Just got my NS12S3
Just got my NS12S3
Whats up all,
I just got my new motor and I had a couple of questions.
1. It comes with a standard button head, does anyone know where I can get a turbo button head for it?
2. If I only intend to run it in turbo trim should I break it in that way?
3. I'm sure it's original carb settings from the factory are done with the standard set-up, what changes should I make when I put the turbo plug set-up on it?
I know that's three but I do appreciate the help!!!
KEVIN
KEVIN
I have the NSR123 and changed the button to turbo button. I took out one shim to make the head clearance 0.014"
If you have a new engine you will need to run it in first before worrying about the carb settings
Go to http://www.ziggy12345.plus.com/Cars/ for all the setup docs for the engine
I cant say anything bad about my NS 3 port. It flys. When the liner wears out you can get a liner, piston, conrod and wrist pin for the NS 5 port for $100 and slot it straight in!!
Cheers
Cheers
Cheers
Cheers
16% If I was to go to 25% I would add shims to take it to around 0.020"
Fuel
I'm going to be running 30%, I just need to find out where to purchase the turbo button head and new spacers. Thanks Guys for your help!!!
Kevin
Kevin
When the carb. is calibrated for whatever weather conditions you're located at, what is everybodies run time per tank full ?
Usually
We pit on the 5 min mark but we push it at times, this is in race conditions. Close to six but that'll run it out
Whats the difference between a turbo and standard head? Can you see the difference in those two?
