Old 01-12-2010, 06:37 PM   #1
forrestboy's Avatar
Trader Rating: 16 (100%+)
Default which fuel is better
O donnel or byron for a .12 onroad engine?
Team C Racing
forrestboy is offline   Reply With Quote
Old 01-12-2010, 07:16 PM   #2
Both of these fuels are good! But i say Byrons i have been running it for a long time and it is a great fuel! Good engine protection and it makes awsome power!
Jeremy Cupps
Sponsors are
Mugen Seiki, NovaRossi Engines, Enneti Tires, Byrons racing fuel, Airtronics, XceedRC, Mikes HobbyShop Porter Texas, Global Hobby Distributors, Avid Bearings, Paint by Smiley, and my wallet!
J-MAN is offline   Reply With Quote
Old 01-12-2010, 07:37 PM   #3
shokyo's Avatar
i use o'donnell 16%...internal engine clean...
its better u get fuel that ur LHS supply...easy to get.
FB= Yuneef Shokyo
~///~ Futaba 3PDF FM 75.67Mhz + Futaba 3PKS 2.4 GHz ~///~
~///~ Mugen Seiki MTX-4R + LRP spec 3 je(dah jual), STS DX3R, OS SPEED TUNED (dah barai),Picco edo (dah barai), Picco IDM (dah barai), Nova Max (dah jual), Nova NS3,Nova 353 09, Nova .12 3ST 09 ~///~~///~ Serpent 960 + Nova Flash .21 ~///~
shokyo is offline   Reply With Quote
Old 01-12-2010, 11:15 PM   #4
Toh WL's Avatar
Any fuel which does not require after run oil is good. Sometimes you can forget n the next day u get corroded & rusting engine.
Toh WL is offline   Reply With Quote
Old 01-13-2010, 08:37 AM   #5
trickd122's Avatar
Default Best fuel
Based on my experience, GOOD fuel or the BEST fuel is one that provides the most protection. The needs to be a good blend of castor and synthetic. typically fuels that exhibit such qualities will coat the Piston and headbutton with the dark brown to black film. The quicker the fuel does this the better the fuel is. Odonnel is good, I have not ran the new Byron blend so can't comment, however the one that I do run, J-Tech racing fuel, I have found to be the best. It remains un affected by Cold weather as low as (I live in FL)37deg temp or high 90+ degrees. Most important to me is that it is consistent form batch to batch.
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 01-13-2010, 05:15 PM   #6
wizby's Avatar
I have less engine problems with MAXY'S
wizby is offline   Reply With Quote
Old 01-13-2010, 05:46 PM   #7
Paulie Bee's Avatar
Depending on how much experience you have with your engine tuning my recommendation is Tornado. It may cost a little more but VERY worth it. It is the most consistent fuel I have run in many years of racing. No other domestic fuel can compare with there quality controls in my humble opinion.
If your looking for a high quality fuel for a high quality motor this is for you.
If you want your motor/bearing to rust after one bottle then buy the other stuff.
Car 16 Regular Blend
For novices and slightly more experienced racers. Top capacity for maximum racing fun. Low cost. Special dedicated oil blends ensure maximum engine protection. On and off-road racing proof. Clean combustion ensures low maintenance. Fit for all engine types. Minimal foam accumulation. Special additives prevent corrosion and oxidation. Use of afterrun for maximum protection during storage
10% NM
Super power
< 1% Additives
Special additives optimize fuel’s combustion properties
12% Oil
Special dedicated oil blend for maximum protection resulting in prolonged engine life. Special blend based on synthetic oils and ricinus
77% Methanol
Car 16 Competition Blend
For experienced racers. Maximum capacity due to lean engine settings
Note: incorrect setting may result in extra engine wear out due to lower oil content. Acceleration enhancer provides higher acceleration. Maximum engine protection in heavy conditions. Clean combustion ensures low maintenance. Minimal foam accumulation. Special additives prevent corrosion and oxidation. Use of afterrun for maximum protection during storage
16% NM
Super Plus power
<1,5% Additives
8,6 % Oil
Special dedicated oil blend for lean setting combined with maximum protection based on ricinus and synthetic oils
73,9% Methanol
....again just my opinion.
Good Luck,
Thank You...
PT RC Racing Oils
Paulie Bee is offline   Reply With Quote
Old 01-19-2010, 02:11 PM   #8
hkboy's Avatar
I have been using Tornado Fuel for a long time in Asia. I also tried other fuel, but I found that Tornado is the one that is most consistent tin after tin.
I understand you can pick them up in North America now, so I suggest you to try. Not that I am saying the other fuel is no good, but this is the fuel I trust. Hope that helps
Shephard, Tornado Fuel, Sanwa, Corally, GP Battery, Team C
hkboy is offline   Reply With Quote
Which fuel is best and why?? Reevo Nitro Off-Road 72 11-17-2008 06:25 AM
Which fuel do YOU use? XER987 Nitro On-Road 128 08-10-2007 08:20 PM
Nitro Fuel -- Which one is better ?? Sledder Electric Off-Road 18 05-27-2005 04:54 AM
SEO by vBSEO 3.5.0
