Capricorn LAB-C01
#306
#307
More ?'s than Answers
Why should I?
Oh Drat...............gonna have to dig out the Manual,......And,.............. the Manual doesn't give you all the necessary specs, (only lists a choice of 25 or 26 T outer middle shaft sprockets, lists # of teeth on all but Front and Rear Diff Sprockets), I'd have to obtain the remaining info then calclulate! (Could it possibly be the same as the NT1?),...... I'll get back to ya!
#309
Its the same as the nt1.
#310
does anyone tried the soft susp set?should be good with bumpy surface...
#313
someone nice enought o count the teeth in the rear diff?
is it 42t?
is it 42t?
#315
middle shaft inside 19t
middle outside 25t
main shaft outside 18t
main shaft inside 20t
rear diff 41t
Today I tested the car more, and liked it more. First, I changed the rear camber link position to the longest, and car instantly had more grip at rear, especially out of the corners. Then I tried the rear roll center eccentrics to the lowest position, and rear end had even more grip, but it resulted in some high speed understeer. Then I layed down the front shocks, so it had more mid corner steering. At the end of the day, it was all good and I was putting in really consistent laps. Tires were xceed 40 rear 37 front, and they were down to 52mm and still going well.
