Old 11-01-2013, 05:33 PM   #3391
hitcharide1's Avatar
Send a message via Yahoo to hitcharide1
Default Just so you know...
YOU DA MAN!!!!!
The average response time of a 911 call is 23 minutes. The average response time of a .357 is 1400 feet per second.
hitcharide1 is offline   Reply With Quote
Old 11-01-2013, 05:36 PM   #3392
Taylorm's Avatar
https://sdp-si.com/eStore/CoverPg/Gears.htm go down to pinion wire inch/metric....they have 32 pitch in 9,10,11 tooth..
all in 20 degree P.A.
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
Old 11-01-2013, 06:16 PM   #3393
azeroth's Avatar
Trader Rating: 20 (100%+)
Originally Posted by hitcharide1 View Post
YOU DA MAN!!!!!
umm thanks now check your Private messages let me know
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 11-01-2013, 07:32 PM   #3394
Default Right
I'll get back with you on it, we've got to clean up the pieces and remake a few, final design issues. The pinions, on the other hand, should prove handy. We wanted pinion stock, first, to help Tom with his idea, second, to provide more pinion options for the current build. We're currently running 21p 40s, which was fantastic at Dayton, but it's still a little lacking for Toledo. We'll be moving the spur to a 38, but would really like a 22p which no one seems to make.
We didn't make many gear changes years ago because most tracks were the same, running Heart of America format, and all roughly about the same size (except Indy, which was huge, and Toledo, which was a bit small.) I think we can get by on one spur but would like more options for the pinion, since the pinion is easier to change on our build (have more than one bell ready to go, very short process.)
Old 11-01-2013, 07:50 PM   #3395
ScottE1776's Avatar
I tried searching the thread for the G10 source? anyone have a link?
ScottE1776 is offline   Reply With Quote
Old 11-01-2013, 08:10 PM   #3396
azeroth's Avatar
cool
http://www.eplastics.com/G10_FR4_Glass_Epoxy_Sheet
Old 11-01-2013, 08:14 PM   #3397
azeroth's Avatar
i thought sombody was making some pretty small ones for the speed run guys check some of the traxass stuff
Old 11-01-2013, 10:51 PM   #3398
Default TRUE ??
JEEPERS! the sand box is fun again. Who said,"I love it when a plan comes together."?
In 2002, Juan Pablo Montoya's BMW V10 F1 motor revved up to a record 19,050 rpms. A piston would have gone up and down in its bore 635 times to produce 158 individual combustion per second. can you dig it? I'm thinking it was really a 3-port, Who needs more?
Das 1/8th Mopar is offline   Reply With Quote
Old 11-02-2013, 02:26 AM   #3399
howardcano's Avatar
Trader Rating: 35 (100%+)
I got mine on Ebay. Small quantities are cheap! Do a search for:
G10 sheet 1/8"
or whatever thickness you want.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 11-02-2013, 04:41 AM   #3400
Taylorm's Avatar
www.mscdirect.com
Old 11-02-2013, 05:46 AM   #3401
Default Hey
I get the stuff from Matt's link, about 50 bucks for a 2 x 2 sheet, with which I can make at least five chassis. I'm using the same stuff for my servo trays as well, which is probably overkill, but results in superior protection for your servos and such. Light stuff, very easy to work with, and cheap enough that if you screw a piece up, no big deal.
Old 11-02-2013, 05:48 AM   #3402
Default Heh
I need more, to get up to 88 mph so the flux capacitor can work.....
Old 11-02-2013, 06:01 AM   #3403
Default Hmm
I'm using Revo spur gears mounted to the hub Tom remade (superior to the one I made.) About three bucks a pop and they seem to hold up well. Because of the gearing in the diff, none of the Kyosho or Edam spurs we have worked. There are enough various spurs available to get the job done and we've tried to stick with something "off the shelf."
One consideration, when we started thinking of building for sale, was cost/availability. With most kits, you're locked in to whatever the manufacturer supplies, which means being stuck with their supply chain and their price markup. Going this route, other than the pieces we make ourselves, a buyer of our kit can shop around and get the same parts from a multitude of sources for a decent price (I get Revo gears from the local hobby shop.) Frankly, most of our drivetrain is offroad, and there's just more parts available for offroad than their are for onroad.
Old 11-02-2013, 11:39 AM   #3404
Default AARCOBRA
Just so you know, AARCOBRA has had some major work done on his back, I for one hope he's doing well!
Old 11-02-2013, 12:19 PM   #3405
Default Hmm
The VA botched mine...permanently. Here's hoping his went better.
