Old 02-13-2011, 07:37 PM   #1561
Originally Posted by ralphierace13 View Post
no weights im at 2340 i run it like that at the club races
I would rather put myself at a disadvantage at a club race then an advantage.
I think with a Lipo and light wheels you can get the MX5 down to 200-210 under weight. prolly more with a super light body and small tires.
Crazy how light 1/8th scale cars have become.
Desoto Racing, Serpent America, Novarossi, KoPropo, Xceed.
2011, 2013, 2 Time Midwest Series 1/8th Open, Champion
2011 Byrons onroad 1/8th Open 3rd
2011 Roar Nats 1/8th Open, 5th
2012 GLC 1/8th Open Q7 Finish 5th, 2013 GLC 1/8th Open Q4 Finish 7th
Vector03cobra is offline   Reply With Quote
Old 02-13-2011, 08:22 PM   #1562
Arahawak's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Romeo View Post
Weight 2780 full car w/o fuel.
Bro you weight it with new tires or small ones??
Abit too heavy..
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 02-14-2011, 12:29 AM   #1563
West03's Avatar
Originally Posted by Mr-s413bt View Post
Hey Guys,
I have been running the Blitz R09 body ( body of choice at our track ) but my LHS is out of stock. Has anyone tested the R09 against the R11?
Glenn, I happen to try the R11 on the weekend and have to say it's not bad. Mounted the body at 18mm and found it had some push on corner entry. Moved the body to 20mm and it starter to turn in better. I think this body will work better mounted at 22mm.
EGA . MUGEN SEIKI (MRX5 WC) . MMI . SANWA . MURNAN MODIFIED
MRCCR - MELBOURNE RADIO CONTROL CIRCUIT RACING
www.mrccr.com.au
West03 is offline   Reply With Quote
Old 02-14-2011, 08:28 AM   #1564
ralphierace13's Avatar
yes i run lightweight tires, lipo, alum axles, tit here and there and superlight body i rather have the advantage..
RALPH FORTUNATO
MUGEN SEIKI MRX6 TEAM DRIVER
Futaba 4PK-S-R, Novarossi Team Driver, CONTACT TIRES
Byron Fuel, Veytrex Desgin Labs
2014 R.O.A.R. REGION 1 CHAMPION!!
ralphierace13 is offline   Reply With Quote
Old 02-14-2011, 10:53 PM   #1565
West03's Avatar
I am almost certain that the runaway issues with the MRX5 is related to an increase in frequency noise which effect the receiver. With the receiver mounted so close to the pinion gears and the increase in frequency noise like a bearing which has become a little rough could be triggering the runaways. It could be the reason why Mugen has redesigned their radio tray to include the receiver being mounted in the opposite end.
I had a few runaways during practice at my last club day. After noticing one of the bearings was a little rough, I replaced the bearing with a new one. Since then I have not had an issue all day. I had notice that runaways happened when my trust washer and clutch bearings where at its oldest. At major events, new clutch bells and clutch assemblies are used therefore I have not experience any problem then. They are also more regularly maintain during every run. What do you guys think?
www.mrccr.com.au
Old 02-15-2011, 02:03 AM   #1566
csterikim's Avatar
Originally Posted by CHRISP76 View Post
Are any of you guys using aluminium pulleys? I'm thinking about getting a set of CSO ones. Any thoughts?? Thanks...
Dear
I ordered CSO options for my MRX 5 because I had MRX4X with CSO Pulley sets and They are reliable to keep pulley tention and save maintenance time when I have race in Club race...
It is depended on you.
Some Drivers recommend only stock parts but I had some problem with plastic pulley and lost front belt teeths.
When I installed CSO pulleys in MRX4X, I never had problem with belt and pulley..
Mate !!!
Any one know the replacement parts for H0136B part for front turnbuckle end..??
I broke front parts alot!! when I race my MRX5.
Also I tried to find H0136B part but It is included in H2112 part.. I want to get only H0136B for changed part..!!
Please Help me !!
I can not upload parts picture because RCTECH have restrict upload pictures with my user level...
If you have part list then you can find part list number
Thanks...
csterikim is offline   Reply With Quote
Old 02-15-2011, 02:56 PM   #1567
walo's Avatar
Send a message via Yahoo to walo
Originally Posted by csterikim View Post
Dear
Mate !!!
Please Help me !!
Thanks...
Hello, I think you're right. Maybe you can try part #H0147F. This is from the MRX-4X manual and you can find this on the rear upper arm. They may sell it separately under this part # (H0147E). How is the performance of the car so far?
walo is offline   Reply With Quote
Old 02-15-2011, 11:17 PM   #1568
Dasmopar's Avatar
Send a message via AIM to Dasmopar
So when you go to a bigger race the car is a whole different animal? That doesn't make a whole lot of sense to me. Also we on a club level kinda go by a gentleman's agreement meaning you play by the rules and I will do the same without us having to check over each other all the time. I have run lite at a club race I'm sure but not on purpose or any where close to that much.
Lon Burling II
Capicorn, Serpent America, Novarossi, Enetti tires
Chicky fan club member #11
Dasmopar is offline   Reply With Quote
Old 02-16-2011, 12:45 AM   #1569
Hi there,
little question about mounting a body on the front end. How do you guys set-up the body height up front? Do you slam the body all the way down, let it rest on the bumper and then put the pins in the posts to have some up/down play? On the 4 we had body posts which had a support for the body and we adjusted the posts for the given body. Any tricks like that on the 5?
If I take a new body which I had already prepared for the 4 and slam it down up front I have to trim the front lip another 5mm. Right to the point where it almost becomes a sharp edge and looses some stability. Is this the way you mount yours?
Thanks for your feedback and best regards, Stefan
fulcrum2 is offline   Reply With Quote
Old 02-16-2011, 01:21 AM   #1570
Phil Trotta's Avatar
Originally Posted by fulcrum2 View Post
Hi there,
You may be mounting the body too far foward ... This is what's causing you to trim so much of the front lip off. On the 5 yo want the font of the body to be 18 mm in front of the middle of the bumper (centerline of car ) the 5 has adjustable pins so if you adjust the pins foward(all four ) and mount the body 18 mm foward of bumper you will be able to try car 3mm back. It's a great tuning option. As long as you have the motor /INS box clearenced Morethan 20 mm foward makes car edgy or erratic. Un stable. Hope this helps. Nyrclive will be putting a video up on this soon. Stay tuned Phil
PHIL TROTTA
Phil Trotta is offline   Reply With Quote
Old 02-16-2011, 01:45 AM   #1571
asw7576's Avatar
Hi there,
I use low profile body post ( serpent allumunium body post ) + thick foam inserted between the body shell and body post.
In theory, more downward position means more front downforce ( and wind drags too ).
I cut the front lip exactly following the cutting marked / cutting line.
Old 02-16-2011, 02:29 AM   #1572
Ah, I see. So you bring the body up a bit from the bumper by using a different body post and avoid having a "sharp" and fragile front edge of the body (maintain a little "skirt").
I find it kind of strange that Mugen does not offer a solution for this like they had on the old car. Am I missing something here?
Old 02-16-2011, 04:12 AM   #1573
i ran the car alot both ways really lite or i just slap in a big 1900 orion batt. and a .30 body and tell u the truth the car is the same i cant tell a diff handles the same to me, yes is it alittle quicker from point a to b oh yes, far as rules lol oh well...
RALPH FORTUNATO
Old 02-16-2011, 04:17 AM   #1574
csterikim's Avatar
Thank you for your response.
I also checked a lot of pages both mugen official site and rctech forum.
But Mugen did not sell any seperated parts for H0147F of MRX4X and H0136B of MRX5.
Some threads in rctech show Xray NT parts for MRX5 but I really do not know the part number.
MRX 5 is the fastest machine but front parts are very very weaker than MRX4X.
I still have MRX4X for only driving test with new electronic parts like as HV servos and Batteries.
In my opinion, MRX5 is faster than MRX4X but more weak. I think MRX5 is more stable in corner and curve way which is only my thought.
Another thing..
Anybody knows RPM Foam Tires??
I saw the tires last club race which had dish wheel.
Usually, I use GRP and Jaco tires. Please leave your opinion. I will order RPM tires for MRX 5.
Thank you.
Mugen MRX4X, JR Z9100t Servos, Nexus HV Servos, Life 6.6V, Futaba 4PK,
,Serpent 966 TE, Associated B4.1, Mugen MBX6 M-Spec, Yocomo YRX-12WE.
Old 02-16-2011, 05:17 AM   #1575
MugenDrew's Avatar
Trader Rating: 30 (100%+)
Another thing..
Thank you.
The a,b,c,d stuff your seeing is the designation for one cavity in a multiy cavity mold. If you have your parts list find the box with the part in it that you need, you get all the stuff in that box. Yes H0136 is the least expensive way to obtain the ball end.
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 07:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 09:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 08:49 AM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
