Old 01-31-2010, 08:22 AM   #1
Default Clutch set up
I wondering about the clutch set up.
So is it most powerful engine need to set the clutch spring less pre-load, in order to avoid clutch shoe burnt out?
Less powerful engine with more pre-load?
I have Velox V10, the clutch made me sick. the thurst bearing keep on burnt out. I tried all the clearance and spring pre-load setting with same result.
beebone is offline   Reply With Quote
Old 01-31-2010, 08:51 AM   #2
helivaguy's Avatar
Trader Rating: 42 (100%+)
here is some good reading to help you out...
The only thing that is "still like new" is the box it came in..
Only a half gallon through it my Ass!
helivaguy is offline   Reply With Quote
Old 01-31-2010, 09:04 AM   #3
DS Motorsport's Avatar
It depends on the engine's powerband how much preload you will need.
It is also up to the driver, most experienced drivers will use more preload because it makes the car harder to drive, more aggressive.
I don't understand how you are able to burn out the thrustbearing, if you use quality grease it should outlast an engine. Probably too much endplay.
If you burn out a clutch shoe you are running too much spring tension, or the clutch isn't shimmed out properly so the shoe doesn't have full contact with the bell.
DS Motorsport is offline   Reply With Quote
Losi 8ight Best clutch set up ? Ramirez24 Nitro Off-Road 70 05-10-2010 06:25 PM
what kind of clutch set up is this Graphite07 Nitro On-Road 7 10-20-2009 02:37 PM
Mugen clutch set up in a Losi 8 TRIPC Nitro Off-Road 22 04-07-2009 08:03 PM
Clutch set up help! DirtRacer Nitro Off-Road 6 01-01-2008 04:39 AM
novarossi 21bf with 1/2 gallon on it/w clutch set up mxracer458 R/C Items: For Sale/Trade 12 04-05-2007 07:11 PM
SEO by vBSEO 3.5.0
