good temperature gun
#16
i agree the exergen temp gun is really good. my dad and i have had ares for at least four years and haven't had to change the battery
#17
Of my three temp guns; the Losi tmp/tuner, the duratrax temp gauge and the telemetry temp reader on my DX3S, two of them are very consistent with each other and other guns at the track. Those two are the DTX and the DX3S believe it or not. Once I do as the manual says, and check temp with vehicle stopped for 5 seconds or so, the DX3S telemetry seems to be spot on. That suprised me.
#18
exergen is the best tempgun.$250 for a bnew,but you could get a cheaper one on ebay or on the for sale forum. i think i saw one before for $150 (dx501).
#20
I still use my Raytek temp gun that I bought almost 10 years ago. I have one of the small O'donnell ones as a backup. I use each to check for accuracy between the two and my Raytek is right on point after all the usage. You can still find them new for under $100. The Odonnell one cost me a shade under $40 and it has a carrying pouch that you can attach to your belt. You can't go wrong with too many of the temp guns on the market.
#23
Boil a pot of water. Use a small aluminum, thin walled pot. Just when the water is at a full boil, place a piece of black electrical tape vertically on the outside of the pot. Now scan the temp gun up tape on the pot. It will hit 212F at the point where the top surface of the water is.
You can't just aim it at the water because it will measure the temperature of the steam/air/water/pot or whatever the beam deflects off of.
#24
Does anyone have any links or info on getting a exergen re calibrated??
#25
Pass you soon...
#26
Its 20 degrees cooler then the other exergens I compaired it with, and I made sure the lens was clean
#27
Suspended
#29
