Capricorn LAB-C01
#1801
Hi everybody,
Just wanted to say the C02 Worlds Edition is ready, Cap will probeably announce it one of these days officially.
Only 100pcs is produced.
Upgrades are:
All suspension parts in hard plastic version
New belts
New spring pipe support
Weight under tank
F1 sway bar
New 2speed shaft
Upgrades are:
New belts
Weight under tank
F1 sway bar
New 2speed shaft
#1803
These are nice .... More good quality stuff comming from our friends at Capricorn. Nice body too.
http://www.redrc.net/?s=capricornrc
Niko has these if you need them....
Just drop him a line. Good guy to deal with!
[email protected]
BM
[email protected]
BM
#1805
Noce, are you collecting money for a BSC-1?
#1806
Cap Shock LBS
Dear all could some post the Capricorn Shock pressure in LBS.
#1807
I've made a sheet some time ago: http://www.dsmotorsport.nl/downloads...values-copy-2/
Are you sure of your values? The white springs seem to be harder then the red one. Or does it depend on the number of turns?The front blue spring also doesn't fit into the original Capricorn sheet.
#1815
Put the different springs together end for end in a vice or between fingers; then press together and measure or observe which spring changes length the most, to test which is harder or softer.
I hope that this has helped.
Kindest regards,
Lars.
