Old 02-07-2004, 09:33 AM   #1
SeventyGTX's Avatar
Rotary to Slide carb for NTC3 questions
I plan on installing an OS CV-R with slide carb in my RTR NTC3. Is there a linkage kit available just for this particular application? Anyone have pics of their TC3 with a slide carb so I can see exactly how it should be installed.
Obviously by my post count, I'm new here. Looks like an awesome board! Thanks for any help!
SeventyGTX is offline   Reply With Quote
Old 02-07-2004, 10:00 AM   #2
Ducati-Rider's Avatar
Default Carb linkage
Hello - I have one of each and made the same transition, you can use the stock linkages and just use a 90 degree servo crank instead of the 180 degree.
I've been running nitro for 3 months.
Go to the AE website and look at the pics of the new NTC3, it shows you a top view of the lay out, or look in your manual.
Just make sure the linkages don't bind up cuz they will rub and stick and potentially stick open the throttle. I bent the throttle up a little to clear the brake.
I also run the OS, they ain't the quickest, but I've never had a flame out. Just keep the idle up and use a little drag brake when in neutral
Ducati-Rider is offline   Reply With Quote
Old 02-08-2004, 08:15 AM   #3
TOEBSTER2's Avatar
I also run a slide carb in the NTC3. I turned my servo around and used a 90 degree arm, a few custom bends and a little tweaking.
Crookid Creations
TOEBSTER2 is offline   Reply With Quote
Converting Rotary Carb to Slide Carb? hrnts69 Nitro Off-Road 1 07-18-2008 11:29 AM
WTB 11L ROTARY CARB FOR .18TZ, HAVE NEW SLIDE CARB TO TRADE? SHAGGS R/C Items: Wanted to Buy 0 12-01-2006 02:34 PM
NTC3 nitro throttle return spring ideas for slide carb motors? calstarjig90j Nitro On-Road 5 09-13-2004 09:56 PM
os .12 CV-R - 10c slide carb like new sickrcracer R/C Items: For Sale/Trade 0 01-31-2004 12:48 PM
slide carb for rx.18? rccraze Nitro On-Road 2 12-23-2002 02:38 AM
SEO by vBSEO 3.5.0
