Kyosho V-ONE RRR Shimo Edtion
#211
i like the radio box.
#214
I noticed there wasn't an English version of the RRR Shimo Setup sheet so I translated it and posted it on the website.
http://kyoshoamerica.com/downloads/m...lank_setup.pdf
#215
What's the different effects between ackerman 10,11, &12?
#216
younghovaa you have a pm
#217
It is the distance between holes: 10mm, 11mm, 12mm.
The closer the holes on the servo saver, the less ackermann efect you have.
Ackermann efect has the most influence on low speed turns.
If your car steers well off-power but pushes on-power, use more ackermann and reduce dual rate. The opposite situation less ackermann and more dual rate.
AFM
AFM
#219
#220
Deco choice
Hey wanted to know if u guys are running w/ servo down or upright?? And why?? Or jus choice??
#221
#222
i run the KO half height servos though and NIMH, when I ran upright i mounted my lipo reg on the bottom of the throttle servo. there was no noticeable difference in lap time. running nimh though, i think the cg is higher than it should be with upright servos.
I could see a difference maybe if you had full servos (10g heavier each).. but the cost to the avg racer of having the linkage out in the open for a side collision is too high to me. i've done as others and moved my receiver to the pipe side for weight (ko micro isn't much) but it also protects it, not that i have ever had a runaway or anything from a hit.
basically, look elsewhere unless you have it laying around.. the evo2/shimo top deck is better than the previous versions unless you have something else like the KM or capricorn for the xray tank. the reason its better is because starting with the evo2 they started incorporating more flex in the front of the car (really shown with shimos worlds car having that two piece front deck, the fact that he used wheel discs and other random attempts to get the car to steer at the worlds)
#224
i agree it adds more complicated linkage.. and also the servo is exposed.. so just hope u dont get t-boned.
plus the right side of my car is heavier than my left. so it works out good.
i run a low profile standing throttle servo, and i put weights under it.
i also mount the servo sitting under the top deck, rather than on top.
#225
hi guys!
i want to ask something.
when you set your rear height you set 1+ from that are you seeing in the tool? or 1.5mm?since the chassis has an angle and it is not straight like front.
so 1mm or 1.2-1.3mm more?
