Hop ups V one-r
Hop ups V one-r
Hi I'm new around here....
I would like to Know which hop ups parts should I bought to my V one R.
I had a sirio evo motor, but recenty I buy a NovaRossi 353 and I can't handle the car, especially going out of curves.
I hope you understand me, I'm not really good in English
As far as you losing control of car, please explain more on the handling issue.
Is car spinning out or just not staying on your driving line? Stronger engine may require you to take a different line until you get used to it. Or you may need to get some upgrades that you spoke of earlier to accomodate the extra power the engine produces.
Then again, you may just need to adjust your cars setup. Like heavier shock and differential oil, tighten or losen swaybars. Position of shock on shock towers. Try a few adjustments, one at a time, on car and see if the control becomes better. Do this before buying any major up-grades. This will also help you improve your driving at the same time.
Lastly, tell us more about yoru car and its setup, so we can understand it better.
Yep it starts spining.I only handle it in front lines.
I'll try modify the clutch to be more less agressive??
