3.3 Engine Takes long time to start, using Ez - Start
Hey
im using a 3.3 nitro engine and last time i started my car it took me a good minute or two to start the car by pressing the button on the ezstart remote but finally it started so what could be the promblem also i have the traxxas nitro 4 tech 3.3 and i just got a new glow plug and i have using 30% sport nitro fuel by blue thnder. Thanks |
anyone
3.3 engine
Originally Posted by imran
(Post 6282465)
Hey
im using a 3.3 nitro engine and last time i started my car it took me a good minute or two to start the car by pressing the button on the ezstart remote but finally it started so what could be the promblem also i have the traxxas nitro 4 tech 3.3 and i just got a new glow plug and i have using 30% sport nitro fuel by blue thnder. Thanks It is not good for the engine to take that long to start. Bad on the piston/sleeve, and bearings. Check the heat range of the glow plug, make sure your igniter is fully charged, and set the high and low needles back to factory specs. If you dont have the manual handy, go to google, type in Traxxas, and you should be able to get the high and low needle settings |
Don't hold the ez start button for too long! It's taking a long time to start because the neddles might be set up wrong. When I had the EZ start on my 4tec I would cover the pipe stinger with my finger and press the ez start button to prime the engine after the fuel reaches the carb it would start right up!!! press and hold for about 3 seconds. Try riching the hsn about 1/4 turn
Originally Posted by Gonzo RR
(Post 6288249)
Also make sure the wire from the ez-start to the glowplug is secure. |
