Old 02-09-2011, 06:06 PM   #1531
Originally Posted by Dasmopar View Post
Is that the one piece motor mount on there also?
Yes.
rwang is offline   Reply With Quote
Old 02-09-2011, 09:21 PM   #1532
Originally Posted by West03 View Post
Arrowmax is the only company that I know of promoting their products regularly, however no one can actually buy their stuff. Been on their websites and have sent several emails to them. I still have not receive a reply after weeks of trying Has anyone else made an order via their website and been successful?
I managed to get in touch with them and I have their price list...I also spoke with Ivy.
Mtx6,Reds WCS,Protoform,kopropo,contact tires.
tonyhalandri is offline   Reply With Quote
Old 02-09-2011, 09:23 PM   #1533
Originally Posted by rwang View Post
JJ says the car drives a bit stiffer due to the one piece alloy radio plate mount, other option parts don't seem to affect car feel. JJ likes the arrowmax optioned MRX5.
Rick
Old 02-09-2011, 09:31 PM   #1534
West03's Avatar
Thanks mate.
EGA . MUGEN SEIKI (MRX5 WC) . MMI . SANWA . MURNAN MODIFIED
MRCCR - MELBOURNE RADIO CONTROL CIRCUIT RACING
www.mrccr.com.au
West03 is offline   Reply With Quote
Old 02-09-2011, 10:22 PM   #1535
Dasmopar's Avatar
Send a message via AIM to Dasmopar
Yes.
Thanks. I didn't get much of a chance to chat with you guys much but I look forward to our next meeting.
Lon Burling II
Capicorn, Serpent America, Novarossi, Enetti tires
Chicky fan club member #11
Dasmopar is offline   Reply With Quote
Old 02-10-2011, 01:59 AM   #1536
Hi there,
just building my 5 and got a question. What is the weak spot around the front upper arm? People are using a longer turnbuckle - what's the point here? Do you want more threads in the arm, or more of the turnbuckle supporting the ball cup which is connected to the upright. I could as well move the OEM turnbuckle more to the outside in order to support the cup.
So in short: Which part needs reinforment?
Thank you, Stefan
fulcrum2 is offline   Reply With Quote
Old 02-10-2011, 02:16 AM   #1537
asw7576's Avatar
Originally Posted by fulcrum2 View Post
Hi there,
Thank you, Stefan
the current turnbuckle quite easy to bend and come off.
The newer revision probably will be made from 4mm thick turnbuckle and 6mm longer.
For the moment, you can use Xray T2 and T3's turnbuckles ( made from hudy springsteel ) are stronger and longer than the original.
Old 02-10-2011, 03:47 AM   #1538
So the turnbuckle itself will break?
Old 02-10-2011, 04:35 AM   #1539
Phil Trotta's Avatar
Yes. It will snap. I use the mrx4x upper arms and knuckles and the car works very well.
PHIL TROTTA
Phil Trotta is offline   Reply With Quote
Old 02-10-2011, 05:14 AM   #1540
Thanks for the feedback Mr. Hammer
Good to know that the MRX-4 parts could be used in a pinch. Let's see how the 5 works with OEM parts on european tracks with grass infields - maybe we won't have the issue here...
Old 02-10-2011, 06:35 AM   #1541
CHRISP76's Avatar
Are any of you guys using aluminium pulleys? I'm thinking about getting a set of CSO ones. Any thoughts?? Thanks...
Chris P
MUGEN / NOVAROSSI / MATRIX
CHRISP76 is offline   Reply With Quote
Old 02-10-2011, 07:12 AM   #1542
YLLIB's Avatar
NO, save you money, it just a personal preference. No advantage and more belts that can and will be damaged. Plus the gears cannot hold up from pitting from garbage of the track when running no matter if there harden or not, IMO. Put your money to better things for the car,
YLLIB is offline   Reply With Quote
Old 02-10-2011, 07:53 AM   #1543
choisan's Avatar
i am using the cso's pulleys, they are runing fine so far. no belt stripped ever. nice quality.
i used the belt tensioner together.
choisan is offline   Reply With Quote
Old 02-10-2011, 01:59 PM   #1544
tdr170's Avatar
Default Pulleys
Yes to the aluminum pulleys, I changed the front 16 (mrx4x) to the aluminum pully at the beggining of this season and have not changed it since.
The pully still looks as good as the day I put it on, along with a front belt tensioner and I have not stripped a front belt since.
Most guys here run the Titan pulleys from Serpent readily available a good price.
I had a couple of guys here say they were not worth it and now they too have full aluminum pullys.
Take from this what you will but I believe they are a good choice.
tdr170 is offline   Reply With Quote
Old 02-10-2011, 03:20 PM   #1545
Rocketron1969's Avatar
Trader Rating: 29 (100%+)
Thumbs up alumnium pulleys
iam running cso pulleys on my mrx5 i like them cause they clean out very well but if u get a rock good by pulley its just preferance thx have fun
Rocketron1969 is offline   Reply With Quote
Adelaide Nitro On Road Littlehampton Kodak Hodak Australian Racing 2503 09-19-2014 07:08 PM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 09:24 AM
Mugen MRX5? straightaway Nitro On-Road 140 08-23-2007 08:49 AM
