver being close to the clutch. He also mention that mounting the receiver on the left side of the fuel tank, it is more then likely that fuel will enter the receiver and they are also working on some countermeasure to solve this.
#1607
The receiver box section has been cut off the mold?
#1608
I would go for the MRX4 setup, just a stand up servo with on the side the receiver. I do not think someone can notice the difference in a lay down or a stand up servo.
#1609
The only problem i had was the older Futaba SS recievers were to bit to fit inside the box properly due the the antenna bulge and when you screwed the box closed it put pressure on it and it lost bind. As soon as i went to the new thinner version and with no buldge i have had no problems at all.
#1611
i as well would not switch my rec box to the other side, u not going to find more noise vibration and heat then being next to a pipe!!!
i just ran today my second mrx5 kit i built over the winter and not 1 problem today guys like i said i have been in a race and got a glitch when i got to the pit i have found something loose everytime!! so make sure every thing has thread lock on it
#1612
Radio Tray
Here is a pic of the new tray.
#1613
Huh ?? what's that ?
That's an old radio tray from mrx4 era, isn't it ?
I think its stupid to use open tray system next to fuel tank. The fuel spill directly landed on the receiver, and the cables routing probably can hit the side belt or front belt.
I dont believe a clutch bearing can produce signal disturbance to receiver. Why ?
1. it's 2.4 GIGA Hertz, way way out of range for metal friction can produce radio interferences.
2. my friends who race modified electric cars, they put their radio receiver next to brushless & brush motor, and they have no problem with radio interferences. Brushless motor and brush motor spins at 40,000 - 48,000 rpm.
My suggestion to mugen :
1. make bigger capacity radio box so people can put extra damping foam and dont have to squeezed all cables.
or
2. go back to old style like roelof said.
or
#1614
#1615
for anyone that has put the 4 front end on the 5...
Are you pulling the 1mm shim at the hub/steering arm connection and mounting the steering ball directly to the hub arm?
Also...does the front upper arm hinge pin still go in the upper position?
#1616
front upper arm
I have a picture of my new upper arm I will be selling.I am waiting for the turnbuckles and the ball ends.The turnbuckles will be 4mm but they will use the same wrench as the 3mm.The ball ends will be aluminum with reverse thread.I should have the rest complete next week to try out.The dimensions are all the same except for the material added behind the pocket for the turnbuckle so you will be able to adjust camber.I am not saying this is going to cure the problems but I know it will make a big difference.JOHN MULLEN J&S Racing
#1617
upper arm
I failed to mention these arms are laser cut out of Nylon 6/6 .It is very strong and its not brittle like other materials.As soon as I get a set done they will be track tested,not by me my track is still under snow and water.
#1618
Not using the spacer under the steering link. I used upper and lower position car felt more stable in lower position.
#1619
#1620
I think what you wrote is wrong.
Here are some idea why some mrx5 had runaway accidents :
1. Receiver heat problem ( no air cooling inside tiny radio box )
2. Vibration problem. Not enough damping between receiver and radio box. If I put very thick double tape foam, the receiver casing actually touch the radio box.
3. Squeezing all cables ( 2 servos, 1 power, 1 transponder ) in one cramped exit hole probably creates electronic noises.
