Old 08-19-2009, 08:35 AM   #1
Default Centax new problem
I ve been running centax clutches for a while now with out any problems. Ive set the nut that holds the spring after the shoe 9mm as stated in the manuals. It runs fine for 10 mins then the clutches slip. Everytime I take it apart the nut that holds the spring has screwed its self fully in. Any ideas what might be causing this?
one58 is offline   Reply With Quote
Old 08-19-2009, 08:37 AM   #2
SERPENT7twenty's Avatar
Trader Rating: 20 (100%+)
Call Serpent directly.
Kamikaze Development Driver - R&D = Rebuild & Destroy
SERPENT7twenty is offline   Reply With Quote
Old 08-19-2009, 09:17 AM   #3
Roelof's Avatar
Send a message via ICQ to Roelof
Be sure the nut and inside the clutchbell are smooth. When using a pin from the outside setting the nut you can bend some material of the nut to the outside touching the clutchbell.
And you can use some weak threadlock on the nut.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 08-19-2009, 09:48 AM   #4
wingracer's Avatar
Trader Rating: 21 (100%+)
That's what I do. I little dab of blue loctite and it's good to go. Once it's been done once, it forms a little ridge inside the nut so I usually don't have to reapply it. It can be moved easily until it gets to that ridge so it wont tighten up.
Sean. Certified speed crazed mowron.
Team Shepherd USA
wingracer is offline   Reply With Quote
Rc10ntc3 Taz_S Nitro On-Road 9420 09-03-2016 01:30 PM
HPI R40 Nitro Car Forum EVOLUTION Nitro On-Road 11979 06-26-2012 07:57 PM
RDLogics Mongoose KMac Nitro On-Road 2117 03-09-2011 12:57 AM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 01:47 PM
OS TZ running @ neutral bboy Nitro On-Road 6 05-01-2008 07:54 AM
Serpent 705 centax question. sstupid Nitro On-Road 16 01-21-2006 04:33 PM
SEO by vBSEO 3.5.0
