Old 12-14-2013, 10:26 PM   #3661
Dasmopar's Avatar
Send a message via AIM to Dasmopar
Word has pretty much rolled down from the top that 3 port motors will no longer be produced unless there is a order for like 20 of them at a time. No one would have thought they would pull the plug on this motor when everyone agreed to the three port engines. So even if rules had been put in place it wouldn't have changed novarossis mind on production schedules. They just aren't selling enough of them to bother with them. Now the 5 port motors look to be the option.
I'm not sure why I'm the one posting this info. Jeff and Lon sr are on the front lines of this, not me.
Lon II out!
Lon Burling II
Capicorn, Serpent America, Novarossi, Enetti tires
Chicky fan club member #11
Dasmopar is offline   Reply With Quote
Old 12-15-2013, 04:46 AM   #3662
Taylorm's Avatar
Lon II out!
No wonder I can only find a couple ( high priced at that)... I have an offer
standing on one on eBay for 185.00...so what say ye Lon Sr Poobah??..
I suggest up to 5 ports... There are many more choices without
eclipsing the 300.00 mark..,
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
Old 12-15-2013, 09:32 PM   #3663
[QUOTE=Dasmopar;12813974]Word has pretty much rolled down from the top that 3 port motors will no longer be produced unless there is a order for like 20 of them at a time. No one would have thought they would pull the plug on this motor when everyone agreed to the three port engines. So even if rules had been put in place it wouldn't have changed novarossis mind on production schedules. They just aren't selling enough of them to bother with them. Now the 5 port motors look to be the option.
Lon II out!
That's my boy! Any how this was never planned as a Novarossie class but their motor fit like a glove, then it was gone. Garen isn't saying if the Motonica 3-port is out there yet. Guess there are buggie motors out there but I know nothing about them (can't really suggest them.)
Just got some input from Jeff Z. with input from Jeff W. Anyone with a thought on this, let me know. The simple 3-port class doesn't appear to go as the class needs motors that anyone can get. A 3-port and a restricted 5-port class? Yes my offer to tech still stands. The 5-ports are out there and don't appear to be going away soon. What do you think?
Das 1/8th Mopar is offline   Reply With Quote
Old 12-15-2013, 10:00 PM   #3664
azeroth's Avatar
Trader Rating: 20 (100%+)
sorry to say you guys should check A-Main hobbies
http://www.amainhobbies.com/product_...-Standard-Plug
http://www.amainhobbies.com/product_...097-Tuned-Pipe
http://www.amainhobbies.com/product_...ine-Turbo-Plug
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 12-16-2013, 03:46 AM   #3665
howardcano's Avatar
Trader Rating: 35 (100%+)
You can also try here:
http://www.thercshack.com/fmsplus21-...rboplug-1.aspx EDIT: OUT OF STOCK!
Of course, if we just require a small restrictor, then there's no reason to limit to three ports, and that gives many more engine choices in the sub-$200 range:
http://www.amainhobbies.com/product_...G-Buggy-Engine
http://www.amainhobbies.com/product_...ipe-Turbo-Plug
http://www.amainhobbies.com/product_...n-Buggy-Engine
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 12-16-2013, 05:25 AM   #3666
Taylorm's Avatar
Lon ...good ideas... Maybe we run the 3 port motors with open
restrictor... And 4 and 5 port motors with a 7mm???... Should
help hold down the RPM of the 5 ports...???...
Lots of option then like Howard posted...
http://www.absolutehobbyz.com/produc...4ca2g2j84dhdn2
http://www.absolutehobbyz.com/produc...oducts_id=6062
http://www.absolutehobbyz.com/produc...oducts_id=6063
http://www.absolutehobbyz.com/produc...oducts_id=6064
then we have Davis machine Jeff a 3mm reducer....... : )
Howard...I think this would be perfect motor...Newbie wallet friendly!!...
Old 12-16-2013, 12:25 PM   #3667
Taylorm's Avatar
http://www.houstonsengineservice.com...79603e89dedd73
http://www.houstonsengineservice.com...79603e89dedd73 ..has CNC piston
some more buugy 3 ports....Novarossi based
Old 12-16-2013, 01:11 PM   #3668
Send a message via AIM to jeff whiting
Default Sounds Right?
I think an open restrictor for 3 port motors and a 7mm restrictor for 5 port motors seems reasonable and a good place to start. There are quite a few 3, 4, and, 5 port On and Off road motors out there. The variety of these options makes it fun and interesting and It would be fairly easy to tech these options if needed. Specifying the cost of a motor hangs me up a little just because the retail cost thing can get a little iffy with deep discounts, eBay and such. If you spend 350 on a nice 5 port buggy motor and then put a 7mm restrictor on it, I suspect you won’t go faster anyway. It might however last longer than a 150 dollar buggy motor.
We will run two pan cars for 2014. The car “formally known as the Rubber Band” but still French Fry DFX car and our new WRC 2013 car. We ran an Off-Road motor last year and I thought it ran pretty well so we may just stick with Off-Road based motors. I think this class can grow. A little self-policing, some easy to follow rules and a slant towards fun will certainly help.
Thanks to our sponsors: Desoto Racing, Serpent, Ielasi Tuned, HobbyWing, Byron's Fuel, Matrix Tires, Protoform, Futaba, www.LEFComplex.com
jeff whiting is offline   Reply With Quote
Old 12-16-2013, 01:51 PM   #3669
Taylorm's Avatar
Also don't want to limit by cost..... As costs
can vary widely... Where's Poo-Bah??
Old 12-16-2013, 02:06 PM   #3670
Farmer_John's Avatar
In a summer of grenading several higher dollar RB c6 buggy motors, I had a great experience running a Nova budget 3 port. The 086 pipe listed as best match is a monster though. HUGE!
Just chiming in, hi guys!
RCHOTPIT.COM...now alive...
Farmer_John is offline   Reply With Quote
Old 12-16-2013, 02:50 PM   #3671
Very interesting. I'm looking forward to seeing what everybody comes up with.
Old 12-17-2013, 07:49 AM   #3672
Taylorm's Avatar
guys...I looked up Novarossi N21B09 motor...case...crank..rod...piston ..sleeve...backplate..bearings.. are all the same as the N21-3T...just has a standard head/plug.....and carb is also different....
might be fine for our needs..
http://www.ebay.com/itm/Novarossi-N2...item35c9219e92
http://www.absolutehobbyz.com/produc...ducts_id=14322
http://www.serpentamerica.com/shop/p...&cat=78&page=1 DESOTO HAS 9..and just raised the price 30.00 !!!
http://www.amainhobbies.com/product_...-Standard-Plug just ordered...159.98 with discount code and shipping...
Old 12-18-2013, 12:45 PM   #3673
Yup, pretty much the same engine as the N21bf I was referring to.
Old 12-18-2013, 06:08 PM   #3674
Gary NJ's Avatar
You may want to pull the button off the motor when you get it and see how many ports it has. NR has offered that series of buggy motors for the last 5 years under various model names, and I have gotten a variety of ports (3,4 and 5) and differing cranks depending on the particular run. It seems like NR uses that engine as a place to build budget Frankenmotors using whatever surplus parts they are trying to get rid of....the A Main description is completely inaccurate and has been for years - they haven't made that 13mm, square bore/stroke, aluminum carb'ed version in years (wish they still did - I thought they were a great small track/low traction buggy motor...). All of them run real good, however, and the 086 pipe works good on all of them. (Budget tip: use a Dynamite hard anodized version of the 086, and available with out the buggy header, which you won't use anyway...perfect pipe, and indestructible - perfect for the 2wd ethos). If you want to be sure you're getting a 3 port NR, choose the Novarossi .21 P3XS Off Road 3-port Standard Engine - $179 before using a coupon at Absolute Hobbyz. Basically the 3 port version of the legendary NR P5...The Fusion 3 port would also be very good.
Personally, I'd stay away from the Chinese/Taiwanese 3 ports like the Losi, Dynamites, Ofnas etc. The carbs and bearings are nowhere near as good, and you pay so little more to get a genuine NR in this level of motors, that it just doesn't pay IMO.
Gary - GMK Supply
www.gmksupply.com
Great products. Goofy names.
Gary NJ is offline   Reply With Quote
Old 12-18-2013, 07:27 PM   #3675
Taylorm's Avatar
http://www.serpentamerica.com/shop/p...&cat=78&page=1. so Desotos description could be inaccurate also??...How the hell would a highly reputable co. like Novarossi advertise it as a 3 and it may be a 4 or 5??...so now I may have a high dollar paperweight??........now I'm rethinking all this spec crap...it never works out in the end...because even if we all run 3 ports...it only takes a smart guy with a Dremel and a modified sleeve...then whammo another open class..
http://www.sgrid.com/forum/entry.php...engine-timings guess we never discussed changing timing on the 3 ports...
you want cheap header/pipe?.. http://www.ebay.com/itm/Team-Solar-1...item19e525f5af damn cheap
