Capricorn LAB-C01
#871
http://kamikazercracing.com/proddetail.php?prod=LABC01
from Feb 10-16 sale on Capricorn Lab sedan $575!!!!!!!
#873
Only one request i got for you Capricorn distributors. Please make sure people are aware that the manual is outdated. Maybe a sticky here or on your websites. Yes it is for advanced users (in terms of real engineering it is actually one of the easiest designs I have seen) but wrong instructions are wrong instructions and even if you got a pretty good clue of what the parts are, you can be thrown completely off track.
by the way, the bottom ball cup you have in the photo is different to the one the manual shows. I have installed the one the manual shows and the length of the shocks is still correct. i dont think i can change it now. the plastic is pretty tight.
I assume you have a longer ballcup in the kit?. I'm currently running the medium ballends on my shocks instead of the short ones.
#874
Sorry but the complexity of these cars is laughable to someone who has worked with some serious engineering drawings for 2 years. I know very well what I am doing. I can put this thing together with my eyes closed if i didn't have a manual giving me wrong instructions. At the very least an engineer is supposed to trust 100% the drawings of the manufacturer. How am i supposed to guess that the manual is wrong? In my scenario, either the manual was wrong or parts were missing form the kit. There is no third option. Thanks for the feedback though.
Pass you soon...
(speak you in a few weeks...)
#876
We Are very sorry abouT the instruction manual of the kit
The first release 1.1 is in the kit but after we make 2 update
The 1.3 with the new damper spare parts and other trick is in download website
http://www.capricornrc.com/capricorn/cms.php?id_cms=7
#877
i just checked 1.3 on your site and it still shows the wrong parts.
it shows two rubber wipers for the shaft instead of one. It still shows the old plastic washer, it still says that the metallic washer is in bag S when it was in bag D in my case and last but not least two items have the same part number CAP16003. All that just on page 5 which is the first thing you do. Not exactly encouraging.
#878
#880
one more question about the shocks.
i have assembled them as the instructions state down to the last comma. the dimensions are accurate and i have triple checked everything.
the problem i have is that the nut at the end of the piston inside the shock actually protrudes into the rubber gasket on top when the damper is fully compressed. at the same time, having installed the springs, they are not a secure fit on the dampers. i mean the springs wobble about even when the stiffness ring is adjusted to the specifications.
is all this normal? when the dampers are installed in the car are they slightly compressed so the spring sits tight and does the movement of the suspension arms prevent the nut at the top of the shaft from puncturing the rubber gasket inside the damper?
#881
#882
Mine are 66.7mm in the front and 67.2mm in the rear.
However on the front shocks I use an Xray lower ballend since I ruined the original one. But I actually like the Xray ones better, as you can see these cover the entire thread of the shock shaft, were the rears are still exposed.
Fronts:
Rears:
It's normal for the spring to be loose, the "stiffness ring" doesn't change the spring's stiffness but is used to set the ride height.
It will be normal when the car is put onto it's wheels.
#883
thanks. the shocks look good then.
i just hit another major problem and i can't do the diffs.
the overall quality of this kit so far has been a joke.
one of the diff shafts has a hole that is not big enough for the pin to fit in.
i checked it against the other shafts and one of them definitely has a smaller hold than the others and no pin fits in. looks like a manufacturing fault.
the manual has more mistakes too. the screws needed to mount the pulley on to the front diff are not allen. no allen screws match those holes. instead they have some philips head screws that do the job but there is no description of them in the manual or in the screw chart.
seriously come on now. someone is taking the piss.
#885
i can't keep at it. i need a replacement part at this point. one of the drive shafts for the rear diff does not have a hole big enough for the pin to fit. if i can't fit the pin then obviously the shaft will come loose. it's a manufacturing fault.
i'm on hold until they send me a new part.
