Old 12-03-2011, 12:26 PM   #1081
garen's Avatar
Buy a (or rebuild an old) pan car, build it, race it, have fun, go home happy.
bpengines-usa.com fioroni-usa.com motonica-usa.com
Airtronics Avid RC Byron Fuels VOX Engines
VMR Tires - available at http://motonica.ipower.com/store
garen is offline   Reply With Quote
Old 12-03-2011, 01:36 PM   #1082
Default WORDS!
One of the many things I like about Garen, he has a way with words! I don't think you should try to talk car class and driver class at the same time.
Das 1/8th Mopar is offline   Reply With Quote
Old 12-03-2011, 06:24 PM   #1083
Default Car vs. Driver Classes
That's what I was saying. If you have enough drivers, you don't need to be concerned about classes as much. Qualifing will sort things out just fine. But without at least 2 or 3 heats in each class, the car class is the only thing to keep things somewhat even. That's pretty much where the Master's class and the Pan class are in 1/8th gas. imo
Better, more experienced, drivers will always be faster, but with slower (more regulated) cars the difference is less.
(Lon-I'm getting the Spada back!)
aarcobra is offline   Reply With Quote
Old 12-04-2011, 08:16 AM   #1084
Default spread the word
dropping off the flyers you sent me at our local track. i agree the hardest part of racing pans at our track is your face hurts from laughing. however jeff scratching his nose while beating me was kinda different
5italkart is offline   Reply With Quote
Old 12-04-2011, 04:14 PM   #1085
Default truth being!
Jeff was working harder then you think, usually he's scratching some where else! My guess is he was feeling some sort of pressure.
Old 12-04-2011, 05:03 PM   #1086
Default under pressure
must have been from the misses !!! lol !! so how many cars are we up too now? in case you miss pm. your parts are done will ship after holiday rush
Old 12-04-2011, 08:01 PM   #1087
Taylorm's Avatar
Joe, what parts did you make?.this post is BS without pictures?..........And get building on an F1 now!!!!!!!!!!!!
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
Old 12-05-2011, 03:39 PM   #1088
Default pics
tell me how too add pics and i will. i made some of those front end bracing tubes first thought up by lon +ned. keeps my little shop busy
Old 12-06-2011, 09:55 AM   #1089
Dasmopar's Avatar
Send a message via AIM to Dasmopar
You got your F1 in hand yet?
Lon Burling II
Capicorn, Serpent America, Novarossi, Enetti tires
Chicky fan club member #11
Dasmopar is offline   Reply With Quote
Old 12-06-2011, 04:07 PM   #1090
Taylorm's Avatar
......no... was thinking i would receive it today....no dice....hopefully 'morrow......
Old 12-06-2011, 10:19 PM   #1091
Dasmopar's Avatar
I had a fedex package on the truck and on its way to my house today but it never showed either.
Lon Burling II
Old 12-07-2011, 04:03 PM   #1092
Default hoho ho
i can only imgine how many packages are on the road this time of year
Old 12-07-2011, 07:02 PM   #1093
Taylorm's Avatar
.......no doubt....not the best time of the year to order a new kit......the wife is sick of me calling her from work to see if "IT" arrived yet....................Joe......just make a photobucket account and add links to this thread..........i wanna see proof of your skills......
Old 12-07-2011, 07:06 PM   #1094
Taylorm's Avatar
http://www.ebay.com/itm/Vintage-1-8-...item2eb9d26db7 ......are these made from unobtanium???............
Old 12-07-2011, 08:57 PM   #1095
Default Dynamic Wheels/tires
They ARE unobtainium (able)! Those are the wheels from the Dynamic car I just bought! The Tires are the first gen, as we would say now, they were just stretched over the wheels, were made out of solid rubber and weighed about a pound each!! They worked about as bad as you would think and molded foam tires were next.
It seems weird now but back in those days you never thought about spares or even extra tires! You were glad to have the set that came with the kit!!
The wheels were turned from bar aluminum with a 1/4-28 threaded axle and a jam nut to hold it on. Worked ok on the side that tended to tighten, but the other one came loose all the time. Luckily three of the guys in the club worked at in the Air Guard and could get lock nuts with nylon inserts, problem solved! Then the axles bent! The aluminum spur gear was screwed directly to the wheel with two flat head slotted screws and the pinion was steel. THe steel wore out way faster than the spur!!!!!!!!!!!!!!
